rebuilding after the crash
Discussion in 'Off Topic Hot Rods & Customs' started by racer-x, Sep 19, 2015.
  1. Now that all eight cylinders are even we can start adding power. Timing was only 40 degrees. I upped it to 45 yesterday. That will make it hit harder and rev up faster. I also changed the lenco from a 1,25 to a 1.34 this will make it hit harder also. PXL_20250505_230759150.jpg
    Tim, mad mikey, chryslerfan55 and 8 others like this.
  2. Calkins
    Calkins
  3. Thanks Justin for posting the video. The car sure sounds angry. More good things to come in Eddyville.
    Thanks go out to the hamb members who stopped by our pit area.
    Tim, chryslerfan55, enloe and 7 others like this.
  4. 19Eddy30
    19Eddy30
    from VA
    I looked for live stream or post video
    Thursday through Sunday,
    Did not see any for 2025 Chaos ,
    Only Finials video for each cl*** .
    chryslerfan55 and porkshop like this.
  5. Calkins
    Calkins
    They no longer offer live feeds. They could not get the sponsorship to pay for it.
    chryslerfan55, loudbang and porkshop like this.
  6. It will be live at Eddyville.
  7. TerrytheK
    TerrytheK
    chryslerfan55, CDLooper and Calkins like this.
  8. 19Eddy30
    19Eddy30
    from VA
    Elimination Results:
    & Qualifying
  9. The car has been serviced. The upper rod bearing were changed along with a few lowers. The trans with the 1.34 gear set is in. The shifter linkage received a lot of attention to ensure it works perfectly. A new shifter gate with detents was my made. New heim joints that are heavier were installed. The trailer was cleaned and restocked. Restocking is a time consuming thing. Nitro; oil; methanol; solvents; water; and anything else that was consumed needs to be replaced. The trailer needs to be washed. The bathroom needs to be cleaned. The tires need to be checked for damage. The refrigerator needs to be cleaned and restocked. Before the next event a trip to the grocery store will happen. It's a never ending process. There's a lot of behind the scenes work going on to make a race. We have a plan for Eddyville.
  10. My boy, ya done did good. I hope you are successful in your return to the drag strip. Give ‘em hell.
  11. Calkins
    Calkins
    Here are the YouTube links for his weekend's event at Eddyville Raceway Park;
    Friday Qualifying:
    Saturday Qualifying:
    Sunday Eliminations:
  12. Thanks for posting that info. We are loaded up. Leaving Thursday morning. We have the car tuned up. PXL_20250519_183238118.jpg
  13. We arrived without incident. We are set up ready for some chaos. PXL_20250522_190029826.jpg
  14. DDDenny
    Safe and happy racing to you Bryan.
  15. Ran into the Farm Truck driver from the TV show. Cool guy PXL_20250522_200254164.jpg
  16. snoc653
    snoc653
    from Iowa
    Are you running tonight? Looks like the rain has finally cleared out. With cool temps should be good power for the making.
  17. Calkins
    Calkins
    EVENT SCHEDULE:
    Thursday · May 22
    Parking - PROS - Noon to 8 PM
    Friday · May 23
    Parking - ALL CL***ES
    Pit Gate Opens 9 AM
    Spectator Gate 4 PM
    Sportsman TNT 5 to 6:30 PM
    Small Tire Test Hit 7 PM
    Funny Car Chaos Q1
    Nitro Chaos Q1
    Saturday · May 24
    Pit Gate Opens 8 AM
    Spectator Gate Opens 10 AM
    Sportsman Time Trials 10 AM (2)
    Sportsman Eliminations As Called
    WARM-UP CHAOS NOON
    SMALL TIRE Q1 2 PM
    FUNNY CAR CHAOS Q2
    NITRO CHAOS Q2
    Sportsman Eliminations Continue
    SMALL TIRE Q2 7 PM
    FUNNY CAR CHAOS Q3
    NITRO CHAOS Q3
    SMALL TIRE Q3
    Sunday · May 25
    Pit Gate Opens 8 AM
    Sportsman Time Trials 10 AM (1)
    SMALL TIRE Round 1 @ Noon
    SMALL TIRE Round 2 @ 2 PM
    FUNNY CAR CHAOS ROUND 1
    NITRO CHAOS ROUND 1
    SMALL TIRE Semi-Finals @ 5 PM
    FUNNY CAR CHAOS Semi-Finals
    NITRO CHAOS Semi-Finals
    ALL FINAL ROUNDS @ 7 PM
  18. 19Eddy30
    19Eddy30
    from VA
    Live Streaming available ?
    Link & if so when will it start ?
  19. Calkins
    Calkins
    Go up about six posts.
  20. 19Eddy30
    19Eddy30
    from VA
    Thank you ,
    some how over looked
    Calkins likes this.
  21. Calkins
    Calkins
    Jerry Kaye photo:
  22. mad mikey
    mad mikey
    Excellent ^^^^^^^ Do your deal Brian.:)
  23. Unfortunately the converter broke. I drove home today and pulled it apart. It will get sent out Tuesday. I have secured another while it's being repaired.
    On a positive note Jerry Newman turned up the power. It sounded and felt like never before. PXL_20250524_235219572.jpg
  24. snoc653
    snoc653
    from Iowa
    It was nice meeting you. I was hoping that the problem last night wasn't a showstopper. Hopefully next time I'll be able to see you get a p*** as your car looks awesome.
  25. wrenchbender
    wrenchbender
    Well **** Brian I was hoping to see you make a p*** but when I didn’t get to see you run this evening I wondered and looked up the qualifying runs and found you had no times turned in I figured something happened and was hoping it wasn’t bad but I see it isn’t good but at least it wasn’t severely catastrophic good luck on the next outing
  26. Tim
    Tim
    from KCMO
    Worlds most expensive game of knocking over dominoes! Add power, break the next thing repeat but boy does it sound good! Love following along seeing how you create solutions at every turn and somehow make it create even more power!
  27. 19Eddy30
    19Eddy30
    from VA
    Do you know what broke in converter ?
    Does not look to be serviceable unless cut open.
    I seen Friday Night @ start up ,
    Could not tell if started before water box , if so is that when broke when you went to engage forward ?
  28. It turns out the converter didn't break. I changed gears from a 1.25 to a 1.34 for a better 60 foot.
    I have changed gears for decades and never ran into this issue. The 1.25 uses a different shaft. It's smaller by .050 so the splines were not engaged. It's a easy fix I just put the 1.25 back in. I guess those things happen when you have no sleep and your in a hurry.
    We will be back at Eddyville the weekend before the fourth of July for their night of fire. PXL_20250525_210700944.jpg
  29. TerrytheK
    TerrytheK
    Gotta say that the "Like" in this case isn't for the fact that you broke, it's for the post explaining what you found. Seems like it's often the little things that'll get ya. Glad you figured it out and as you said, an easy fix.
    And of course, for the umpteenth time, thanks for taking us all along for the ride. What a ride it is!!
  30. wrenchbender
    wrenchbender
    Well at least it isn’t a terrible fix and hopefully didn’t cost much but I understand the being in a hurry and no sleep deal after my bonneville experiences that whole week is that probably very comparable to a drag week deal I’ll see you at mokan for sure
