History So . . . What is it?
Discussion in 'Traditional Hot Rods' started by Sskirch, Jun 2, 2025.
  1. Sskirch
    Sskirch
    Long story short, my dad is downsizing and he gifted me his 31 Ford Roaster and a boat load of parts. Everything is identifiable except this this one piece. He has no it idea what it is how to utilize it. Here's what we do know: It's definitely a component of some kind of intake setup. He acquired it in a parts swap in the late 1950's. It's attached to two Carter YH side draft carburetors, most likely from a 53 or 54 corvette. It mates perfectly to a standard Stromberg intake manifold. If you attached it to a standard flathead manifold the carbs would be facing forwards. It came with a McCollum 39M supercharger, and it was supposed to belong to the supercharger setup, but that does not appear to be the case. On it's own it's too heavy to support it's own weight and would probably crack itself or the manifold (or the supercharger) on the first pot hole, indicating there there must be a missing bracket. There are no markings or numbers. It's made from cast aluminum. Any ideas on what it could be?
    20250601_150434.jpg 20250601_150417.jpg 20250601_150434.jpg 20250601_150417.jpg 20250601_150434.jpg 20250601_150417.jpg
  2. pprather
    pprather
    Welcome to the HAMB from Illinois.
    What is the gauge above the mounting flange?
    dana barlow likes this.
  3. It's got in- Hg on the scale.
  4. 41 GMC K-18
    41 GMC K-18
    Paging @Hitchhiker
    Hey Matt, chime in and give us all the lowdown on what this is!
    @carbking may have some good input as well!
    warbird1 and lothiandon1940 like this.
  5. Sskirch
    Sskirch
    I believe it's a vacuum gauge.
  6. pprather
    pprather
    I would say it is an intake manifold. The three bolt mounting flange should bolt to a stock Ford flathead intake manifold, once the stock carb is removed.
    lothiandon1940 and 41 GMC K-18 like this.
  7. Andy
    Andy
    I think it was designed to fit on a blower. Probably a centrifugal one.
    BigJoeArt and squirrel like this.
  8. squirrel
    and under the Carter carbs are adapters to the Stromberg 3 bolt pattern? and the are bolts for support brackets, as well.
    pretty wild setup...I can see why it sat in a box for 70 years.
    alanp561 and 41 GMC K-18 like this.
  9. Sskirch
    Sskirch
    The Caters bolt directly to the manifold. No adapters. The red piece is a throttle body. I believe that the bolts on the side a for a support bracket. They would almost have to be.
    seb fontana and squirrel like this.
  10. lostn51
    lostn51
    from Tennessee
    I agree with the blower intake synopsis and I couldn’t even come close as to who’s it is but it is neat as hell!:cool:
    seb fontana likes this.
  11. krgdowdall
    krgdowdall
    from Alberta
    My guess is a flathead marine manifold. Low profile.
    They used side drafts on the Y block marine also.
    panhead_pete and Toms Dogs like this.
  12. Some of the early "dishpan" blowers had a mount for a single Stromberg 3 bolt pattern carb. Mounting twin carbs vertical would make it way too tall and side drafts were popular in the early 50's. So a pair of side drafts on a branch manifold. That manifold is cast aluminum, they made more than ONE ?
  13. stuart in mn
    stuart in mn
    I ***ume it's McColloch supercharger? If so using this spelling may help in your search for answers.
  14. AccurateMike
    AccurateMike
    McCulloch will work even better.. Mike
  15. silent rick
    silent rick
    looks like the carbs would face rearward, not forward. has to be a ***** to get the back nut or bolt on. my guess is marine application also or next guess, possible a home made one off intake somebody made or had made
  16. carbking
    carbking
    Too many pieces removed from the carbs to tell original application from the pictures; BUT the tags ARE present. The numbers on the tags will tell us the original carb application.
    Jon
    Budget36 and 41 GMC K-18 like this.
  17. Sskirch
    Sskirch
    You are correct. I just checked the car, and there is a plate between the carb and the supercharger that reverses the bolt pattern. I'll have to ask my dad why he did that. Anyway, mounting it facing the rear would allow a bracket to be attached to the primary intake, which makes more sense.
    41 GMC K-18 likes this.
  18. patsurf
    patsurf
    :confused::eek::rolleyes:
  19. Sskirch
    Sskirch
    So, facing rearwards, attached to the McCulloch, it just barely clears the firewall, leaving little to no room for air cleaners. The marine application theory is looking more likely. However . . . if I could rotate it 90 degrees, I could mount it as a true (sort of) sidedraft intake. Anyone know of a flange that would allow me to rotate a two barrel carb, and by extension this weird-*** manifold, 90 degrees?
  20. ROADSTER1927
    ROADSTER1927
    Just make one it is not hard to do.
  21. Ducbsa
    Ducbsa
    from Virginia
    I wonder what that stud crossways in front of the carbs is for, also the cover plate above it?
  22. seb fontana
    seb fontana
    from ct
    Those Carbs have slotted bolt holes, that oem on bottom side? Maybe done to slip in place because of clearance issue? Top side looks to be a bolt.
  23. seb fontana
    seb fontana
    from ct
    I guess custom built for supercharged FH powered early hydro where engine is mounted backwards, scared to read boost so vacuum gage or maybe for carb tuning under prop load. Maybe Holman/Moody.
    Neet piece, never seen one. I guess Dad likes you; Tell him I said Happy Fathers Day!
  24. trevorsworth
    trevorsworth
    How the hell do you put a nut on that stud?
  25. seb fontana
    seb fontana
    from ct
    Simple.. You don't! With all the overhang weight I think a little gasket shellac and a little push down when tightening the support bolts will make the gasket seal. Or maybe take top half of super C off and bolt from inside.
    trevorsworth likes this.
  26. richard noble
    richard noble
    I think that Summit vacuum gauge was added later, as Summit didn’t open till 1969. If you take that gauge out I think you could slip a nut through the hole for the flange. Just a thought…
    seb fontana and trevorsworth like this.
  27. Sskirch
    Sskirch
    My theory is that the guage on top is not supposed to be there. Those two holes line up perfectly It's possible that a longer bolt goes through that hole into the manifold. Or, you use a socket cap head bolt and tighten it with an allen wrench via the guage hole.
  28. lostn51
    lostn51
    from Tennessee
    This is on another thread that was just posted and I think this might be the maker…… IMG_3276.jpeg
  29. lostn51
    lostn51
    from Tennessee
    IMG_3276.jpeg I can’t blow it up big enough to see for sure but the one on the last row second from the bottom might be the kritter.
  30. seb fontana
    seb fontana
    from ct
    Wow, hell of an ***ortment of examples. Company name is sorta familiar.
