Projects Little Runaway
Discussion in 'Traditional Hot Rods' started by 270bob, Feb 11, 2025.
  1. Robdski
    Robdski
    Beautiful!
    270bob likes this.
  2. 270bob
    270bob
  3. 270bob
    270bob
    Thanks!
  4. 270bob
    270bob
    20250518_194908.jpg 20250518_194908.jpg 20250520_181606.jpg 20250520_181612.jpg 20250523_194319.jpg 20250526_201308.jpg
    Thor1, hook00pad, Just Gary and 12 others like this.
  5. 270bob
    270bob
    This is the current status of Little Runaway. I decided to leave her in primer and put her together. 20250526_201308.jpg 20250523_205736.jpg 20250523_194349.jpg 20250525_152507.jpg
    Thor1, Just Gary, Uncle Ronn and 17 others like this.
  6. Tim
    Tim
    from KCMO
    Very nice
    winduptoy, 270bob and Chief 64 like this.
  7. Tim_with_a_T
    Tim_with_a_T
    That's a sweet looking little T.
  8. Grumpy ole A
    Grumpy ole A
    It’s looking good
    270bob likes this.
  9. 270bob
    270bob
    Thanks, I had to make a new upper coolant pipe. The first one only fit the 2×4 intake. That motor wasn't going to be ready in time. Just need to make battery cables, go through the carburetor and run fuel line.
    Thor1, Deutscher, winduptoy and 5 others like this.
  10. Tim
    Tim
    from KCMO
    Brutally close now!
    winduptoy and Outback like this.
  11. WiredSpider
    WiredSpider
    Rob. Your roadster looks great. Nice work.Hope you are well, haven’t seen you in 25 years
    winduptoy likes this.
  12. 270bob
    270bob
    Thanks Steve.
  13. 270bob
    270bob
    Thor1, Just Gary, Outback and 5 others like this.
  14. 270bob
    270bob
    Every car has a story. For me, every part on this car has a story. Some I will share and some I won't. However, the motor has an interesting story. I was having issues getting parts for my original motor, so Dad says, "take this motor and freshen it up till you get your parts. It will require good gas because it has a lot of compression. " He informed me that he bought this motor brand new in 1969 and put it in his 1960 corvette. I ran the numbers on the engine and it is a factory DZ 302. I am running the Duntov 30/30 cam, Edelbrock C4B and Holley carb that he ran. I added the mag and Packard 440 wire, but it is all about the same. Can't wait to here this run. Finally got the brake hoses made the way I wanted them. 20250528_174832.jpg 20250530_160207.jpg 20250530_160219.jpg
  15. Grumpy ole A
    Grumpy ole A
    That is awesome. I guess with that motor you will have an A/Z28, hmmmm?
    hook00pad, Just Gary, Outback and 3 others like this.
  16. ne'erdowell
    ne'erdowell
    This is awesome! That fact that your Dad bought the engine new when they were one of the hottest around and then gifted it to you years later for your roadster makes for a great story. It will be a quick T. Been following this and I now have a similar tale, I sold a car 10 years ago and just bought it back.
    Thor1, Outback, 270bob and 3 others like this.
  17. 270bob
    270bob
    Thanks, hoping to fire it this weekend. I will report back when I do. It was pretty cool freshening up the motor. Ir is standard bore and everything checked out within tolerance. I found the front timing cover was damaged and had to weld up a small hole and fix some dents. Dad said the original plastic timing came apart and that is what the damage was from. The motor has a new double roller in it now.
  18. 270bob
    270bob
  19. ModelAMitch
    ModelAMitch
    Looks great. Great story, great car. Keep the updates coming!
    270bob likes this.
  20. 270bob
    270bob
    See you all in Pomona! 20250611_101143.jpg 20250611_101143.jpg 20250611_101134.jpg 20250611_101207.jpg
    Thor1, hook00pad, Just Gary and 15 others like this.
  21. Grumpy ole A
    Grumpy ole A
    That is an awesome ride you have built. Congrats
    270bob likes this.
  22. Tim
    Tim
    from KCMO
    Awesome! Let’s hear that thing!
    270bob likes this.
  23. dan c
    dan c
    memories...a st. louis guy, rich steyh, had a hemi-powered '27 roadster back in the '70s. when interviewed for the tv news, he always gave his name as "rich stay-high"!
    270bob likes this.
  24. 270bob
    270bob
    Had a great time at LARS, the car worked great too. 20250614_074549.jpg 20250613_102230.jpg 20250613_102137.jpg image000000.jpg
  25. Tim
    Tim
    from KCMO
    Man that thing looks *****in out in the wild!
    mad mikey, 270bob and Robdski like this.
  26. 270bob
    270bob
    I found this video of Lil Runaway driving into LARS, it is at the 1 minute mark in the video.
    Thor1, hook00pad, Just Gary and 2 others like this.
  27. El Hueso
    El Hueso
    How low is your seat? Did you sink it in? It seems like you have a pretty low seating position for a T.
    Uncle Ronn likes this.
  28. 270bob
    270bob
    Great question, I made seat pans so I could sit low. That is why I chose a Deuce frame and shaped it to the outside of the body. I never liked the original seating position and if you use an A or T frame the are directly under your ****, so you end up sitting on top of the car instead of in the car. Thanks
  29. Grumpy ole A
    Grumpy ole A
    That is interesting, never thought about the frame being out of the way for the seat to drop in.
    270bob likes this.
  30. 270bob
    270bob
    Here are a few photos of the seat pan and how you sit in the car. I have a top built for the car and you can see it in the photos too. I found the cartoon illustration in a Street Rodder magazine from 1997. The view from the back of the car is really cool, you can only see the top of the driver's head. I will upholster a traditional roadster bustle and will make it appear as if you are sitting lower in the car. Thanks Resized_20220213_164624 (1).jpeg 20210913_134633.jpg Resized_20220213_164505.jpeg 20210904_101623.jpg 20221223_154734.jpg 20230225_190503.jpg 20230226_182524.jpg 20230504_192842.jpg
    Thor1, willymakeit, Bdamfino and 14 others like this.
