Projects 32 Sedan new to me
Discussion in 'Traditional Hot Rods' started by Barn Hunter, May 30, 2025.
  1. Barn Hunter
    Barn Hunter
    I've known about this car for years. It was in a local private collection and recently became available. I just got it home yesterday. Overall pretty nice, painted 40 years ago, complete with a 25 louver hood. No plans ... just going to clean it up and we'll see. I do have a few questions. The car hasn't been run in about 6 years. I'm sure it has been discussed here time and again but I don't want to damage the engine so to play it safe I imagine I could shoot a little marvel into the cylinders. Anything else to do or look out for, please let me know. Is this long enough for gas to go bad? I don't have the original crank handle. Seems like it would be the easiest way to turn the motor over. Has anyone created a replacement handle? I'm sure I'll have more questions, but thanks in advance for your ideas. 20250506_120713.jpg 20250507_121103.jpg
  2. NoSurf
    NoSurf
    Sweet!
    I like PBlaster for freeing stuck stuff. Try and get the tube/nozzle thing up into any open valves inside the spark plug hole.
    The 59L in my coupe was stuck when I got it.
    Tow Truck Tom and Barn Hunter like this.
  3. Barn Hunter
    Barn Hunter
    Thanks....I'm not saying it's stuck. Just want to protect the cylinders when I turn it over by hand.
    Tow Truck Tom likes this.
  4. alchemy
    alchemy
    Gorgeous sedan! Drain the gas and oil, and replace. Squirt the Marvel as you said. I doubt it will fire off right away, so crank it a bit to get the new oil circulating.
    Before you drive it, check fluid levels in the radiator, trans and rear, and check the brake rods for looseness.
  5. Tow Truck Tom
    Tow Truck Tom
    from Clayton DE
    Winner winner... I dig not messing it. Just detail it.
    Marvel Mystery in the plug holes is also wise, I 'd prefer more than a 'little'.
    Some more in the gas tank........ But FIRST I'd like to see the tank drained.
    ( just sayin' that PB stuff when first out, affected my lungs no-go for me )
    Speccie, Barn Hunter and NoSurf like this.
  6. HOTRODPRIMER
    HOTRODPRIMER
    Nice car and a 25 louver hood to boot! HRP
  7. Rickybop
    Rickybop
  8. ironandsteele
    ironandsteele
    Beautiful Sedan.
    I would definitely pull the plugs, oil the cylinders, let them sit and rotate the motor a few times before I started it. Draining the tank and cleaning out the fuel system first is also a great idea. I'm in the process of doing that now too, also on a '32 Sedan that's been sitting, coincidentally.
    That's a gorgeous car, enjoy it!
    ironandsteele.com​
  9. Kiwi 4d
    Kiwi 4d
    The gas will be bad. Take the cap off but don’t get your nose too close. You want to give it every opportunity to fire off easily, dump the fuel and flush the lines. Checking for aged lines also.
    leon bee and Barn Hunter like this.
  10. Barn Hunter
    Barn Hunter
    Thanks...would love to see pics....
  11. bushwacker 57
    bushwacker 57
  12. ironandsteele
    ironandsteele
  13. 19Eddy30
    19Eddy30
    from VA
    Nice Sedan , should clean up Nice .
    Mine Apple Green & Dark Green on Fenders .
    For Hand crank , I think you could make a tool , rod & pin , extension with a pen.
    Like others said after soaking cylinders
    You could put in gear rock back & forth
    My F-H I was able to turn over by hand
    The Belts , crank with out plugs in .
    Barn Hunter likes this.
  14. 51 mercules
    51 mercules
    Nice!Congrats!
  15. Barn Hunter
    Barn Hunter
  16. Barn Hunter
    Barn Hunter
    Thanks for the tips and compliment!
  17. leon bee
    leon bee
    Start her first out of a clean can.......don't want any of that old gas circulated.
  18. Barn Hunter
    Barn Hunter
    Wiped the dust off and a spritz of shine and it's looking better. Ordered plastic squeeze bottles with a curved tube so I can shoot Marvel to the top of the cylinder wall. Should be here by tomorrow. 20250602_145127.jpg
  19. Barn Hunter
    Barn Hunter
    A flathead question...this is in the 32. According to a little research, these heads are probably 1933-35. Could the block be 32 with later heads? I've also heard that some late 32 V8's were fitted with the 33 flathead. Anyone know about that? 20250608_121410.jpg 20250608_121504.jpg
  20. vintagehotrods
    vintagehotrods
    Look at the bottom of the block in front for the drain pet****s. If they point straight down, it is a 1932 block. If they point toward the outside, it is a 1933 or later block. The intake manifold is at least 1934 or later, as this was when the 2 barrel carburetor was introduced.
    Barn Hunter and Just Gary like this.
  21. HOTRODPRIMER
    HOTRODPRIMER
    The '32 V8 engine also had a aluminum oil pan. HRP
  22. 29Sleeper
    29Sleeper
    from SoCal
    I spray/fog in WD40 rather than dumping oil in that only lubes the lower parts of the cylinder. When it first starts, don't forget the cam, lifters and valve stems have been sitting and dry so you'll want to get the RPM up right away to get the oil misting around and those protected.
  23. Barn Hunter
    Barn Hunter
    Thank you. The pet**** does point towards the outside, so 33 or later.
  24. Barn Hunter
    Barn Hunter
    It is a steel oil pan. Thank you. Also pointing to 33 or later.
