9s for $9k
Discussion in 'Off Topic Hot Rods & Customs' started by squirrel, Mar 18, 2025.
  1. Johnboy34
    Johnboy34
    from Seattle,Wa
    A confidence builder none the less!
  2. noboD
    noboD
    Squirrel is my hero.
  3. RodStRace
    RodStRace
    If the post with figures didn't convey it, He's my hero too.
    The 60 foot time shows it's not launching, which given first time out, basic sorting still to be done, high CG, short wheelbase and small tires, tracks.
    The quarter time and speed match. I'd expect a turbo to pull harder in the second half. There's a lot left here even with safe fuel and timing. Better to sneak up on this, who knows how it will handle laying down big power (high, short WB).
    So for a first time out getting used to it, and still not dialed on tune and traction, I'd say his goal of 9s is possible, with maybe a bit of work on the suspension and tires. There will be other things that pop up, there always is.
    EDITED
    Posted
    60 Foot 1.81
    330 Foot 4.86
    660 Foot 7.37
    660 MPH 97.81
    1000 Foot 9.56
    1/4 Mile ET 11.44
    1/4 Mile MPH 116.67
    Goals 9.99
    60 Foot 1.39
    330 Foot 4.01
    660 Foot 6.30
    660 MPH 107.83
    1000 Foot 8.29
    1/4 Mile ET 9.99
    1/4 Mile MPH 132.63
  4. squirrel
    and do a comparison of required RWHP to run 117 vs 133 mph with 3100 lbs race weight.
    408 vs 600
    so if I started with 300 hp (that's the factory rated hp of the engine, btw) and added 1/3 of an atmosphere of boost to get 400, then I need the other 2/3 atmosphere (15 psi total) boost to get where I need to go.
    it's almost like I planned it that way. Now, to make the plan work...
    Thor1, dwollam, Tickety Boo and 9 others like this.
  5. squirrel
    Good tips, thanks! I found other ways to deal with them, as you'll see the further you read. The hole for the radiator is just too small for what I want, which is way too much cooling ability. So I decided to take the path of least resistance...have the radiator stick out the top, and not really have to cut anything except the part that went across the top, which is a bolt in piece. The radiator I found is for a slightly later Chevy truck, it has two plastic studs sticking out the bottom, I just drilled holes in the "frame" rails and dropped it right in place. It's hella ugly, but it works, and it was about as cheap as you can get for a cooling system with that much capacity. One other problem with this is the reservoir, there's no cap on the radiator, so I put the stock truck reservoir in, but it has to be higher than the radiator, so it makes it all even uglier. But it works, and it was cheap/easy.
    I did struggle with the flex plate for a while, I could not find the info I needed, so I got a stock replacement but SFI rated plate for a 4L80e behind a 6.0, and it fit with the correct spacing between plate and converter at the bolt pads...but the pilot was half an inch short, so I got the half inch space for that. Then the bolt pattern was wrong, I had to drill it to match the TH400 converter. I looked for a while and could not find a reasonably priced plate with all the correct details, strangely. But I'm happy with how it all fit together. And I have 7/16" bolts and nuts holding the converter to the plate.
    The heater hose fittings didn't seem to be a problem. The big one goes to the reservoir, the small one I just put a short hose on, and made a short beaded plug to cap it off.
    Thor1, dwollam, Tickety Boo and 7 others like this.
  6. Sharpone
    Sharpone
    Sounds like a Tee Shirt
    Dan
    porkshop, 427 sleeper and 41 GMC K-18 like this.
  7. squirrel
    What did they used to say, film at eleven?
    Thor1, dwollam, Tickety Boo and 19 others like this.
  8. 41 GMC K-18
    41 GMC K-18
    WOW, WOW, WOW, !!!!!!!!!!!!!!!!
    Gotta love that "CHEEP" kicked *** on this run, and its only going to get better and faster, as more tuning is going to happen.
    BRAVO @squirrel !
    porkshop, SS327, 427 sleeper and 2 others like this.
  9. Sharpone
    Sharpone
    IMG_3212.jpeg That ain’t right!:rolleyes:
    Dan
    Thor1, porkshop, SS327 and 1 other person like this.
  10. slowmotion
    slowmotion
    Sounded good Jim. How hard were you twisting it there, 7+ ish??:eek:
    porkshop, 41 GMC K-18 and Sharpone like this.
  11. squirrel
  12. bjinx
    bjinx
    Way cool Jim
    Sharpone, 41 GMC K-18 and squirrel like this.
  13. squirrel
    thanks!
    I played with wastegate springs today, trying to get a feel for the numbers of how they work. Installed height, seat pressure, lbs/in, piston area, valve area, etc. I think it all adds up, if I figure it was getting about 3-4 psi exhaust back pressure at the wastegate at 5 psi boost, then that would be enough to open the valve with the soft springs that were in it. I put in the next heavier set of springs that should end up roughly around 10 psi, it might be 8, it might be 12. I'll see when I go for a drive, if I have enough road, that is! And there's one more heavier outer spring that should get it up around 15, if my math is right. But I don't want to go there quite yet.
