Technical Brake pedal problem
Discussion in 'The Hokey Ass Message Board' started by hillbilly4008, Jun 3, 2025.
  1. hillbilly4008
    hillbilly4008
    from Rome NY
    Hi all,
    I need others brains on this one.
    Im working on the brake system on a truck i just hauled home. Manual brakes. Drums all around.
    Replaced master cylinder with universal one of the same bore. Rebuilt all wheel cylinders. Bled everything numerous times. Currently have all the shoes adjusted all the way out and locked to the drums.
    I can not get a hard pedal unless pumping the hell out of it.
    Need insight.
  2. 302GMC
    302GMC
    from Idaho
    First thing we always verify - got free play on the pedal ?
    Mr48chev and alanp561 like this.
  3. tomcat11
    tomcat11
    Bench bleed M/C?
    Johnny Gee and hrm2k like this.
  4. hillbilly4008
    hillbilly4008
    from Rome NY
    No freeplay in pedal
  5. hillbilly4008
    hillbilly4008
    from Rome NY
    Bench bled multiple times
  6. tomcat11
    tomcat11
    Can't remember exactly but something like 1/8" freeplay between push rod and M/C piston is needed.
    gimpyshotrods, alanp561 and Just Gary like this.
  7. hillbilly4008
    hillbilly4008
    from Rome NY
    Should also mention no visible leaks anywhere
  8. warbird1
    warbird1
    Where is the master cylinder located and does it have residual pressure valves?
    alanp561 likes this.
  9. hillbilly4008
    hillbilly4008
    from Rome NY
    Firewall. Single line coming out going to a T, line going forward to a T then across the front. Line going to the rear to a T and across. No valves
  10. AldeanFan
    AldeanFan
    Any lines that loop up higher than the bleeders?
  11. tomcat11
    tomcat11
    Year, make and model?
  12. hillbilly4008
    hillbilly4008
    from Rome NY
    1960 datsun plg221
    leon bee likes this.
  13. hillbilly4008
    hillbilly4008
    from Rome NY
    I think this is a pushrod length problem
  14. gary macdonald
    gary macdonald
    Nice ! But I think your old master had a residual valve built into it . It prevents the fluid from entering the master cyl . Drum brakes and disc required different lbs ratings one is 2 lbs the other is 10 lbs . Usually a master on the firewall would negate the use BUT I went crazy with a similar situation. Ended up solving it with a $20 residual valve .
    warbird1 and alanp561 like this.
  15. tomcat11
    tomcat11
    Could be if the M/C piston is not moving all the way back when pedal is released.
  16. hillbilly4008
    hillbilly4008
    from Rome NY
    What if its not long enough?
  17. alchemy
    alchemy
    If your rod isn’t long enough, you’ll never get a good result.
  18. tb33anda3rd
    tb33anda3rd
    I bought a brand new master for a project, could not get a pedal. took it all apart and it was missing a seal on the inside......
  19. tb33anda3rd
    tb33anda3rd
  20. rusty valley
    rusty valley
    Very cool little truck!
  21. manyolcars
    manyolcars
    The master cylinder may be bad. For a while I got 4 bad ones in a row, all were new
  22. ClayMart
    ClayMart
    Datsun sure made some funky looking pick-ups back then. :confused: The only one of these I've ever seen belonged to a waitress at a local restaurant. She named it "Arlo" and it was pretty well used up. The damned thing had a crank hole at the bottom of the grille and a one-way socket on the end of the crank so you could roll the engine over by hand.
    o_O
  23. tomcat11
    tomcat11
    As alchemy says, thats no bueno too. Bore and stroke determine the displaced volume of fluid. You may have to measure and compare the stroke distance to the one that came out. This ***umes the one you are replacing was right to start with. Also look at the push rod. Is it original or modified? Maybe you inherited someone else's bush fix.
  24. hillbilly4008
    hillbilly4008
    from Rome NY
    I don't think its the master cylinder. I pulled the line that comes off and plugged it. Immediately the pedal was rock hard. Could not move it at all.
    Here is a side by side of what i did.
    I did have to modify the pushrod to mate it to the pedal. I made it the exact same size at the original one. This is probably where i messed up. There is no adjustment in the pushrod, they used shims on the master cylinder from the factory. Tomorrow's task is digging deeper into this..
    I don't want to clutter general discussion with an off topic vehicle. If anyone is interested i made a thread in off topic.
    https://www.jalopyjournal.com/forum/threads/rotten-datsun.1335755/
    warbird1 likes this.
  25. tomcat11
    tomcat11
    That kind of stuff should not happen but, unfortunately it does, putting you behind the 8 ball! I wonder if any brake part companies test their ***embled components before they shove them in the box.
  26. Mr48chev
    It doesn't matter what the vehicle or what brakes it has on it you HAVE TO HAVE at least 1/8 of an inch of free play in the pedal when you reach in with your hand and push down on the pedal.
    If that port between the piston and the reservoir is blocked you won't have fluid moving in either direction when you need it to.
    Also and very important, if you are not using a pressure bleeder and have a helper pumping the brakes it is imperative that you have them PUMP SLOWLY and HOLD the pedal until you tell them to release it or pump it again. My 45 year daughter has helped me bleed brakes since she was 4 and she is by far the best helper at that I have ever had including probably 30 different shop employees or mechanics when I was doing brake jobs daily for a living. A helper who will not follow directions or a guy bleeding the brakes who does not give specific directions on how it has to be done cam make a mess of things real quick. Plus there are a lot of wrong ways and damned few correct ways.
    gary macdonald and hillbilly4008 like this.
  27. hillbilly4008
    hillbilly4008
    from Rome NY
    Back in the garage. A couple things I'm trying today. When i modified my pushrod i made it the same length as the original, and used the compression spring on it that the new master cylinder came with. As it turns out that spring was compressing all the way before the piston bottomed out. I wasnt getting the last 1/4" +/- of stroke. I removed that spring completely, the original one never had one. Springs on the pedal.
    I also removed some of the factory master cylinder shims.
    As far as i know i now have full stroke with the pedal now, and a little bit of play. Waiting on my old man to get here so we can try bleeding this thing manually. I've lost trust in my pressure bleeder.
  28. jcrapola
    jcrapola
    Have you considered gravity bleeding it? Add drain hoses to the bleed screws and leave em cracked open. Do NOT hit the pedal just let ‘em weep. The weight of the fluid in the master will keep ‘em dripping a bit. Check the reservoir every 20 mins or so, and clean the garage, have a beer, or whatever. I have also rigged up an auxiliary reservoir and left em over night. Saves a lot of pumping on a new system.
    warbird1 and hillbilly4008 like this.
  29. hillbilly4008
    hillbilly4008
    from Rome NY
    Great idea!
    Those 2 changes i did made a m***ive difference. Its still not perfect though. Gotta bleed more i guess
