Technical What are you working on?
Discussion in 'The Hokey Ass Message Board' started by Lloyd's paint & glass, Jul 18, 2022.
  1. enloe
    enloe
    from east , tn.
    Getting ready for Bowling Green. I should be driving it this week. image.jpg
  2. Rehpotsirhcj
    Rehpotsirhcj
    That looks fantastic!
    I finished up the seat kit for my 3100 today. Much better than it was, but I think very much in the deflated *** category. :)
    saltflats, 1pickup, alanp561 and 8 others like this.
  3. Looking good Enloe! We are looking forward to seeing you guys.
    alanp561, porkshop, Sharpone and 4 others like this.
  4. We're a long way from being able to do professional upholstery, but, when you want the trunk to have a finished look, you do what you can. So, clear off the kitchen counter... move over the bread machine... and go to town. :D
  5. RockyMtnWay
    RockyMtnWay
    Picked up this insert from a bud that has since p***ed on. I’m hoping he likes what I did to it. It’s a repoper so don’t get too worked up. :p:p:p
    saltflats, porkshop, Sharpone and 5 others like this.
  6. So last week I went to an auction here in Southern California and ended up winning a couple of flatheads...
    They both had mercury heads on them and both were seized up solid but when I picked them up they were technically in a garage, So one of them broke loose with a breaker bar at about 2 minutes of work but there is a slight stiff spot... I haven't taken off its right cylinder head yet to inspect I did take the left side off because I wanted to measure the bore and low and behold it is a 4-in stroke Mercury engine just like the heads would have had me believe (That is a win!!!) So the second engine was a little more work it was also locked up solid It is a 1953 Mercury flathead It did not move at all with a breaker bar on it so I pulled the cylinder heads and filled up every cylinder that I could with cleaning vinegar and let it sit for a few days. At that point I ended up getting the engine too ever so slightly move and I went back and forth back and forth about a bazillion times and I managed to get maybe 100° of rotation out of it, at that point I filled it up with vinegar and let it sit for another 48 hours or so then I went back out there and worked at it again I managed to get the engine to turn over although it is still really stiff. I ended up taking a cylinder hone to all of the cylinders to knock off the scuze (carbon and rust) And I discovered pitting and a pretty big ridge but know that the engine turned over I got to measure its stroke and it too is a 4" stroke So that was another win...
    So now I have two Ford flatheads One of them I think would probably be a good candidate for a real quickie rebuild, meaning new rings and bearings and probably a cylinder honing along with some fresh gaskets and it would be good to go The other engine realistically probably needs to be rebuilt and I have no idea what I'm going to do with it if I'm being honest with myself I will probably sell it because I don't have room for it but anyways that's neither here nor there and that's a story for another day. But this was my on topic project that I have been working on for the last 5 or 6 days for a few hours here and there every day. Hopefully no that my off topic car is finished And these Flatheads turn over I could now go back to working on my model A banger project.... I was really hoping to have it done by the beginning of summer but that didn't happen I consider memorial Day weekend the beginning of summer So maybe the end of summer and Labor Day weekend lol
    Here Is my flathead projects the day I picked them up along with a lot of other cool vintage car debris and Here is The 1953 turning over.
    61Cruiser, BigRRR, saltflats and 6 others like this.
  7. I used to hate rust repair Now I am getting kind of comfortable with it I don't really mind it now.
    Your patches are looking really nice and all the body lines look like they are lining up pretty good.
    Some of the patch panels I bought from my model A the fitment was atrocious especially the ones that repaired the cab corners on the pickup cab.
    Edit I apologize I commented on something from 3 years ago...
    I don't know what happened somehow I ended up back on page six I think. I might have fat fingers lol
    porkshop and Sharpone like this.
  8. jazz1
    jazz1
    IMG_3565.jpeg Removed the body from junk frame..note the remains of ifs stub cobbled onto original frame 40 years ago IMG_3561.jpeg
    saltflats, swade41, porkshop and 6 others like this.
  9. 1971BB427
    1971BB427
    from Oregon
    Spent all day trying to fit a new aftermarket grille in my '39 Chevy coupe only to find it's a **** piece. So bad fitting I had to put my old grille back in, and this junk becomes wall art. 6 hrs. wasted I'll never get back.
  10. dsiddons
    dsiddons
    from Indiana
    Put the aerodynamic spears on backwards. I’ve done so many pleated examples and decided to not do any pleats on the sides.
    saltflats, 26 T Ford RPU and porkshop like this.
