Technical Ideas how to secure a loom connector to frame w/o drilling hole
Discussion in 'The Hokey Ass Message Board' started by MrCreosote, May 31, 2025.
  1. MrCreosote
    MrCreosote
    from USA
    The connector has provision for a T-head push barb.
    NOTE: It would be easy to use plastic ties around the frame, but that's Mickey Mouse and also not robust.
    I don't want to drill a hole in frame - I do not like drilling holes in cars of any sort - it goes against my fanatical desire to never make any vehicle less original. (I've seen too much cobbling in my 72 years.)
    There is so much innovative stuff everywhere, maybe something here?
  2. 1biggun
    1biggun
  3. 19Eddy30
    19Eddy30
    from VA
  4. Doublepumper
    Doublepumper
    from OR-WA, USA
    Dow Corning 732 Clear. Might seem a bit mousy, but works great. Can be easily removed if necessary.
    MrCreosote likes this.
  5. Ebbsspeed
    Ebbsspeed
    Panel adhesive.
    bobss396 and MrCreosote like this.
  6. kabinenroller
    kabinenroller
    Let be get this straight, you are posting on a Hot Rod forum and you don’t want to modify your car??
  7. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Candy Cane it around the frame. :)
    charleyw likes this.
  8. DDDenny
    200 MPH tape, about as traditional as you will find!
  9. tomcat11
    tomcat11
    MrCreosote and Kiwi 4d like this.
  10. jimmy six
    jimmy six
    What we called “sticky backs” for zip ties. The tape on the backs are similar to wheel weights …… and you know what a ***** those are to clean off.
  11. jimmy six
    jimmy six
    That tape will deteriorate over time…..black gorilla will not. I only use it on powder coat because it will peel paint.
  12. DDDenny
    They will make more!:rolleyes:
  13. Bandit Billy
    Bandit Billy
    I met a guy at a cruise in last year that wanted to find a traditional way to mount his electric fan. There is just no way to answer somethings other than to silently, and with dignity, walk away and find a beer.
  14. tb33anda3rd
    tb33anda3rd
  15. MrCreosote
    MrCreosote
    from USA
    You'd think my using hard drive magnets for **** welding auto body sheet metal, that I'd have thought of magnetic tie anchors. I did think of adhesive, but I just don't trust it - unless, maybe, if it's 3M.
    As far as Gorilla Tape, I used that to secure an incomplete roofing job over the winter with decent results, but the fabric was too stiff and the adhesive wasn't exceptional. T-Rex tape has adhesive that seems like it might pull skin off. I only use TR nowadays.
  16. MrCreosote
    MrCreosote
    from USA
    Good grief, I'm well aware and use both Uline and especially McMaster but it never occurred to me to check them. Thanks!
    tomcat11 likes this.
  17. Kevin Ardinger
    Kevin Ardinger
    If it is for wiring, why not run it through the frame? All of my headlight wires are run through the frame in the front. Can’t see any wiring.
    Just Gary likes this.
  18. bobss396
    bobss396
    One we used at work was made by Click Bond. It came as a kit. We used it to attach external wires on bomb racks.
    Our lab made up pull-test coupons before we used them. It did the trick, as good or better than advertised.
  19. Country Joe
    Country Joe
  20. Onemansjunk
    Onemansjunk
    from Modesto,CA
    8421146E-EC6E-410D-84A4-8FBC8112CA04.jpeg 7A756ABE-AEC6-411A-AEEF-8571CFC37DD2.jpeg 7274E729-164E-4DAE-A858-83FCC7CF5FCC.jpeg
    The traditional way I mounted my electric fans- was with the “Snotty End of a Weld Stick “.
    [QUOTE="Band
    Bandit Billy likes this.
  21. Tow Truck Tom
    Tow Truck Tom
    from Clayton DE
    Well speaking of traditional,,, get liberal with the baling wire.
    Toms Dogs, CSPIDY, seabeecmc and 2 others like this.
  22. CSPIDY
    CSPIDY
    Alien Tape, look it up, sticks to everything, and everything sticks to it.
  23. oldolds
    oldolds
  24. stuart in mn
    stuart in mn
    Maybe they've improved the adhesive but during my engineering career I never had much luck with them inside industrial control panels, which is a clean environment that doesn't see road dirt, grease or vibration - I wouldn't expect them to last long on the underside of a car.
  25. bobss396
    bobss396
    We used Thomas & Betts metal tie-down bases on a lot of electrical black boxes at work. The bases were small-ish.
    We stuck them down with a Bond Master 2-part epoxy. Once cured, they were impossible to take off short of a body grinder.
    deathrowdave likes this.
