10 second 1/4 for 10 grand?
Discussion in 'Off Topic Hot Rods & Customs' started by Logan79vette, May 28, 2025.
  1. Sounds like you're young and havent really experienced what a 10 second rip feels like. Find someone local with a 10 second street car and go for a ride with them. This will convince you real quick (like, in less than 10 seconds) if you really desire a 10 second car. Going that fast can really humble some people, and make them reevaluate their goals.
  2. twenty8
    twenty8
    .... and while you're there, ask the guy to tell you honestly how much it cost to get into the 10's. It might surprise you.:eek:
    427 sleeper, SS327 and TexasHardcore like this.
  3. swade41
    swade41
    from Buffalo,NY
    First time in a fast car might just give you some ****erflies in the ol stomach, then after about the 3rd p*** it's all back to normal and you lose the feeling unfortunately lol
    I anticipate that feeling again with my new combo in the Henry J, hell it's been 12 yrs since I've been down the track.
    rod1, 427 sleeper, porkshop and 2 others like this.
  4. I feel ya, it's been almost 10 years for me and that was an 11.70 all motor, stick shift, drag radial p*** in my old foxbody coupe. My F-100 will easily be double the horsepower of that car, so I anticipate similar ET's due to the weight and gearing differences. I also would rather be surprised by a faster than expected ET, than let down with a particular number in mind and it doesn't meet that goal.
    Logan, that Corvette will run 10's easily with the Big Block and a healthy dose of nitrous. You'll just need to make sure everything else on the car can handle that kind of torture.
    rod1, 427 sleeper, twenty8 and 2 others like this.
  5. Logan79vette
    Logan79vette
    Will do, just wanna ask if theres any options for a more daily friendly rear end set up beside a solid axle?
  6. SS327
    SS327
    Nope. You’ll break u joints, twist axle shafts and snap pinion gears if you keep the IRS. By the time you make the IRS strong enough to hold up you will have as much money into it as the engine that did the damage.
    porkshop, 427 sleeper and squirrel like this.
  7. Logan79vette
    Logan79vette
    Okay, I'll start looking into the setups of some other 9-11 second vettes and see what I find out
    porkshop, 427 sleeper and swade41 like this.
  8. RodStRace
    RodStRace
    There you go! I will mention that a lot of racers don't disclose every broken part and most won't total up costs. Even with a good program, expect breakage and money burning up.
    porkshop, 427 sleeper and SS327 like this.
  9. Logan79vette
    Logan79vette
    Everything cool is expensive!
    porkshop and 427 sleeper like this.
  10. squirrel
    no, not everything cool is expensive. I built this car for $15k, it was pretty cool
  11. Logan79vette
    Logan79vette
    Yeah well you also seem like the resident master builder
  12. twenty8
    twenty8
    And that's how the $10k mark comes and goes. You either spend it making everything strong enough to be trouble-free, or you eat it up quickly by constantly fixing things that break.
    The secret is to be able to do most of the work yourself, and to count your labour/time as free, like @squirrel does.
  13. Logan79vette
    Logan79vette
    That's the plan, I'll be checking on here everyday and update on anything I've done or found out
    porkshop and Dick Stevens like this.
  14. 6sally6
    6sally6
    HA........never noticed the Schlitz over flow can !
    Cl***y......!
    6sally6
    I had a Colt 45 can.....
  15. oldiron 440
    oldiron 440
    I believe it would be hard to go 10s for less than 15 to 20k if you didn’t have the talent for horse trading, bartering and doing your own work, I think you would need some dumb luck also.
    porkshop and SS327 like this.
  16. Logan79vette
    Logan79vette
    Well I'll keep everyone updated on my costs and progress
    porkshop likes this.
  17. swade41
    swade41
    from Buffalo,NY
    I didn't have that much into my Henry J, and it went 7.0's which is like an 11.0, with the pump gas tunnel ram 383 sbc. On paper it should've went 6.90's, but that's why we don’t race on paper.
    rod1, porkshop, 427 sleeper and 3 others like this.
  18. squirrel
    I don't think so, there are a whole bunch of really good builders here. It's more a matter of figuring out what the requirements are for the car, and how to meet those requirements with the least cost. Basically, it's called "engineering". Yeah, I went to engineering school, but I also did my first big block engine swap while I was in high school, mostly using info from reading magazines (there was no youtube in the 1970s, you know)
    Most guys get into the habit of thinking that the only way to get go-fast parts is to buy the stuff that everyone else buys. There usually are a lot of different ways to do things. Just gotta be creative, and do some research.
