Hot Rods B&M Hydro transmission help to identify
Discussion in 'The Hokey Ass Message Board' started by drumyn29, Jan 9, 2020.
  1. pontiac1953
    pontiac1953
    from missouri
    Gene Berck in Salinas is no longer building transmission, his age and health has him now living in a ho****e or nursing home either in Salinas, or near where he lived in Monterey, Calif. he's a very good friend of mine.
  2. bchctybob
    bchctybob
    That’s sad, but I guess we will all get there eventually. I hope he’s receiving good care and is at peace with this season of his life with lots of fond memories. Another of our priceless resources fading away.
    pontiac1953 and warbird1 like this.
  3. bchctybob
    bchctybob
    B&M stamped the same info from the tag on the machined surface on the back of the main case, driver’s side next to the tailshaft housing. So if the tag is missing or damaged, you should still be able to identify the trans.
  4. justpassinthru
    justpassinthru
    That's sad.
    I have delt with Gene for many years with early Hydramatic stuff.
    I knew something was amiss with Gene about 1 1\2 years ago.
    Gene would always return a phone call, then there was a recording by I ***ume was his daughter, leave a message. Never were returned.
    Eventually the website was taken down.
    Gene had more knowledge of early Hydromatics than anyone still alive.
    Supplied me with hard to find stuff and unmatched technical help.
    Wish him the best.
    Bill
  5. pontiac1953
    pontiac1953
    from missouri
    the tag does rear HO after the P55, the BC or UC code would be where you see SS on the right side, which stands for Street/Strip version of the Hydro Stick trans from B&M.
  6. pontiac1953
    pontiac1953
    from missouri
    I would say the equal to Gene Berck in old Hydra-Matic Knowledge, is Steve Peluso of Peluso Precision Automotive in Menden, M***. ph. 508-478-8900
    bchctybob likes this.
  7. pontiac1953
    pontiac1953
    from missouri
    the B&M tag on this Hydro Stick made me do a double take, My 54 Olds Slant Pan Hydro Stick tag numbers are almost identical, my tag reads R54 E6, and on the right side it reads UC4363 or 4565, it has the Olds 88 shorter tail shaft and housing. PICT0030.JPG PICT0030.JPG PICT0031.JPG
