Technical Quiet electric pump?
Discussion in 'Traditional Hot Rods' started by birdman1, May 27, 2025.
  1. birdman1
    birdman1
    Has anyone used the jegs electric fuel pump? The 15901 is advertised as super quiet. I am using the holley blue electric pump and it's louder than the exhaust pipes. Thank you for your help.
    vtx1800 and LOU WELLS like this.
  2. 1971BB427
    1971BB427
    from Oregon
  3. birdman1
    birdman1
    I will try the rubber insulators. If I wrap it in sound proof insulation will it get too warm and damage the pump
    LOU WELLS likes this.
  4. Rally 1
    Rally 1
    Carter P90091
    Quiet, can’t hear run.
    Amazon, Summit,
    Ken
    dogwalkin, das858, OzMerc39 and 3 others like this.
  5. 2devilles
    2devilles
    Do not wrap the pump in anything, it will, as you asked, get hot and burn it up quickly. The Holley pumps are loud no matter what you do or how you mount them, some guys like it, some don't. It depends on what your fuel requirements are for your engine, but any of the cheaper in-lines from auto parts stores are pretty dang quiet if you aren't racing or your engine is fairly mild. If you have something that requires more fuel, the Edelbrock pumps are a lot quieter than the Holleys, although you can still hear them.
    RodStRace likes this.
  6. tjm73
    tjm73
    Mechanical pumps are pretty quiet.
    What engine are you running? How much hp do you think you have?
    OzMerc39, jimmy six and samurai mike like this.
  7. I don’t know what your fuel delivery requirements are, but I’m running a Carter P4070 and it’s very quiet.
  8. pprather
    pprather
  9. Kiwi 4d
    Kiwi 4d
    Ok cool on the carter , I don’t want to hijack this thread ,but a quiet pump to 3 psi? Any thoughts?
  10. trevorsworth
    trevorsworth
    I have an Edelbrock pump on my T that I removed the ugly red plastic case from since I had to mount it on my firewall. Loud as hell with the engine off but it fades away once it's running.
  11. skooch
    skooch
    You know I installed one of those Carter pumps cause everyone said they were so quiet, I must have gotten a dud cause it was LOUD. Mounted it on a big rubber jewelers block. Ended up with a facet pump that I’m very happy with.
    LOU WELLS, OzMerc39 and AccurateMike like this.
  12. clem
    clem
    don’t know how quiet they are, but someone recommended these to me just this week, reasonably priced I was told and a variety of pressure ranges.
    Supposedly stops pumping when pressure is reached, and resumes when pressure drops.
    Close to home.
    Didn’t know they existed.
    https://fuelflow2020.nz/?page_id=184
    Kiwi 4d likes this.
  13. winduptoy
    winduptoy
    I use the Holly 12-246....it is quiet, mounted on the frame and no need for a fuel pressure regulator on the Strombergs with it....in my experience......or
    drive a Roadster and hear nothing over the wind noise....
  14. A Boner
    A Boner
    Sooner or later they all go silent!
  15. Bandit Billy
    Bandit Billy
    Wish that happened with women. :cool:
  16. Bandit Billy
    Bandit Billy
    I have one of those on my dune buggy, very small and very quiet. All the rest of my cars have in-tank pumps, cooler, quieter, and you don't have to look at them. Replacing them can be a ******.
    winduptoy likes this.
  17. I feel for you! Me too.:p:p
    Ben
    427 sleeper likes this.
  18. milwscruffy
    milwscruffy
    I've used one now for a couple years. Definitely quieter than a Holley, super quiet not so much. I do like that it has a built in pressure regulator though.
  19. choptop40
    choptop40
    Running a Carter and I like the sound cause its on the back p*** frame rail...lets me know I'm getting go juice...
  20. You can double up on isolators, pump to bracket and again bracket to frame, dont wrap the pump.
    427 sleeper and winduptoy like this.
  21. Garlic Slinger
    Garlic Slinger
  22. jimmy six
    jimmy six
    Pressure can be your friend or enemy. Most fuel lines are 5/16”. It’s better to have 3/8”. Many use -6 AN which is called 3/8” but not even close when you check the fittings. My stock fuel lines is 5/16” and the pressure is under at 4 psi. and feeds dual quads and in 8 years never ran out of fuel. Granted they are not big carbs but the same as a 245/270 hp Chevrolet 283. I have a Carter and would use before any Holley. I would mount it on “Lord” bushings . IMG_4522.jpeg
    rod1 likes this.
  23. pprather
    pprather
    @birdman1 , which pump did you install?
    Did it meet your expectation?
  24. 57JoeFoMoPar
    57JoeFoMoPar
    I run a 4070 as well and it seems quieter in my 56 than in my 61, oddly enough. I think it matters where it is mounted, as well. I don't mind a little noise, a nice reminder it's working
    57Fury440 and Just Gary like this.
  25. Kerrynzl
    Kerrynzl
  26. 29Sleeper
    29Sleeper
    from SoCal
    I wonder if it will live with ethanol fuel?
