Art & Inspiration Yo-yo shift knob
Discussion in 'The Hokey Ass Message Board' started by Moriarity, Nov 1, 2020.
  1. Grimpala
    Grimpala
    from DFW
    continentaljohn and Moriarity like this.
  2. Dang it.
    Now I want one.
    6inarow, -Brent-, Sharpone and 3 others like this.
  3. aircap
    aircap
    Now I'm thinking skateboard wheels might work in a pinch.
    Sharpone likes this.
  4. Not like any of US would do that, right ? HUH ?
    Sharpone and Moriarity like this.
  5. That gold metal flake steering wheel is just perfect on the mill. I've turned and machine a lot of Lucite and other plastics some 25 years ago in industrial applications. It takes patients. Or it crumbles up on you. The Green knob is great !!
  6. Might have to find a piece of stainless and machine one
    Machine the plastic as well.
    didn’t see any on a Google search
    Sharpone, guthriesmith and Moriarity like this.
  7. Anyone got the overall diameter/width for these.
  8. Moriarity
    Moriarity
    SUPER MODERATOR
    diameter is the same as the width at 1.850
    6inarow, 5window, Just Gary and 2 others like this.
  9. Ok. Just spitballing
    you can get stainless and aluminum tubing and solid stock. Granger will sell as short as 6”.
    But these marine collars could be a head start.
    Yes/no
    not an exact reproduction but close enough maybe
    Uncle Ronn, Sharpone and Moriarity like this.
  10. 1biggun
    1biggun
    Have you ever seen a shifter knob were a clear gl*** lens comes out and you can put a picture under it/ I saw one in a antique shop years ago wiht a pin up type picture in it and wish I had bough it . Never seen another . Kind of like a locket on a necklace . Id like to find one may have to make one .
    sorry to go off topic
    thanks for sharing the the YO YO stuff very cool
    Moriarity and Sharpone like this.
  11. Along with my own shift knb creations, I've probably bought and sold hundreds of "survivor" shift knobs.
    I've noted a trend of shift knobs tending to get bigger as the population has also tended to get larger than we were in the early HAMB days.
    It wouldn't bother me a bit to reproduce a 2" yoyo instead of a 1 7/8" original-size piece.
    5window, Sharpone and anthony myrick like this.
  12. atch
    atch
    I bet that if they were actually a "store-bought" item that Mark has a collection of them.
  13. 1biggun
    1biggun
    the one I saw was or appeared to be a store bought item and was made of a plastic or some type of Bakelite type material had a rounded cl*** Lense like a pocket watch and a wire ring to keep the gl*** in I think . I wish I had just bought it id .
    I may try and make one some day from a old shift knop form a truck or old fork lift
  14. Moriarity
    Moriarity
    SUPER MODERATOR
    I once had a necker knob that you could change the photo in but have never seen a shift knob like that...
  15. 1biggun
    1biggun
    Well now your collection is not complete ;)
    Wish I had bought the damn thing .
    Those Yo Yo knops are pretty cool now ill have to look for one .
    I used to have a purple gl*** antique door knob I doug out of the ashes of my Grandparents old house on the ranch mounted on my Vertigate shifter in my Chevelle LOL . Its going to go on my roadster if I ever get it done
  16. Found some 2 inch OD machinable plastic in red
    That’s the color I want
    Could also probably stack different color discs.
  17. Moriarity
    Moriarity
    SUPER MODERATOR
    go man go
  18. Ordered some skateboard whees last night
  19. -Brent-
    -Brent-
    If anyone wants to make a black set and a green glitter set for the Eelco type yoyo knobs like @Moriarity posted above - please PM me.
  20. nochop
    nochop
    from norcal
    I would seriously consider one of these…. IMG_8342.jpeg IMG_8341.jpeg IMG_8340.jpeg
    CSPIDY and -Brent- like this.
  21. jnaki
    jnaki
    Hello,
    When you select skateboard wheels, make sure the style is what you want. Straight cut edges or rounded from the mold wheels. The straight edge ones are more popular as they grip flat on any surface. The rounded edge ones are easier to use on a down the street or paved roadway as it allow the transition from one carve to the next with the rounded/smoothed edges.
    The skateboard wheels come in hardness ratings. The soft units are hard to work with if you want to re-shape them. If the straight edge is soft, it may be difficult to shape to smoooth curves like a yo-yo style. The “hard” rated wheels have stiffer material compound and can be used for the grip. Some come pre-shaped with curved outer edges.
    Jnaki
    The hard edged and hardest compound wheels cut easier and can be shaped. YRMV
  22. Grimpala
    Grimpala
    from DFW
    Where did you find the plastic? I'm looking for green.
  23. Did a Google search for machinable plastic.
    But searched for red
    There’s green blocks. Not cheap
  24. Thanks. Got a set coming to the house.
    Not sure on the hardness though. They were cheap with free shipping.
    The plan is to take just enough off so they fit in the 1.25 OD collar I ordered and fit flush with the 2 inch OD. The collar is 1.99 OD. The wheels are 2.047 OD
    It’s my prototype:)
    Sharpone, patsurf and jnaki like this.
  25. Look up green delrin
    -Brent- and Sharpone like this.
  26. Moriarity
    Moriarity
    SUPER MODERATOR
    Does Delrin polish ok? All of mine are acrylic which polishes real nice...
  27. Moriarity
    Moriarity
    SUPER MODERATOR
    a bit rough but a clear one recently sold on eBay
    https://ebay.us/m/Rt6Oj5
    Sharpone and -Brent- like this.
  28. willys36
    willys36
  29. continentaljohn
    continentaljohn
    You can cast your own green ends by using products like
    Alumilite.com
    Make your own mold and fill it in with resins your color or metal flake . The one thing is if you have a deep mold with high details you have to put the drying mold resins in a vacuum chamber. This help any bubbles getting trapped inside your project.
    I did a few skulls ,shift knobs and dash knobs in clear but with rainbow flake. The stuff turns hard enough to tap it and use a set screw but not rock hard image.jpg
    teach'm, Sharpone and -Brent- like this.
  30. lonewolf
    lonewolf
    A wood one on ebay now
