Technical 63 nova lower control arm install help
Discussion in 'The Hokey Ass Message Board' started by fastcar1953, May 21, 2025.
  1. Johnny Gee
    Johnny Gee
    from Downey, Ca
    That’s how I remember them.
  2. fastcar1953
    fastcar1953
    @Johnny Gee I got the new bushings with spacers built in. Installed and car drives o.k. Time to get it aligned.
    No more wobble in wheels. Thanks for the help.
    Johnny Gee likes this.
  3. Mr48chev
    Too late to the party but one trick I used when replacing ball joints or lower control arms in those and the little Fords with similar suspension was set a 2x4 on what serves as a frame to catch the upper control arm and relieve pressure on the ball joints and control arms. It makes working on them a lot easier.
    deathrowdave likes this.
  4. fastcar1953
    fastcar1953
    I used my jack stand under the upper a arm. I had it on my lift. lowered the lift till it raised it up.
  5. Mr48chev
    I did some sketchy things when I was doing front end work for a living but if OSHS had caught me doing that my ass would have been in the frying pan big time. That is a hell of a good way to get injured.
  6. In_The_Pink
    In_The_Pink
    These parts appear very similar to what Corvairs used--- very similar "special" washers and camber adjustment bolts. Check out Clark's Corvairs ( www.clarkscorvairs.com ) I would not be surprised if GM used the strut rod bushings and other pieces for both Chevy II and Corvair.
