Where is the 1935-1936 ford dash install in a model A thread?
Discussion in 'The Hokey Ass Message Board' started by Hitchhiker, Oct 11, 2011.
  1. Hitchhiker
    Hitchhiker
    Where is the 1935-1936 ford dash install in a model A thread? I know I've seen someone on here do it. I just wanted to check it out before I start cutting. Any help would be great.
  2. Koz
    Koz
    Outback likes this.
  3. Hitchhiker
    Hitchhiker
  4. Hitchhiker
    Hitchhiker
    After reading it, that is not the one. In the one I am looking for he cuts the top ears off and moves them to the bottom.
  5. Hitchhiker
    Hitchhiker
  6. Junk Hunter
    Junk Hunter
    from The Ozarks
    Don't think I've seen the thread you are looking for but here is a '36 dash I recently cut down for my current build. Somewhere I have some pics of it as I was putting it together. If I find can find them I'll post for you.
    Stogy and Josh1226 like this.
  7. Hitchhiker
    Hitchhiker
    that would be great! thanks. Also did you weld all the way along the dash rail under the windshield?
    Stogy likes this.
  8. Junk Hunter
    Junk Hunter
    from The Ozarks
    Mine is built over a Model A dash rail and bolts on at the stock locations. That way I didn't have to weld to or modify the body.
    I found a bunch of pics. Here's the first batch...
    Stogy likes this.
  9. Junk Hunter
    Junk Hunter
    from The Ozarks
    a few more...
    You'll notice that some of these pics have the 'horns' in the corners that I reshaped from the original ones on the '36 dash. After I got it done I decided that I didn't like them so I cut them off and reshaped the corners. (per my pics in post #6 above) I like it much better without.
    Stogy likes this.
  10. -Brent-
    -Brent-
    Look at Mr. Ford's car. He just trimmed the sides, not much either.
    Stogy likes this.
  11. Junk Hunter
    Junk Hunter
    from The Ozarks
    Last batch of pics...
    Let me know if you have any questions about any of them. It was my first attempt at cutting one up and I really kind of made it up as I went but it turned out pretty nice.
    Stogy likes this.
  12. Hitchhiker
    Hitchhiker
    So is it a complete bolt in?
    Stogy likes this.
  13. Junk Hunter
    Junk Hunter
    from The Ozarks
    Yep. Uses the 1/4-20 bolt locations that the original model A dash rail used.
    Outback and Stogy like this.
  14. Hitchhiker
    Hitchhiker
    Thanks for the info, your install is really good. I was kinda thinking of something similar, but using the stock dash rail with it never occurred to me. I like how it extends the top of the dash with the top part of the old one.
    Stogy likes this.
  15. Junk Hunter
    Junk Hunter
    from The Ozarks
    No problem. Hope it helps. I'll be checking in on your build thread to see how your dash turns out. Your coupe is coming along great by the way.
  16. banginona40
    banginona40
    Here is the '36 dash in my coupe. It is solid welded in and fitted tight to the cowl. I then set up the perimeter around the windshield so the gl*** could installed with no frame. Makes the opening a bit larger with a chopped top.
    Stogy likes this.
  17. HomemadeHardtop57
    HomemadeHardtop57
    I did mine like Jack's..I think they look cl***y in an A
    Stogy likes this.
  18. Salty 28
    Salty 28
    from Mandurah
    Great thread, I’m just fitting a 35 RHD dash to the wife’s 30 Pickup
    Outback likes this.
  19. Kiwi 4d
    Kiwi 4d
    IMG_0127.jpeg IMG_0144.jpeg IMG_0143.jpeg IMG_0142.jpeg [
    My son fitted one to his 28 , a bit of slicing and dicing. What we didn’t allow for was the window regulator hitting the dash. Thankfully ford had allowed for this and with some manipulation the window regulator mount holes and the door remote hole were exactly the same and we were able to transpose the by a stroke of luck and small metal shaping internally reshaping the remote arm and adding a return spring. remaking the ears was a little more tricky to get it fitting close to perfect. ATTACH=full]6416803[/ATTACH] IMG_0144.jpeg IMG_0143.jpeg IMG_0142.jpeg
    Outback and Speccie like this.
