This close ratio transmission features a 2:32 1st, "big in/small out" 1 3/8"/28, with green 6-tooth speedometer drive gear. Transmission was completely disassembled, thoroughly cleaned, checked and carefully re-assembled with select used OEM gears, synchros, countergear, main bearings and bronze thrust washers. New roller reverse and main shaft bearings, tailshaft bushing, seal and gaskets. Presently in VHT primer, paint/color choice with buyer. More info and pictures are available. Cash pickup at my home. Thank you.