  14. AmishMike
    AmishMike
    Have u considered a water-alcohol injection after the intercooler? Do u run fuel with 15% or maybe E85. Friend has run totally stock EFI v6 ( bigger injectors ) on 18 lbs (17-19) many times; at 5 lbs water injection starts & timing starts to back off. Based on 2 caculations on speed & ET his 3.6 liter (222 ci ) is making around 480 hp
    41 GMC K-18, squirrel and Sharpone like this.
  15. squirrel
    I've thought about it, but I really don't want to. I want to run pump 91 or 93 when driving around, and try to keep the tune safe enough that it will be OK with that and no injection.
    There's a guy in Texas with a build kind of similar to mine (Green Cherokee 2 door with turbo LS) that is doing methanol injection, instead of intercooler, and he recently smoked a piston when the methanol system developed a problem. I really like simple things that don't have extra parts to go wonky, if I can.
    Anyways...back to racing...I found the datalog from my 11.44 p*** Friday night. The file management system is taking me a while to figure out.
    you can see I got off the throttle a bit when it was getting squirrely in second gear. But otherwise it looks kind of like it should?
    Thor1, dwollam, Tickety Boo and 3 others like this.
  16. squirrel
    Also after I swapped out the springs today I went for a little drive, and it has even more traction problem in second under boost than it did before, but the boost got up past 5 a bit before I let off completely. I need to figure out how to change the scale to psi, vs kPa, so it's easier to understand. And the blue color for manifold pressure is hard to see on the black back ground, so there are more things I need to figure out how to deal with..
  17. 19Eddy30
    19Eddy30
    from VA
    @squirrel
    Its been several months ago for me but I stumbled upon it I believe it's under one of these two drop downs
    To change to PSI , & I believe
    Its where you can change Chanel's to be seen in graph..
    It's easy but I cannot remember,
    The E Or box with dots
    Deutscher, Sharpone and squirrel like this.
  18. RMcCulley
    RMcCulley
    Random question...
    are you able to gradually introduce boost?
    Sharpone likes this.
  19. RodStRace
    RodStRace
    Again, peanut gallery. Seems the data shows boost. It also shows Target AFR which is a good 2 UNDER the Actual AFR. I get the feeling the computer isn't using the boost signal to enrich the fuel curve properly. I'd be leery of running that much leaner under boost.
    41 GMC K-18, Sharpone and squirrel like this.
  20. squirrel
    Well...sort of...as throttle and rpm increase, boost increases, until the wastegate starts to limit it. So closing the throttle some will reduce boost.
    But the wastegate is on it's own to limit boost to a set amount, or close to it, under WOT conditions.
  21. squirrel
    Thanks for pointing that out. Made me look again! but it turns out the difference is the scaling. If you look at the left column, you see that the box is checked for AFR scale, but not Target AFR scale...and the two are set to have different start and end points! When I set them the same, you see the two are overlapped pretty well.
    Thor1, dwollam, Tickety Boo and 5 others like this.
  22. 19Eddy30
    19Eddy30
    from VA
    @squirrel
    Just a pic of my screen that I took some time back , Maybe it will show / help to
    Locate the drop down for PSI & other , still playing with , I was dealing @ time with Lean bog @ first hit , then Rich .
    My fix was to add 4 degs of timing
    From 16 to 20 deg of initial for lean @ hit.
    I think I have 25 deg of initial.
    I am running a distributor right now,
    I have not gotten around to putting the crank trigger on.
    View attachment 6416466 View attachment 64164
  23. squirrel
    Thanks, I finally figured out what you're saying and how it works. I forgot that boost psig and MAP are two different things. That configuration table also appears in the gauges thing I was playing with a few days ago, I didn't realize it's a different one, that works the same way in both places.
  24. RodStRace
    RodStRace
    Glad I was able to bring clarity to it!
    Gotta say though, that I would hope that a snapshot in time aligned all traces!
    No wonder all the new car software has so many issues and the DTCs still require an understanding of the gaps in what is flagged and what is the actual expected data and what isn't.
    41 GMC K-18, porkshop and squirrel like this.
  25. squirrel
    I'm pretty new at all this, I expect it will take me a while to be able to do much with it, and I'll never understand it all.
  26. oldiron 440
    oldiron 440
    I think if you had the ability to use the laptop programming would be easier.
    porkshop likes this.
  27. squirrel
    I can use the laptop for programming, and that is what I do. But I trigger the data logging with the small screen, because I haven't yet figured out how to secure a laptop to the car so I can access it while driving. And even if I could, it's probably too distracting to be safe.
    Thor1, dwollam, RodStRace and 5 others like this.
  28. oldiron 440
    oldiron 440
    You need some time on the ch***is dyno?
    bobss396 and 41 GMC K-18 like this.
  29. squirrel
    tomorrow morning...
  30. oldiron 440
    oldiron 440
    That should be fun…
    Sharpone, squirrel and porkshop like this.
