Technical What are you working on?
Discussion in 'The Hokey Ass Message Board' started by Lloyd's paint & glass, Jul 18, 2022.
  1. Sharpone
    Sharpone
    I’d go at least 400 , 600 wold be better IMO
    Dan
  2. gimpyshotrods
    gimpyshotrods
    Love the wheel covers!
    porkshop, Sharpone and deathrowdave like this.
  3. snoc653
    snoc653
    from Iowa
    Trying to figure out the one person engine/trans pull on the 51 Styleline. Everything is disconnected but when I lift the engine the trans presses down on the crossmember and won’t slide forward. Not sure if I can jack the trans up and slide forward and clear the firewall.
    porkshop and Sharpone like this.
  4. RockyMtnWay
    RockyMtnWay
    After enough miles of shakedown it’s time to find and fix all those little nits that popped up. Never have two builds that work out the same even if they are basically the same type of hot rod.
    The Tudor is no different, so when it was time to take the grille shell off and pop in a freshly painted insert (black this time), it was time to see if anything shifted.
    Sure enough, the rad had wandered west a bit so it was time to invent a solution.
    Repositioned the rad and drilled some holes through the rad feet, spacers, rubber and the front cross member. Then made a couple little positioning pins welded to some washers that won’t interfere with the rad flex springs and re***embled everything.
    Worked out well and really like the black insert.
    Bonus is that the hood fits great again.
    Spring looks tight, but left space in each coil.
    Have to do a little paint touch up now. Boo
    Okie Pete, GuyW, porkshop and 8 others like this.
  5. choptop4
    choptop4
    Rebuilt the WCFB. It was bad.
    Now on to the 39 transmission. It's bad to ! Anybody have a 29 tooth cluster gear ?update on the trans, not one usable part! Only the case.
    20250526_103058.jpg 20250526_100437.jpg 20250528_170237.jpg 20250529_113316.jpg
    Okie Pete, porkshop, swade41 and 10 others like this.
  6. HOTRODNORSKIE
    HOTRODNORSKIE
    Still waiting for my olds 303 pistons from Tony a year and counting so I decided to polish the fairlane today and take it for a short shake down drive. Picked up this dual action buffer of the Mac truck it's basically a Dewalt painted red works good but the car wears about 85% of its original paint so a guy has to be careful. 20250531_123156.jpg 20250531_123128.jpg 20250531_123218.jpg
  7. J. A. Miller
    J. A. Miller
    from Central NY
  8. sidewayzz69
    sidewayzz69
  9. FrozenMerc
    FrozenMerc
    The final machining is nearly complete on the first 2 MEL / 6-71 Intakes.
    Paul, Okie Pete, BigRRR and 12 others like this.
  10. Bandit Billy
    Bandit Billy
    Pits are ok and add some interest, but you need to lose the sanding scratches. I take metal to 3000, 5000 if I am show polishing. The more time spend sanding, the less compound and effort to polish.
  11. Bandit Billy
    Bandit Billy
    What do you have the nigh beam holes?
  12. snoc653
    snoc653
    from Iowa
    Well today I finally found out how to get the engine and transmission out of the 51 with just one person. As a local rider explained to me after stopping him to admire his OT 39 Ford, “you don’t pull it, you have to cut the transmission mount out “ it falls down in the back and will slide out. The stock mount apparently doesn’t fit the 700R4 and needs removed anyway.
  13. jamesgr81
    jamesgr81
    What am I working on? What ain't I working on? Just wish I could concentrate on just one project.
    Number #1 is trying to finish my 1939 Chevy coupe. Been sitting too long and I'm so close. But.....
    Tommorow morning I'm gonna look at a 1970 Chevelle complete. No motor or trans but they say body good and no rust. Don't really need it but price is right. Build a SS454 clone or as they say on Barrett-Jackson, a re-creation.
    Just picked up a 1971 El Camino, runs and drives fine, but paint is faded, probably flip it.
    Also recently got a non-Hamb friendly 2005 GTO. Guy was desperate for money so I got it cheap. Runs good, and is fast. Seats are thrashed. We'll see.
    Want to get on my 1953 Chevy truck pickup. Super original but don't dig the babbit pounder or 45 mph on the freeway. Putting in a 454 and TH4oo that I acquired. Have all the parts too.
