Technical Aluminum Intake Repair 409
Discussion in 'The Hokey Ass Message Board' started by BOSTONCAMARO, May 30, 2025.
  1. I have a line on a small port 409 intake that I need for my 348 build.
    Seller said ran, no issues but water p***ages pretty concerning. Think a professional could weld this up and then I could rework it?
    It is cheap, do I buy and fix or spend all the money on a much cleaner one?
    I have done a ton of welding but have not set up my
    tig yet, so likely just bring to have it fixed.
    SS327 likes this.
  2. warhorseracing
    warhorseracing
    from cameron wv
    That could be welded up after a thorough cleaning. But, how rare are they because it may be cheaper to find a better one if it exists?
    BOSTONCAMARO and dana barlow like this.
  3. trevorsworth
    trevorsworth
    I don't think I'd have any compunctions about just running it, but that could be repaired inexpensively.
    BOSTONCAMARO likes this.
  4. deathrowdave
    deathrowdave
    from NKy
    Clean it , clean it again , weld it up and mill it back smooth . No mill grinder and hand file . Carefully
    BOSTONCAMARO, SS327 and Onemansjunk like this.
  5. Aluminum spool gun
    carefull file work
    done
  6. BJR
    BJR
    There has got to be better ones out there that cost less than fixing that one.
  7. 2OLD2FAST
    2OLD2FAST
    from illinois
    IF , you do your own work , wouldn't cost much more than time to repair that , how much do you value your hot rod time at ?
    Algoma56 and BOSTONCAMARO like this.
  8. I do a lot of welding, tig is not set up yet so would farm this out to be welded. Intake is a couple hundred, a real super clean one is a grand so that is what I am wrestling with.
    bschwoeble likes this.
  9. 69fury
    69fury
    from Topeka
    Easy fix for a competent welder. I wouldn't give it a second thought.
    -rick
    BOSTONCAMARO and anthony myrick like this.
  10. Recently welded an intake with a spool gun
    Liked it better than TIG.
    Not the look. It just stacked up material faster.
    BOSTONCAMARO, Algoma56 and 69fury like this.
  11. boxerdog
    boxerdog
    I'd avoid it, there are plenty of good ones out there. The Edelbrock small port 1x4 is available new and possibly used somewhere and will work far better that any GM intake. You might also find some older Offenhauser intakes out there, depending on what you want.
  12. Taboo56Chevy
    Taboo56Chevy
    IMG_5205.jpeg I would keep looking, we just scored this absolutely mint big head dual quad 409 manifold for 400 bucks at the Portland Swap meet for the 409 we are putting together.
  13. Moriarity
    Moriarity
    SUPER MODERATOR
    I don't think Chevrolet ever made a small port alum manifold for a small port 409. I do know that they made one for a 348 though. how about a picture if the whole manifold?
    Edit, Apparently there was a small port alum 409 manifold in 1961... my mistake, carry on
    BOSTONCAMARO and boxerdog like this.
  14. 34Phil
    34Phil
    couple CI ones on Ebay now for $200 but ck 3 carbs for $120
    Deuces likes this.
  15. warhorseracing
    warhorseracing
    from cameron wv
    Since it is just a coolant p***age and the manifold was "running good" there are epoxy's out there that are heat resistant. Check into even J B Weld as an alternative to welding since aluminum welding appears to scare you. That would even be cheaper than another manifold or farming out the welding.
    Deuces likes this.
  16. Jmountainjr
    Jmountainjr
    The biggest issue with welding cast aluminum in general is getting all of the contamination out of the porous material. And improper cleaning methods can contaminate the material as well. The bulk of the cost if you farm it out for welding would be the labor to clean. If you were able to do the cleaning you would be far ahead. Cleaning it yourself and using an epoxy repair should be something you can do. Cleaning for epoxy is more forgiving than cleaning for aluminum welding.
  17. junkman8888
    junkman8888
    Frankly, I'm all about learning new skills, if that means I have to buy a new tool, take a cl***, or watch a lot of youtube videos, so be it. Embrace the challenge.
    BOSTONCAMARO and Deuces like this.
  18. The MIG spool gun process doesn’t have to be as clean as TIG.
    great when you need to stack material
    warhorseracing and BOSTONCAMARO like this.
