Projects Poly begets a Hemi begets a Model A
Discussion in 'Traditional Hot Rods' started by wstory, May 21, 2020.
  1. 40ply
    40ply
    Beauty Bill! That's a work of art.
  2. pprather
    pprather
    VERY impressive!
  3. rockable
    rockable
    Damn, Bill! There aren't many fabricators who could or would tackle that job! Cong!
  4. 73RR
    73RR
    ...Bill is now, officially, in the snake charmers Hall of Fame....
    warhorseracing, panhead_pete and Tim like this.
  5. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    Brings to mind this:
    Deutscher, Outback, brEad and 5 others like this.
  6. wstory
    wstory
    from So Calif
    Got the "snakes" back from the media blaster. Obviously the surfaces look more homogenous now. Unfortunately the tasty bronze TIG weld beads, done by my friend Mike Hight, can't be appreciated after stuff is painted. :(
    As previously mentioned, paint was to be the short term coating solution. I decided to experiment with layering available colors because I didn't care for any of the HI Temp options.
    The "Copper" turned out to look more like chocolate :eek: However, the following "dustings" of Black and Silver got me closer to an acceptable color for the near term.
    Next is to decide which "sub project" to tackle next. Steering, pedal ***embly front end, cooling and fuel delivery all need to be figgered out. I've discovered a local guy who says he can spec a side draft carburetor adequate to feed 270 inches so I may decide to address that next. But,....I gonna sleep on it ;)
  7. That spray bomb blend looks great Bill!
    PoTaToTrUcK likes this.
  8. warhorseracing
    warhorseracing
    from cameron wv
  9. brEad
    brEad
    The color on the exhaust looks great!
  10. wstory
    wstory
    from So Calif
    Here's a little more on color. Interestingly the hue changes from a smokey grey to copper depending on the lighting and angle. Kinda fun tho most of that goes away when installed.
    I'm about to bolt this stuff on for the last time and get on with the next phase.
    das858, Deutscher, Outback and 11 others like this.
  11. 340HilbornDuster
    340HilbornDuster
    That's a Snake Pit for Ya...
    FYI - I ran that "Bronze BBQ paint on my pipes"
    1. Looked more like Dog Poop than Bronze.
    2. Burned of after a while...(Note still tuning)
    Again Awesome job!
    Outback, loudbang and brEad like this.
  12. warhorseracing
    warhorseracing
    from cameron wv
    No one can claim this is a belly ****on build. NO ONE. With the work that you have put into this build it could become a museum piece or a trailer queen. But I am betting it will be neither.
    Nailhead A-V8 and rockable like this.
  13. wstory
    wstory
    from So Calif
    Duster,....I understand the challenge of start up and tuning re exhaust temps. Were you able to "cure" the paint before running the engine in normal service? I have seen even expensive High-Temp coating ruined on startup as the initial curing routine could not be followed.
  14. 340HilbornDuster
    340HilbornDuster
    Cure Routine...?
    I sprayed it the day B4 the Garage Shoot...LNSPBLVD
    Maybe i should read the instructions?
    Those 180's supposed to sound really cool!
    Are You using a special "180" cam or?
    Aloha Tommy
  15. winduptoy
    winduptoy
    I've just let them sit in the hot New Mexico sun seems to have worked just fine for curing the paint
    Outback likes this.
  16. Dick Stevens
    Dick Stevens
    Only if you want good results! :rolleyes::rolleyes::rolleyes:
    Outback likes this.
  17. wstory
    wstory
    from So Calif
    Thanks windup. I'm trying just that. 90+ here in socal today.
    Outback, winduptoy and warhorseracing like this.
  18. wstory
    wstory
    from So Calif
    Also thinking "heat lamp".
    Tim and warhorseracing like this.
  19. j hansen
    j hansen
    Or,,,
    Outback likes this.
  20. wstory
    wstory
    from So Calif
    Finally, finally,....as previously mentioned, ad nauseum, :eek: I've spent an inordinate amount of time stressing/fussing with details,...like the color of the headers and the configuration and details of fittings. Finally got what I was after 'tho with a few redos. Did several rounds with Summit in order to get oil lines compatible with the fittings I'd selected. Struggled with cutting those S.S. shielded hoses. I had to unbolt the oil filter bracket in order to provide wrench clearance to cinch down the oil lines. Finally DONE! I just wonder what the next guy who owns this car will think when he has to work on some of these ridiculously tight placement of components. thumbnail 76.jpg thumbnail 68.jpg thumbnail 70.jpg thumbnail 73.jpg
  21. 40ply
    40ply
    He's going to think that this build was damn well done! Nice work Bill! Plus the big auto manufacturers never worry about the mechanics when their placing components anyway.
  22. pprather
    pprather
    The Sharpie arrows on the oil filter in and out will not be visible, as a reference, once the body is installed.
  23. continentaljohn
    continentaljohn
    Amazing build and Craftsmanship is off the charts!
    Nailhead A-V8 and winduptoy like this.
  24. Givhar
    Givhar
    I’ve been lucky enough to see this manifold project progress through the different stages in person. I am such a borderline Hot rod guy, (even owning but mostly driving three of them), that I hesitate to make a comment. I have been in awe at every stage as I’ve watched this project develop. It’s just spectacular. I’m excited to see what happens with the next sub project. See you Monday morning, Bill. Congratulations on finishing this stage.
  25. winduptoy
    winduptoy
    They are for the oil to know which way to go when they get to the round-a-bout
    pprather likes this.
  26. ekimneirbo
    ekimneirbo
    from Brooks Ky
    That's what makes you a fine craftsman...........Well done, keep up the good work.:)
    PS: If you get a silver colored sharpie you can mark the hose fittings so you know which hose goes where. It may be that your hoses length makes that obvious, but if not the silver marker will help. Not joking, I'm being serious. I use the silver ones in my shop on all kinds of things that are dark colored.:D
  27. wstory
    wstory
    from So Calif
    May be naive of me but I figger once they're hooked up, I'll never need to know which is which :eek: ;)
    Currently starting detail and ***embly of the front end,...tho nothing to show for a few weeks as a couple dozen of my closest friends are invading Northwest Deuce Days in Victoria, BC before cruising and drinking our way thru a scenic loop North and East before returning to the border in another week.
    I and others, I hope, will post on our CanAm Curmudgeons thread.
  28. wstory
    wstory
    from So Calif
  29. Dick Stevens
    Dick Stevens
    Looks like a great time with like minded friends!
    winduptoy and anothercarguy like this.