  11. Had to pull the super T-10 out to replace the syncro's. Earlier this year, I replaced the rear seal and put the wrong gear oil in. (synthetic). Realizing my mistake, I dumped the oil and re-filled with non synthetic GL5. Then found the older trans needed GL4... :(. Too late, the damage was done. Cold, everything worked fine, but, as you went along, it got harder and harder to shift and the ****** got extra hot. Pulled the side cover and... sure enough... the syncro's were discolored. Waiting on the rebuild kit. Decided while I had the ****** out, I might as well pull the engine and get rid of that ****py, leaky, chrome oil pan that refuses to hold a gasket. I think a nice cast aluminum one will be in the works.
  12. mad mikey
    mad mikey
    Sorry to hear that. These parts are becoming a real problem, all the parts for automotive and trucks, maybe try to get your money back on the **** part.
    Sharpone likes this.
  13. Bandit Billy
    Bandit Billy
    How about a better shot of the fan mount?
    Love the Harrison tank but it looks like it needs a little attention.
    mad mikey and Sharpone like this.
  14. swade41
    swade41
    from Buffalo,NY
    I started bolting the bed together on the 57, real happy with how these mismatched parts are fitting
    Also put a new date certified harness in the Henry J, between those two I've managed to re-agrivate my si joints in my lower back .... ugh
    rod1, saltflats, 1940Willys and 5 others like this.
  15. oldiron 440
    oldiron 440
  16. swade41
    swade41
    from Buffalo,NY
    Low impact back work was mocking up $50 bucks worth of new Henry J scoop sticker possibilities, I kind of like the first one to give a nod towards Hollywood Knights
    This would be the one if it was a little longer, but it's kinda small on there
    Same kinda thing with the beast
    This one is just letters, no background so it might get lost
    Whatever I don't use on the scoop might find it's way onto the new white open face helmet.
  17. Greg Rogers
    Greg Rogers
    I vote 1st one.
    swade41 likes this.
  18. deathrowdave
    deathrowdave
    from NKy
    My Friend I find myself saying the very same thing lots of times anymore . I get so frustrated with Drs office and insurance companies . My damn time is just as valuable as the Drs time , be one time for the scheduled appointment . I explained to a lady last week my feelings about having to call the insurance company. I told her my feelings were : she is getting paid for hours of settling my claim correctly . I’m getting paid nothing , it’s wasting what valuable time I have on the life clock and if it was done correctly she would no longer have a job. She wasn’t happy with me at the end of the conversation .
  19. patsurf
    patsurf
    prob not at the beginning either...
    Sharpone and alanp561 like this.
  20. enloe
    enloe
    from east , tn.
  21. shorrock
    shorrock
    No other pic, sorry. The fan is bolted to a stub that is driven by the large V-belt wheel under the blower. 20250501_162614.jpg
  22. Tickety Boo likes this.
  23. enloe
    enloe
    from east , tn.
    Yes
    The numbers said it was a 1965 327/365 engine.
    rod1, J. A. Miller, mad mikey and 2 others like this.
  24. Onemansjunk
    Onemansjunk
    from Modesto,CA
  25. Onemansjunk
    Onemansjunk
    from Modesto,CA
    How many miles or hours did it take for the synthetic/and the GL5, take to damage your Super T-10? That ****s big time!
  26. 1pickup
    1pickup
    Spent a little time cleaning up the piston tops/air filters (post 5324) w/ 180 grit, then 240 grit. Looking better. Pic shows sanded (left) vs wire brushed (right). I don't care if they are perfect, or even close, but how fine of a paper should I hit them with before letting the wife polish them a little? Not trying to take out all the pits, and don't really want them to look like chrome.
  27. Less than 50 miles. Pissed me off no end. Have heard lots of people say you can use GL5, but, I now know they're wrong when it comes to older 4 speeds. Another thing I noticed... you have to really examine any GL4 because apparently some of the newer blends have included additives that can also damage the sycro's. Just found that out today. Got my eye on some GL-1 now. It's pure mineral oil with no additives.
  28. The alt and PS brackets we made are working out nicely.
    Okie Pete, porkshop, Oneball and 8 others like this.
  29. justabeater37
    justabeater37
    Just wanting to throw things at the love/haTe special as I work through it's issues. At least it's on the road I guess. Lovehate.jpg
  30. gimpyshotrods
    gimpyshotrods
    It certainly does not help that there is so much information being repeated about GL-5.
    People are literally arguing with chemistry, and thus are arguing with the Laws of Physics.
    They will even call the records of General Motors fake or incorrect, and and are perfectly happy to argue with actual Automotive Engineers.
    I don't get it. The solution is just use a GL-4, or lower. It's not like I am telling people they have to pick a limb to amputate.
