Hot Rods Sway bar on chevy straight axle
Discussion in 'The Hokey Ass Message Board' started by 6inarow, May 25, 2025.
  1. 6inarow
    6inarow
    Thoughts on how helpful a sway bar, anti roll bar whatever you want to call it, is on a 38 Chevy with original axle dropped 3". Probably will be radial tires
  2. choptop40
    choptop40
    They are used in solid axle rears .Don't see why it would not work as long as the frame is strong
    6inarow likes this.
  3. Joe H
    Joe H
    Tim, milwscruffy and 6inarow like this.
  4. 6inarow
    6inarow
    Thank ypu for the post @Joe H I am ***uming the pick up is the same as the p***enger car? Secondly where did you get the shock mounts for the front?
  5. Doublepumper
    Doublepumper
    from OR-WA, USA
    I recently put one under the front of my '46 Ford pickup. Like night and day difference! No more wallowing and tracks great. I highly recommend one.
    deathrowdave and 6inarow like this.
  6. swade41
    swade41
    from Buffalo,NY
    I bought one for my 57 pickup
    6inarow and deathrowdave like this.
  7. Dan Hay
    Dan Hay
    Do it. A sway bar is a good upgrade to the front end of any ride. I put one on my 39 Ford (straight axle) and it was a different car. Of course transverse axle Fords benefit a little more than parallel leaf Chevys.
    6inarow likes this.
  8. deathrowdave
    deathrowdave
    from NKy
    I used one from Jeep CJ on my 37 Chebbie
    6inarow likes this.
  9. deathrowdave
    deathrowdave
    from NKy
    Front was CJ rear was late 70s TBird on the 37 Chebbie . Both fit as if they were made to be used on the 37
    6inarow likes this.
  10. Joe H
    Joe H
    The front shock mounts on my axle were on it when I pulled out of a fence row, I beleive they be stock lower mounts, the uppers were also on it, they are just so 1/4 or 3/8" steel plate bent and welded to the frame. They fit behind the inner fenders and didn't look to bad so I left them. The shocks are fairly short so I didn't have a lot to choose from, these I think are Ford Pinto rears.
    I had stock '37 bar off a carry-all or suburban type car/truck, it was really small diameter and used some hard to find links on the ends, I sold it and bought the later truck unit.
    Tim and 6inarow like this.
  11. 1971BB427
    1971BB427
    from Oregon
    I like rear swaybars on cars/trucks with parallel leaf spring solid front axles, but never found a need for a front swaybar on them. I just felt it cluttered up the clean front setup, and even if it improved handling I'd likely not add one for my cars.
    6inarow likes this.
  12. 6inarow
    6inarow
    any particular year? This sounds like the cats *** to me if it is as easy as you say
  13. 24riverview
    24riverview
    GuyW, deathrowdave and 6inarow like this.
  14. deathrowdave
    deathrowdave
    from NKy
    Never saw stock 39 front axle and such . It’s different than 37-38s I have tinkered with . No tube shocks on earlier or sway bar , the reminder looks dead on
    24riverview and 6inarow like this.
  15. Joe H
    Joe H
    They came on the commercial vehicles, Carry-all/Suburban types.
    6inarow likes this.
  16. 1971BB427
    1971BB427
    from Oregon
    1939 Chev didn't have tube shocks, they had knee action shocks. The axle shown is modified to add tube shocks.
  17. 24riverview
    24riverview
    Sorry but Chevrolet and I respectfully disagree, every beam axle 39 I've been around had them.
    From the 39 service manual and other literature-
    1939 Chevrolet Manual.jpg Resized952025052795194442=1.jpg Resized952025052795194520-1.jpg
    6inarow likes this.