    Get my Meyers Manx on the road. Relocate oil filter and go.
    Fix the burst fuel line on my 1967 El Camino with LS motor.
    My 1970 Corvette is done but needs TLC.
    Get my drag racing car out and ready for some fun. 66 Nova with 434 SBC runs 9.50's.
    Haven't done didly on my 1969 Chevelle SS396 resto project. All complete but in pieces. I call it my retirement project.
    My baby, my 1956 Chevy Del Rey, has a 540 BBC but Richmond 5 speed shifts terrible. Don't ever buy one. Wanna put in a TKX. Super fast car.
    Never been a low and slow guy. Always about engines and hauling ***. Toned the latter down in my old age. But lead sleds, deuce coupes, customs and shorts, love 'em all.
    Did I forget anything....
  14. BigRRR
    BigRRR
    I finally finished up a Vat60 project. In the end it only needed a thorough cleaning, a little paint, and a new indicator light - Axman Surplus, for the locals, came through once again! Tested a couple of batteries for fun :)
  15. Got the ****** kit and rebuilt the T-10. Got my cast aluminum oil pan and had a problem with the fel-pro gasket. No way will the bolts pull down the gap. Turns out, I'm not alone with this issue, so now I'm waiting on a Mr Gasket pan gasket. Still made in America I've discovered, not like Fel-pro is pushing these days.
  16. HOTRODNORSKIE
    HOTRODNORSKIE
    When my brother bought the car in 77 he painted the bulbs in that smoke colored window tint .I will leave them like that to honer his memory every thing else I want the way the late Jim Getts built it in 64.
  17. saltflats
    saltflats
    from Missouri
    Got the power glide back together and spent so time on the 62 Biscayne project. Got the clutch, ****ter shied, transmission and shifter installed.
    Okie Pete, rod1, swade41 and 14 others like this.
  18. earlymopar
    earlymopar
    #4.jpg Just completed camshaft break-in on my new engine.....
  19. That's a poly, right? Tell us about it, the blower, intake manifold, etc. What's it going in? How did you come across it? You've got my interest and attention!
  20. earlymopar
    earlymopar
    Yes, 1963 Poly built to the following specs for my 65 Dodge Utiline SWB pickup. The intent was to have a fairly mild, stock-stroke engine that could put out decent HP and still have good manners and mileage.
    - .030” over on 1963 Poly block yielding 323 cubic inches
    - Decked to yield .015” piston to deck clearance
    - Align bored
    - All rotating parts Dynamically Balanced
    - Crankshaft re-ground to .010” / .010”
    - Sealed Power CP series Rod & Clevite P series Main Bearings
    - **** I-beam connecting rods
    - NOS TRW Forged Pistons (L2270F), increased valve relief diameter and depth for 1.94” intake valves and increased lift
    - SpeedPro E178K Moly Rings
    - OEM camshaft reground by Oregon Cams to:
    224/224 @ .050”, 270/270 adv, .470”/.470” lift, 112 sep (Lift = .499" with 1.6 rocker change)
    .022”/.022” lash hot
    int open 0 btdc close 44 abdc
    exh open 44 bbdc close 0 atdc
    0 degrees of overlap @ .050”
    - Heads:
    o Re-surfaced to achieve 30RA or better surface finish for Cometic MLS gaskets
    o 1.94” / 1.60” Pro-Flo stainless valves / Comp 747-16, 10-degree locks / Comp 614-16 (+.050” offset Retainers) , .060” lash caps on Exhaust valves
    o Schneider Valve Springs # 68044, 125 lb. seat / 310 lb. open (break-in were Comp # 942-16 springs)
    o OEM rockers, Rebuilt, bushed and modified by Rocker Arms Unlimited to 1.5 and 1.6 ratios (1.5 Intake / 1.6 Exhaust)
    o New hardened rocker shafts, new ARP 3/8” – 24, 12-point adjuster screws and nuts
    o Teflon Positive Valve seals
    o Gasket-matched and Ported
    o Cometic .040” head gaskets
    - Smith Brothers push rods
    - FlowKooler water pump #1701
    - Summit Racing billet gears and double roller timing chain set
    - Howards Cams Direct Lube (EDM) solid lifters
    - High Volume Melling Oil Pump w/custom pickup to fit modified Chrysler Marine oil pan (7 quart capacity)
    - Weiand 7503 (original Weiand prototype manifold, modified by owner for supercharger)
    - Carter Compe***ion 625 CFM 4 barrel (9636SA), manual choke
    - NOS Carter street / strip mechanical fuel pump
    - Ford 302-351 Headers w-custom Poly head port adapters designed and machined by owner (not shown in the break-in picture)
    - Pertronix Distributor (for now)
    - Magnuson 112C supercharger
    - 440 Source billet steel flywheel w-SPEC stage2 clutch
    - TKO 600 5-Speed
    - 7.8 Static Compression Ratio / 10.0 to 10.9 : 1 Compression ratio with 6 PSI boost depending on formula used (cranking pressure 136.6 psi)
    Yielded 461 HP per Performance Trends software (which is usually within 2-3% of dyno runs based on replies from several pro engine builders on the Speed-Talk website. I have also made provisions in the intake manifold to spray water or water-methanol to cool the charge if needed which might yield a bit more with timing changes.
