Hot Rods BENNETTS ‘Pacific-Indian Special’ ‘29 Roadster on ‘32 rails
Discussion in 'The Hokey Ass Message Board' started by jordabennett, Jun 5, 2022.
  1. I just came to the realization that "Dunsborough" is not somewhere in Washington, but rather Western Australia. I've been following this thread thinking that you're border hopping between BC and Washington. I'm now even more impressed at you having that large Tim Hortons sign in your shop!
  2. Dragging what I can from home down under to keep the home sickness low hahah
  3. Well I definitely cut into the nice quarters today. Scary! But I’m on a roll havnt decided yet wether I’ll bring it back 2 or 2.5” yet but for me this will make a huge difference in driving. IMG_6933.jpeg IMG_6935.jpeg IMG_6936.jpeg IMG_6937.jpeg IMG_6938.jpeg
    charleyw, CSPIDY, hfh and 8 others like this.
  4. Tim
    Tim
    from KCMO
    That’s a clean cut! Looking forward to seeing where it lands!
  5. Knocked out a few more hours during naptime. both sides measured and cut out. Removed the upper trunk panel or car walk and started cleaning and Planishing. Next I removed about 2 3/8” or roughly 60 mm. Definitely lots of stuff to create, modified and manufactured in order to make it all work but it looking cool!
    so much room for activities’ IMG_6959.jpeg IMG_6957.jpeg IMG_6964.jpeg IMG_6960.jpeg IMG_6964.jpeg IMG_6967.jpeg IMG_6968.jpeg IMG_6978.jpeg
    porkshop, CSPIDY, Kiwi 4d and 7 others like this.
  6. dirt car
    dirt car
    from nebraska
    I'm confident to even the most familiar 28-29 observer barely a detectable modification.
  7. 05snopro440
    05snopro440
    Wow, incredible work as always.
    Kelly Burns and jordabennett like this.
  8. I see the tape running across the catwalk, implying a "cut here", and I see the newly "resized" catwalk fitting to the slid back cabin corners, I just don't see any sign of where the catwalk was ever welded back together. Nice work!!
  9. dirt car
    dirt car
    from nebraska
    I thought he may have re-bent the back edge although it appears to be a double bend, not sure.
    brEad likes this.
  10. You’re right. That part isn’t finished but it’s close to what was done factory… almost, but should work well and means no welding.
    brEad likes this.
  11. Thank you sir
    05snopro440 likes this.
  12. No welds! Not finished yet but it’s close. Some fine tuning hammering the edge over and the cat walk portion will be complete. Once that’s fitted with all the brackets and structures under shortened and modified it will be bolted in.
  13. Snuck in the shop after dinner for a hot minute- managed to cover a few things with this ****pit extension. Luckily the brace that runs vertically from the subrail to the quarter almost lined up perfect after removing the excess from the belt line.
    I hammered over my flange for the catwalk. And sealed it,
    Next step- weld the belt line and smooth that out, then mockup out upper quarter panel pieces to fine tune the fitment.
    IMG_7075.jpeg IMG_7083.jpeg IMG_7084.jpeg IMG_7091.jpeg IMG_7079.jpeg IMG_7077.jpeg IMG_7076.jpeg IMG_7081.jpeg IMG_7085.jpeg IMG_7087.jpeg IMG_7107.jpeg IMG_7106.jpeg
  14. Also got these great lenses from Chris at Polykings. I want to created a cast piece that these sit in and follow the contour of the head light. It’s an idea. Not sure yet.
    41 GMC K-18, Tim, brEad and 2 others like this.
    41 GMC K-18, Tim, Texas36 and 3 others like this.
  16. Well crazy thing I found out who purchased those head lights years ago- just working on getting them back.
    Spent the afternoon noon getting the right side tacked in. Inner structure extended and welded in and the upper quarter fitting nicely. Figures crossed by the time this is done you won’t really notice it.
    IMG_7151.jpeg IMG_7150.jpeg IMG_7235.jpeg IMG_7237.jpeg IMG_7240.jpeg IMG_7238.jpeg IMG_7243.jpeg IMG_7242.jpeg IMG_7241.jpeg IMG_7244.jpeg IMG_7245.jpeg IMG_7233.jpeg
    charleyw, brEad, 41 GMC K-18 and 5 others like this.
  17. Looking for 3 more similar to these 32 latches.
    Tim, brEad, 41 GMC K-18 and 2 others like this.
  18. Found this rad caps too if anyone could identify it? IMG_7276.jpeg IMG_7275.jpeg IMG_7278.jpeg
    rod1, Jimmy B, brEad and 7 others like this.
  19. 05snopro440
    05snopro440
    The video of moving the rear of the p***enger compartment back is really good.
    Jimmy B, brEad, 41 GMC K-18 and 2 others like this.
  20. Thanks!
  21. TexasSpeed
    TexasSpeed
    from Texas
    Finally got around to reading your build thread since I almost never get on the computer these days. This is excellent work!! Keep it up!!
    Jimmy B, jordabennett and Tim like this.
  22. Tim
    Tim
    from KCMO
    That rad cap is perfect!
    Seems a lot of the time a cap with that style is scaled to large. Good find!
    jordabennett likes this.
  23. Creating some sand bent pipes for my friends 32 3 window in Canada. So using my frame and these Ardun heads as mock up. Also playing around with flange ideas to. Textured and br***ed. Might be too much but will see. IMG_7549.jpeg IMG_7550.jpeg IMG_7552.jpeg IMG_7555.jpeg IMG_7566.jpeg IMG_7574.jpeg IMG_7626.jpeg IMG_7630.jpeg IMG_7634.jpeg IMG_7633.jpeg IMG_7636.jpeg IMG_7640.jpeg IMG_7649.jpeg
    old skoool, wandi harry, rod1 and 5 others like this.
  24. Tim
    Tim
    from KCMO
  25. Killer! How do they seal off, to keep from having an exhaust leak at the pipe/new flange?
  26. The pipe will be welding on the inside flange, giving you a simple look
    Kelly Burns likes this.
  27. Very nice! Thanks for sharing your work and the information!
  28. pittaway
    pittaway
    from england
    been following this on YouTube, fantastic work as always Jordan.
  29. Thank you sir!
  30. Roadster update- No progress. Been working on getting this 32 Tudor chopped. The roadster ch***is and motor has been aiding the mockup for the sandbent pipes that I’ll be dragging back home to Canada for Craig’s 32 3 window. The Scotsman’s talent for traditional sandbending is incredible to watch.
    IMG_7850.jpeg IMG_7851.jpeg IMG_7865.jpeg IMG_7815.jpeg IMG_7785.jpeg IMG_7790.jpeg IMG_7794.jpeg IMG_7795.jpeg
