Projects Achievable Pre-War Supe Job Build
Discussion in 'Traditional Hot Rods' started by RyanAK, Sep 17, 2022.
  1. RyanAK
    RyanAK
    Long weekend… improving weather. Maybe we get the body shimmed, bolted, prepped, and painted.
    Maybe…
    Went through this and it’s a complete carb with good br*** except for needing a choke lever. Parts are being cleaned and should be able to re***emble with gaskets this evening. Half carburetors almost done!
    Outback, Ragged Edge, brEad and 4 others like this.
  2. RyanAK
    RyanAK
    Getting the “extra” holes in the Winfield head plugged.
    And making a mess of one of my adapters trying to make it shaped like the originals. :mad:
    Outback, brEad, Ragged Edge and 3 others like this.
  3. Six Ball
    Six Ball
    from Nevada
    Where did you find the special Windfield racing plugs?
    Outback, winduptoy and 41 GMC K-18 like this.
  4. RyanAK
    RyanAK
    Ha. Hardware store. The big hole in the water jacket top was/is for a temperature sender. That came from the plumbing section. The ones on the side… no idea what the point of those are. They’re not even pipe thread. They had cut-off bolts threaded in. I replaced with square head grub screws.
    Outback, brEad, winduptoy and 3 others like this.
  5. RyanAK
    RyanAK
    My cheap drill press quit… so no making another adapter for the foreseeable future. :mad:
    Outback and 41 GMC K-18 like this.
  6. RyanAK
    RyanAK
    Maybe I’ll drill the heads of those grub screws and safety wire them together and really confuse people… :p
    Outback, brEad, Ragged Edge and 4 others like this.
  7. RyanAK
    RyanAK
    Cleaned up and everything checked. Ready for new gaskets.
    Outback, Carter, brEad and 6 others like this.
  8. RyanAK
    RyanAK
    Hours of work… so many setbacks. I’ll spare most of the details. I’m really struggling with the front door alignment and as I tweak things, the doors are revealing themselves to be rougher than first thought.
    IMG_7908.jpeg IMG_7909.jpeg IMG_7910.jpeg IMG_7912.jpeg IMG_7913.jpeg IMG_7914.jpeg
    On a positive note, the rear doors seem to be solid and the alignment is going much better.
    Outback, brEad, winduptoy and 5 others like this.
  9. RyanAK
    RyanAK
    Getting closer…
    Outback, brEad, 41 GMC K-18 and 3 others like this.
  10. RyanAK
    RyanAK
    I need to decide on what is good enough for these front doors. This would be an eight year old car in the period, but the doors I’m working with are pretty rough.
  11. Six Ball
    Six Ball
    from Nevada
    Do the best you can with these while lookin for better ones. Don't modify the body to fit the doors.
    Outback, Martinbuilt, Carter and 3 others like this.
  12. RyanAK
    RyanAK
    Put the Sawzall away. Got it. :p
    I have them “pretty good”. There just isn’t much else to be done with what’s left of these.
  13. RodStRace
    RodStRace
    And choke up on the BFH. Tap, tap, tap.
    As for fitting in period, think about how many 'new' cars are totaled these days and what a 2 year old, stolen, joy ridden and left abandoned car would look like, then add it sitting for a couple more years, when some low buck hooligan scoops up the pile for a song. It may not have a bunch of rust through, but beat up and bent is going to fit.
  14. RyanAK
    RyanAK
    Good ***essment, Rod @RodStRace. The car is basically in “appropriate” shape for 1937. It’s been repainted a LOT over its years. Except for the two front doors, it’s solid.
    Now… how to do a period appropriate interior…. o_O
  15. RyanAK
    RyanAK
  16. 5window
    5window
    41 GMC K-18, Six Ball and RyanAK like this.
  17. RyanAK
    RyanAK
    We’re going to spackle it and move on for now.
    School ends Tuesday and Spence will have more emotional equity to spend on enjoyable things. This was a really difficult school year for him. He’s wiped out. But Tuesdays at the Arrowhead sounds wonderful!
  18. Six Ball
    Six Ball
    from Nevada
    A few hours of soaking in a citric acid/water solution will remove the rust and not remove other metal. Rinse it with soda/water and do whatever repair works. Things like Rust Mort turn the rust into another oxide that can then be painted over or repaired. The citric acid is no more harmful than lemon juice.
  19. RyanAK
    RyanAK
    Ok… I have a plan for the front doors. I’m not sure how much I want to divulge because of… well… shame. Let’s see how it goes first. o_O
  20. 5window
    5window
    Man, I need some dry weather. Can you please let us know when you are NOT going to be outside working on this car so I can pan ahead :)
  21. RyanAK
    RyanAK
    $5 650-16s for the rear.
    Outback, Ragged Edge, Mikko_ and 6 others like this.
  22. RyanAK
    RyanAK
    Some more bits and bobs for the Winfields courtesy of Kevin.
  23. RyanAK
    RyanAK
    And a prewar coil.
    Outback, Tim, winduptoy and 7 others like this.
  24. Martinbuilt
    Martinbuilt
    You bonehead.
    A few hours ago, i didn't know what an Echlin coil was.
    Now, i'm shopping...
    Outback, winduptoy, Six Ball and 2 others like this.
  25. RyanAK
    RyanAK
    This thread might affect the like-minded that way. :p
  26. RyanAK
    RyanAK
    It’s heavy. I may have hurt myself…
    Gotta dig a hole in the tiny shop and then we can try for better Winfield adapters.
    Outback, Tim, winduptoy and 5 others like this.
  27. RyanAK
    RyanAK
    Gettin’ somewhere…
    Outback, winduptoy, Carter and 4 others like this.
  28. RyanAK
    RyanAK
    Found a hole…
    Outback, winduptoy, Six Ball and 4 others like this.
  29. Martinbuilt
    Martinbuilt
    Like a proper shop.
    Needs more clutter.
    winduptoy, RyanAK and 41 GMC K-18 like this.
  30. RyanAK
    RyanAK
    This shop was underwater. It’s all clutter. I just frame the photos so people think I know what I’m doing. :p
    Outback, Six Ball, Carter and 2 others like this.
