Dust Bowl Speed Shop World Headquarters
Discussion in 'The Antiquated' started by Roothawg, Dec 9, 2023.
  1. Roothawg
    Roothawg
    Sorry to hear that. I think that number is pretty low of you ask me. Mine is 50x120x18. If I were single, I would have an apt upstairs approx 1200 sf. And that would be it.
  2. nrgwizard
    nrgwizard
    from Minn. uSA
    If you haven't done it yet, & still can, Run the fiber-optics cable(s) now, or at least put in some runs for them later. We're just getting it here in MN, at least where I live.
    Marcus...
    & TT;
    Ouch, that hurts, in a few ways. Hope things work out well for you, soon. A small-ish trailer-house for temp living? While the new(est) shop is being built? Contractor-deal might be acceptable, if you get what you need.want... Don't think I could live in CA, for a lot of reasons. Someplace South outta the snow does sound good, though. :D .
    Marcus...
  3. alanp561
    alanp561
    o_OWow, I haven't seen that since high school Lit cl*** in Mustang. Same teacher for Lit and Latin.
    Roothawg likes this.
  4. Roothawg
    Roothawg
    We have fiber here in the shop. I wired it with all Cat 6E. I have the office wired, all the TV’s. Etc. I have pre wired the walls for surround sound.
  5. nrgwizard
    nrgwizard
    from Minn. uSA
    Stargate chamber, too? ;D.
    Almost the perfect Retreat. :) .
    Marcus...
    Roothawg and porkshop like this.
  6. TraditionalToolworks
    from NorCal
    Thanks, I don't want to de-rail BossHog's thread, but things will hopefully work out. Trying to get my home listed, pay my taxes and get the flock out of here before it crashes. My CPA told me that there's a lot of people thinking like me, cash out while we can and get the flock out of CA once and for all. For me the worst part will be separating from my wife...but we will hopefully visit each other. I would visit Japan if I had a place to stay. And she will visit here...I'll just get a dog...LOL
    SS327, hotrodjack33, Roothawg and 2 others like this.
  7. guthriesmith
    guthriesmith
    Guessing you were able to water the new sod for free again last night? Hopefully it didn't wash away.
    down-the-road, Okie Pete and porkshop like this.
  8. Roothawg
    Roothawg
    The new sod is in overdrive. It only has a couple of spots where it is slow to grow, only because it’s where water stands. Come July, when Bermuda kicks in, it will spread like wildfire.
  9. Roothawg
    Roothawg
    Spray foam guys are getting after it. I snuck in and snapped a couple of pics. This is roughly 8” of foam in the walls. A layer of closed cell against the sheet metal and the rest is open cell. I think he said the R value was around 39 on the walls and 35 on the roof.
    drdave, SS327, down-the-road and 3 others like this.
  10. Roothawg
    Roothawg
    This is what they use to flatten it. It’s basically a chain saw with a special attachment.
    This is the wall after it’s leveled.
    drdave, Lepus, RMR&C and 6 others like this.
  11. TraditionalToolworks
    from NorCal
    BossHog,
    How much does that insulation cost? I am looking at a shop that uses the foam panels, 2" thick, 4x8s, but it only provides R-13.5, which is not even good to live in during the Idaho winter.
    Does the foam fill in the entire 6" depth of the framing? His panels are about 1/3rd the framing, but seems that would be better with the foam like you used. Those foam panels are about $55/ea at Home Depot...I was thinking it may be possible to fill in the framing, I don't know if it's 6" as it's steel. You may have some steel, but above is obviously stick frame. I was thinking about stick framing 500 sq.ft. to live, and calling my $800/year good on taxes, if I buy it. I want to go up and camp on some property I'm interested in after Labor Day...I want to negotiate just before winter is heading in...;)
    How do you get taxes on the living space inside? You have to pay taxes on that, right? I haven't found a state that doesn't charge for living space, yet.
    Yeah, looking at it, it looks like the steel supports are only 4" deep possibly.
    porkshop likes this.
  12. oldiron 440
    oldiron 440
    I didn’t know talking to crickets was a thing…
    porkshop and Okie Pete like this.
  13. Roothawg
    Roothawg
    So, I am sure I’ll have to send my plans to the county for their ***essment. Otherwise they will tax me on the entire 6,000 SF.
    The foam is about 8” thick. I have a 4x4 frame plus the 2x6 wall.
