Hot Rods Throwout bearing: Constant contact or air gap?
Discussion in 'The Hokey Ass Message Board' started by KCTA Chris, Jun 4, 2025.
  1. KCTA Chris
    KCTA Chris
    Changing my transmission in the '55, no drivability problems just changing updating my Saginaw 4 speed on a SBC with a tight mechanical linkage. Question has come up if I had my throwout set correctly. Searching past threads go either way without a definitive answer.
    I had set my throwout set for constant contact with very minimal pressure on the pressure plate fingers (bearing always spinning). Thats how I thought it was done? I've also read thats wrong... and needs to be set up with a few thousands air space between the plate fingers and bearing - bearing should only be spining when engaging the pressure plate fingers to change gears.
    Not sure which set up is right? or if Im killing my bearings life?
  2. dana barlow
    dana barlow
    from Miami Fla.
    Gap,/play, 1/8 to 1/4 inch free play is good,before it starts on clutch fingers.
    If it is in constant contact=it will good bad fast; not designed for spinning the hole time engine is running.
  3. 302GMC
    302GMC
    from Idaho
    I've always given the pedal 1'' - 1 1/2'' free play - I like the release point right in middle of travel.
    Mr48chev, 427 sleeper and 2OLD2FAST like this.
  4. squirrel
    It's a good idea to set it up with significant clearance between the bearing and fingers. It only needs a few thousandths, but as the clutch wears, the clearance decreases, and you don't want to be adjusting it every week.
  5. 427 sleeper
    427 sleeper
    Like what @302GMC says... 1 to 1 1/2" of freeplay at the pedal. That's all that's really needs to be worried about. The distance between the fingers and the bearing is a constant at that point. Don't over think it.
    squirrel likes this.
  6. rusty valley
    rusty valley
    Throw out bearings are not designed to run all the time, they need clearance or they will wear out faster than the clutch life. About an inch of pedal free travel is the norm for any make of car for about 100 years
    deucemac likes this.
  7. Mr48chev
    One more vote for one inch of free travel. Meaning that if you set a on the floor or kick board in line with the travel of the clutch pedal you should be able to press the pedal down one inch with your hand before you feel the throw out bearing contact the fingers on the pressure plate. Make sure that you have a return spring on the clutch pedal too. From there it is 303GMC said in post 3. where you like the pedal when the clutch releases. The clutch in my C30 is spot on for what I like but the one in my F250 never feels right. I had a shop in town put a clutch in it as both my son in law an I were too bunged up at the time to do it ourselves out in the driveway and still am not sure they used the right parts. It works fine but is the worse feeling cutch I have ever driven.
  8. Another thing, must have a good clutch pedal return spring so the linkage and fork don't slop around and make random contact on the throw out bearing. Which comes out to part time full contact. Adjustment is something you will learn over time. Over time you will learn what feels right.
    Always buy the best clutch throw out bearing you can find. I've seen/had cheap ones that start to go dry and drag on the pressure plate arms wearing those down as well. Throw out bearings and pilot shaft bearings. Pulling a ****** just to replace a few of those is a PITH.
    Just my opinion, like **** cracks, everyone has one.
    dana barlow likes this.
  9. KCTA Chris
    KCTA Chris
    Thanks guys, thats the info I needed.
    Going to give it a space this time.
  10. Onemansjunk
    Onemansjunk
    from Modesto,CA
    “Riding the clutch “. On purpose???
    427 sleeper and ClayMart like this.
  11. V8 Bob
    V8 Bob
    I was always curious about the "1 inch or so clutch pedal free-play" spec so common in shop manuals, and finally bought the mid-'70s "Tom Monroe Clutch and Flywheel handbook" before I started building clutch linkages, learning the normal overall clutch operating ratio was in the 11 to 1 range, which will result in the 1" or so pedal free-play spec with minimum T/O bearing to pressure plate distance. All that's really needed is about .100" (1/10th") clearance, as long as full dis-engagement doesn't exceed recommended disc to plate clearance, based on the pedal ratio and pressure plate design.
    Simply put, at-rest pedal free travel is the result of throw-out bearing to pressure plate distance X overall clutch linkage ratio.
    Tom's book is still widely available, and although dated, is still a very good source of clutch related information today.
    Automotive Stud, rusty valley and Tim like this.
  12. ClayMart
    ClayMart
    You may be getting advice from some folks that are used to working with later model, off-topic clutch set-ups. Some hydraulic clutches and even cable actuated clutches with automatic self-adjusters run the T.O. bearing in constant contact with the pressure plate fingers. And those bearings seem to be considerably more "spendy".
  13. 1biggun
    1biggun
    You want free play on the bearing .
    I ruined a few in my younger days on chevys that spun high RPM.
