9s for $9k
Discussion in 'Off Topic Hot Rods & Customs' started by squirrel, Mar 18, 2025.
  1. squirrel
    yeah, we'll see what happens.
    new tag came today
    NoSurf, dwollam, Robdski and 18 others like this.
  2. That thing needs some meats.
  3. RodStRace
    RodStRace
    The gentleman runs mid 11s first time out and you critique his meats? :)
  4. Seeing what’s under the (non) hood compared to the tires, it’s like consistently ignoring leg day!
  5. squirrel
    yeah, I gotta spend some money for tires. I had the 6" slicks already, and they did work pretty well to run 11.44 :)
    Thor1, dwollam, Robdski and 7 others like this.
  6. Dick Stevens
    Dick Stevens
    He didn't build it for show, it's bult for business and I guarantee it will have appropriate meats on it when it is being raced!
  7. RodStRace
    RodStRace
    porkshop and Sharpone like this.
  8. e1956v
    e1956v
    Alliance Vendor
    https://ebay.us/m/MBQaHH
    Jim here’s a splitter cable so you can run the small screen and laptop. IMG_5606.png
  9. squirrel
    thanks, I have the cable already, it's just a matter of not being able to deal with a laptop while driving. I use it all the time when I'm stopped, to load tunes and save tunes etc. and my kid has datalogged with it while driving. I just need a way to mount the computer so it stays put and is accessible. The small screen has that going for it, but not much else.
    Thor1, dwollam, dogwalkin and 3 others like this.
  10. oldiron 440
    oldiron 440
    You need a computer stand like they have in cop cars…
    Thor1, Damon777, partssaloon and 3 others like this.
  11. Sharpone
    Sharpone
    What about a knowledgeable copilot that can run the laptop while you drive or drive while you operate the laptop, just thinking outside the box.
    Dan
    bobss396 and porkshop like this.
  12. squirrel
    That's a good idea, but I also like to drive by myself.
    In the end, I probably just want to get it tuned well enough that I never have to mess with it.
    Oh...I got the speedometer working! now I need to connect it to the computer and get it to be datalogged. I had purchased a gizmo that converts the cruise control speed sensor I have (that screws onto the speedometer gear fitting) to a square wave signal that the digital speedometer in the car can read. It took some fiddling, but finally seems to be doing it's thing. I need to change the gear in the transmission to get it to read correct, it's really close, only about 5% slow.
    Here's a datalog snapshot from the drive I took a little while ago. When I open it up at 60 mph, about 3000 rpm, it doesn't spin the tires. But it gets going faster than the speed limit pretty quickly.
    looks like it got close to 8 psi boost.
    dwollam, swade41, bobss396 and 5 others like this.
  13. e1956v
    e1956v
    Alliance Vendor
    Jim
    The Jeep speedometer driven gears are roughly 3% per tooth so two teeth less will speed you up 6%.
  14. squirrel
    I don't have the Jeep gears in it, since I swapped in a TH400, but I think the numbers are about the same :)
    I'll do a bit more testing before I change them. I expect one or two teeth difference will fix it. I want to check the odometer accuracy first, though.
    Thor1, dwollam, Sharpone and 4 others like this.
  15. RodStRace
    RodStRace
    Wonder if that's a feature on the dyno?
    Sharpone, Deuces, porkshop and 2 others like this.
  16. e1956v
    e1956v
    Alliance Vendor
    I forgot about the TH 400, yes same general percentage applies a little less in the 40 tooth range.
  17. 19Eddy30
    19Eddy30
    from VA
    @squirrel
    Cad mount out of / or for
    Cab , Police , Ambulance..
    Or pice of ply wood, stop / speed sign & tubing for mount & tilt , off floor or off bottom of dash ,
    Make a few L or U or Z brackets, foam on Edges to protect lap top with wing nuts for Quick release removal .
    Speedo signal
    How about a Ring modified to
    Rear Yoke with pick up instead of inside
    Trains
    I Do not know & asking,
    Hypothetically if Ring has 10 teeth,
    Does it mater if the 10 teeth are in a
    2 inch circle or in a 5 inch circle ?
    It still would be picking up 10 pulses .
    Or would the signal /frequency be clearer ,& more stable the smaller
    the Ring ?
    Sharpone and porkshop like this.
  18. squirrel
    I think I've solved the speedometer issue.
    As for the laptop mount...I can come up with something, just have to switch my mind to it. I need to make a console/cup holder thing to keep up with the modern cars, perhaps I can get by with a pocket for the computer to sleep in.
    It might be something I don't really need to deal with, I don't know yet. As I learn the system more, and get it running the way I want, I think it becomes less important, actually.
    Thor1, dwollam, 41 GMC K-18 and 6 others like this.
  19. Zottel
    Zottel
    Did someone watch UTG ?!
  20. TA DAD
    TA DAD
    from NC
    Your about ready for War in the Woods ! @ Brown County
  21. 19Eddy30
    19Eddy30
    from VA
    That Track by Pic's / Video Definitely qualifies to have some big ones Especially Low 5:10 & quicker ,over last few years they have added more pavement over gr*** incenter ,
    I have not seen track in person tho to walk ,
  22. squirrel
    The dyno session was fun. Didn't change the tune at all, but learned a lot.
    here is some data from the last pull
    dwollam, James D, BigJoeArt and 15 others like this.
  23. Greg Rogers
    Greg Rogers
    Impressive #'s Jim.
    Baumi, 41 GMC K-18, Sharpone and 2 others like this.
  24. swade41
    swade41
    from Buffalo,NY
    I met up with the local kid that won the second chance race (30's pickup true gangster) on his way to the race. He was relaying some parts to another racer for me, but he said it'd take solid 4.60's to win that race. My last words to him before he left was "be safe", that track looks sketchy as all get out with that gr***.
    Tickety Boo and porkshop like this.
  25. fastcar1953
    fastcar1953
    Roll cage pictures looks like a bad paint job. I doubt it's muffler shop bends.
    slowmotion likes this.
  26. 19Eddy30
    19Eddy30
    from VA
    People Fly in Air Plane's with out
    """ Parachute"""
    But on water Need a Life vest !!
    Tickety Boo, 427 sleeper and Sharpone like this.
  27. slowmotion
    slowmotion
    I think Jim installed the cage the same day he left for his first test session IIRC. Probably slapped some paint on it and headed out. Ain't no show piece, it's a go piece!
  28. squirrel
    What are the rules about roll bars? I know there are SFI specs about cages for the faster cars, but there doesn't seem to be much about the roll bars aside from General Regulations 4:10, and it doesn't mention how tubing is bent, although it does talk about mounting requirements and welding processes. Most guys think a roll bar has to be 6 point, but the rules never mention a p*** side door bar...I think hardly anyone actually reads the rule book carefully, before talking about what's required.
    badshifter, Thor1, dogwalkin and 8 others like this.
  29. swade41
    swade41
    from Buffalo,NY
    Didn't it already p*** tech, how could've you made a mid 11 p*** without p***ing tech ???
    427 sleeper likes this.
  30. squirrel
    it p***ed tech for 10.0, and needed it to make the 11.44 run it did.
    dwollam, Deuces, swade41 and 5 others like this.