    But learning to make stuff, or make other stuff work, is an acquired skill. And it's acquired by doing, not watching.
  19. oldiron 440
    oldiron 440
    If you’re just starting out I would recommend setting your goals more realistic say low 13 high 12 second ETs and then start running your car making changes to improve your ET. You will gain valuable experience and knowledge about modifying your car and running on the track. After you learn how to dial your setup and your self then you can reevaluate your setup and determine what it will take to make your goal of running tens with the same vehicle. You can look for a vehicle with less weight and maybe is even setup to run the numbers you want or quicker. And I can’t say that I have ever met a drag racer who didn’t want to run faster. Sometimes you can find a race car for sale without the engine/transmission for a hell of a deal and transplant your current power train or start fresh getting to the ten second quarters much easier.
  20. twenty8
    twenty8
    How many $$$ are you in already? What did you pay for your 'vette? How much of the $10k do you have left?
  21. RodStRace
    RodStRace
    @squirrel you are too modest. ABone knocks out model 40s at a fast clip, Marty Strode builds beautiful stuff, but I think you are the most prolific street/strip builder on here. Chevy II, the cuda AWB, the vette, and now the Jeep. I didn't include the Checker because it was street. Who else has 4 in that time?
  22. squirrel
    And you didn't include my old truck or my 55 chevy, where I learned most of the stuff I know :) but they go back a long time. I'm pretty slow at getting going (with the usual excuses of having work/family to deal with a lot back then).
    I've seen a lot of neat cars on the hamb, there are definitely a lot of talented guys here. They don't all post what all they're doing all the time, though.
  23. swade41
    swade41
    from Buffalo,NY
    I believe he has a budget of $10k to spend on the vette, not $10k total starting from scratch without a car.
    One thing that hasn't been mentioned is if you are running at a sanctioned (NHRA/IHRA) track you will only be allowed to run so fast without the addition of safety equipment. The faster you go the more safety you need, it would be wise to find a rule book and highlight the areas that pertain to you and what you want to do.
    I believe the current rules are, now these are abreviated not the actual rules, just to give you an idea
    14.00 seconds you need a helmet
    Drive shaft loop if you run slicks
    Fire extinguisher
    13.50 = Rollbar (4-6 points) in convertibles
    11.50 = Rollbar in everything (if you haven't altered the floorpan)
    10.00 or 135+mph = Rollcage, License
    150 mph+ = Parachute
    8.50 = Serious Rollcage
    porkshop, Dick Stevens and RodStRace like this.
  24. RodStRace
    RodStRace
    Shouldn't need to move the battery, those being behind the seat, but a cutoff switch might be a good idea, too.
    Belts at 12.0? Can't remember, but also good to plan for.
    Coolant overflow, clutch can(?), fuel line routing (most stock stuff isn't good for 10s).
  25. squirrel
    The roll bar requirement is 5 points, I know because I just built one a couple days ago. Main hoop, two rear down bars, one door bar on driver side. Has to be welded to the frame on any car that has a frame. This is kind of impossible to do on my soft top equipped 62 Corvette and keep the top working, but a later T top should be possible, but it will be tight and difficult to install.
    racing harness is required if you have a roll bar or cage, otherwise OEM or similar seat belts.
    The battery cutoff switch is required if you relocate the battery, or run faster than 10.00. But it would be a good idea to add it, having the battery located in the p***enger compartment. Also for safety, look at venting and the battery hold down hardware, they usually like to see 3/8" bolts going through the frame or other steel support.
    porkshop and RodStRace like this.
  26. RodStRace
    RodStRace
  27. squirrel
    having a street car go that fast is a whole different ball of wax :)
  28. RodStRace
    RodStRace
  29. twenty8
    twenty8
    The very first post in this thread references @squirrel 's 9's for9k thread, which includes the initial cost of the vehicle.
    Guess that was not the intention here.
    porkshop and squirrel like this.
  30. Dick Stevens
    Dick Stevens
    Well, you know what they say about making ***umptions :rolleyes::D
    porkshop and twenty8 like this.
