Technical Cam ID Help 348 Chevy
Discussion in 'The Hokey Ass Message Board' started by BOSTONCAMARO, May 27, 2025.
  1. I picked up a newly rebuilt 348, from an estate. I want to put a little hotter cam in it, so I took this out guess it is stock replacement? maybe IMG_0939.jpeg IMG_0941.jpeg IMG_0939.jpeg IMG_0944.jpeg IMG_0939.jpeg IMG_0941.jpeg IMG_0944.jpeg a longshot but there are some smart folks here.
    Thanks, Tim
    Cam number 263173
    Deuces and Sharpone like this.
  2. saltflats
    saltflats
    from Missouri
    Really need to watch lift and duration with those pistons.
  3. '
    Something mild
    Sharpone likes this.
  4. Ericnova72
    Ericnova72
    from Michigan
    Have you got a dial indicator and magnetic base (or a way to solidly attach the indicator and arm)??
    If so, degree the cam out and thus reverse engineer the cam card straight from the cam you have....not much different than sending the cam out to someone who has a Cam Doctor measuring rig set-up.
    If you need a degree wheel, there is a download printable version, just glue it to any round flat object you can put a hole through the middle of....pie tin, small cheap pizza pan, old plastic frisbee, cheap plastic picnic or Walmart dinner plate.
    Tavia Performance Products Downloadable Degree Wheel
    If you don't have a 1" travel indicator and mag base, I suggest you get one.....valuable for numerous hot-rod uses and nearly every hotrodder should have one
    Harbor Freight is one budget source. Amazon can set you up as well.
    Truckdoctor Andy and Sharpone like this.
  5. saltflats
    saltflats
    from Missouri
    With a part number like that I would guess it a stock replacement cam.
    BOSTONCAMARO and Sharpone like this.
  6. Taboo56Chevy
    Taboo56Chevy
    I think that's a 409 truck block and not a 348. Based on the X on the front of the block, the big relief cut at the near the deck, the casting number on the back (I could be reading wrong) and then the drilled and tapped holes in the p***enger side of the block near the timing chain cover bolt holes.
    But rule of thumb with the un notched pistons for valve reliefs is 220 degrees at .050 and a 110 LSA is the biggest you can go without clearance issues. That at least for the lower hp 348's, should be similar on a 409
  7. I didnt even check block number, was a quick run up to Maine on a Sunday morning.
    I heard specs like a low HP 409 will work, melling makes one I hear.
  8. Jtaylorok327348
    Jtaylorok327348
    You dont have valve relied in the pistins so you know the intake/exhaust duration on a 348/409 is limited .555 or less.
    BOSTONCAMARO likes this.
  9. yes, want to go with better than stock but not too radical
  10. boxerdog
    boxerdog
    It looks like a 655 block, which is one of the better 348s. Showcars can probably fix you up with a mild hydraulic like their 908 or 911 to keep it mild, make sure you get some quality lifters.
  11. I hear Melling makes a 409 / 340 hp replacement that is in hyd and will lilely not have any clearance issues. It is a 655 block.
    Deuces likes this.
  13. what do you think of the ones I posted above? thanks!
  14. JD69
    JD69
    from Hockinson
    Looks like a 409 truck block.
  15. boxerdog
    boxerdog
    348 truck block. A 409 would be a 656.
    I'd back off the Melling, you would fall asleep with the it. The SC/Iskys are a little pricey. You might also call Camcraft and see what he can whip up for you. You could play it a little safe with the Howards by running BBC 1.7:1 rockers JIC.