  14. Roothawg
    Roothawg
    I can dream.
    porkshop, Okie Pete and oldiron 440 like this.
  15. TraditionalToolworks
    from NorCal
    Yeah, this seems pretty common for all states. Although, Idaho is a lot less for property tax with no living space on it, it's also not uncommon for small 500 sq.ft. cabins with 4000-5000 sq.ft. shops for the same reason. The above has the concrete beefed up for machines and heavy equipment, and there's a large flat area all around the shop, so the taxes are low. But based on .4% of $325k, that's about $1200 per year taxes, about 1/3rd-1/4th of what CA charges. We also get taxes for everything and why my property is ***essed at $560k but I pay $9k for taxes/year.:( At 1%, which we're supposed to be, they would be about $6k/year with a couple bills for local schools.o_O
    Is you foam cheaper than the above panels I mentioned? Pretty sure they're about $55/ea at Home Depot, and I think that is pretty much true across the country. I figure there's easy 100 panels, so that's gotta be $5k-$6k for the panels alone, not including labor. The top braces do make it look like it could withstand a heavy snow load.
  16. oldiron 440
    oldiron 440
    lol
  17. Roothawg
    Roothawg
    Bought some more junk for the office, because I have so much free space to store stuff.
  18. Roothawg
    Roothawg
    It's not cheap, but they did a ton of foam. They sprayed about 2500 sf of living space plus the roof and then we had them totally spray the garage for mama's car. It got sprayed the roof and walls and then we sprayed a layer between the house and the shop to cut down on noise. All of that was $15k.
  19. Squablow
    Squablow
    Love the starburst clock. Would really like to see the desk but the pic link is dead.
    porkshop and down-the-road like this.
  20. Roothawg
    Roothawg
    OK fixed the link.
    porkshop, Squablow and Okie Pete like this.
  21. oldiron 440
    oldiron 440
    The thing about getting a bigger place is:)
    Okie Pete, Roothawg and porkshop like this.
  22. Roothawg
    Roothawg
    Spot on.
  23. drdave
    drdave
    Man, looking good Chris! You will love that foam.....best investment I ever made in my shop. I only had the roof done and did fibergl*** in the walls, but the foam alone on the roof made a HUGE difference. Having it all over like you did will make that place snug as can be. Nice!!
  24. Roothawg
    Roothawg
    Unfortunately, the shop got the standard R3 batt insulation. The spray foam is for the living quarters, shop office, her garage and ther welding shop.
    Okie Pete, drdave and porkshop like this.
  25. Roothawg
    Roothawg
    Some boring updates.
    I wanted a barrier between the shop and the house garage. I always worry about a fire in the shop while we sleep, sonI bought a commercial steel door with a 90 minute fire rating. Code says 20 minutes. I also have the 20 minute fire door between the garage and the house. I wanted to make it look as vintage as possible. I added trim to make it look less industrial.
  26. Roothawg
    Roothawg
    IMG_5010.jpeg The house is underway. The sheet rockers are gaining on it. They are close to texturing. They should be done this week.
    Squablow, Tim, guthriesmith and 5 others like this.
  27. Roothawg
    Roothawg
    I added an inline vent blower to evacuate fumes out of the welding shop. It’s roughly 800 cfm.
    It should work out ok. We had a problem anyway trying to vent the dryer vent, since I didn’t want it to go out through the roof. I used a Y to tie in the dryer.
    It’s an 8” duct. Should be plenty of volume
    For fumes. I added a check valve right at the exhaust vent and another to prevent the dryer from pushing the exhaust into the welding shop.
    There will be a 90 degree fitting here and will tie into a hood. Still have to build the hood.
    Squablow, Tim, guthriesmith and 3 others like this.
  28. Roothawg
    Roothawg
    Here is a pic of the blower.
    drdave, Okie Pete and porkshop like this.
  29. Roothawg
    Roothawg
    I had a few drywall sheets left over, so I had the guys throw them up in the welding shop over the plywood. I know it seems like overkill, but it adds a fire barrier and also helps with the noise. So, it will have 1/2” of Sheetrock, 3/4” of plywood, then 6” of spray foam and another 1/2” of drywall.
    I can’t have mama invading my happy place making domesticated sounds from the laundry.
  30. Do you have a link for that inline vent fan? I want to have one in my welding area, and also vent it out the wall.
    Thanks!