    Okie Pete, enloe, rod1 and 7 others like this.
  21. Sharpone
    Sharpone
    Nice very nice
    Daniel
    enloe and deathrowdave like this.
  22. saltflats
    saltflats
    from Missouri
    Went to lend a hand on my friends race car to see if we can find something wrong with it not wanting to run out the big end of the track. His last outing he did a proper plug check with some new plugs and it shows running rich in the back half of the engine and little lean on the front half. I also noticed that the front two cylinders the spark plugs show posable detonation. I took both carburetors apart but didn't find anything that looked out of place. I added a little more jet to the front carburetor. Checked timing and it is at 38 at idle and goes to 36 with more rpm that seem a little odd. I didn't want to make anymore changes until we can get to the track be have a better chance of tracking what we are doing.
    #1
    #2
    Okie Pete, enloe, loudbang and 5 others like this.
  23. EarlyMoPAR, that is an absolute jewel of an engine. Thank you for the thorough rundown explaining each element and the precision invested in making this poly what is possible. The basic engineering was always in this engine's design but you've unleashed a lion by careful machining and ***embly, and some clever creativity in several places. Thanks for the treat for us old MoPAR fans.
  24. swade41
    swade41
    from Buffalo,NY
    I started the wood for the 57 pickup, sanded it out then stained the bottoms first to try and figure out what I'm doing. I need to wipe it off sooner so it's not so dark, first board (far left) was at 20 minutes, then I went to 15 minutes on the far right.
    These 4 were at 10 minutes
    While taking a break I caught this thing looking at me
    Okie Pete, Robdski, enloe and 7 others like this.
  25. earlymopar
    earlymopar
    You are welcome osage orange. It has been a lot of fun but also slow (and discouraging at times due to errors made by both the shops that did the block machining and cylinder head work). I gained a big respect for these engines when my dad bought a new 59' Plymouth Sport Suburban 9-p***enger station wagon, We moved to Oregon in 1960 and that car received a lot of use and never once had issues. So when I got my pickup 12 or so years ago, the first thing I wanted to do was to put a Poly engine in it, so that started the process for me. The Poly was an "option" in the truck when ordered but mine came with a slant 6 and 3 on the column like many did.
    lippy, Okie Pete, enloe and 4 others like this.
  26. LOU WELLS
    LOU WELLS
    from IDAHO
    DSCN0691.JPG Yet Another Rusty Ford Flathead Arrived To Be Cross Examined.....
  27. milwscruffy
    milwscruffy
    Gave my wagon new shoes and stance, also a little clue this ain't your grandma's wagon. IMG_3421.JPG IMG_3422.JPG
  28. enloe
    enloe
    from east , tn.
    Changed the break in oil and topped off the radiator. I also tightened the collector bolts. Ready to head to Bowling Green this Wednesday morning.
  29. choptop40
    choptop40
    Replacing the heavy wood garage door springs...One snapped this winter .Found out they have to be rated to the weight of the door and are color coded ..That F*ckin door is a bear unsprung..
  30. snoc653
    snoc653
    from Iowa
    Be extra careful. Some of those door springs are dangerous. Between being wound tight, door weight, and being on ladders you can get hurt in a blink working on them.
