Projects 1938 plymouth coupe project
Discussion in 'The Hokey Ass Message Board' started by gas man, May 7, 2025.
  1. There were some mopar forged I beam axles.
    not sure which years or dimensions
  2. gas man
    gas man
    from socal
    So im either going to make an attempt at a 2 link air ride or air over leaf in the rear. Anyone have any suggestions on either one? Motor will be stock, weekend cruiser to the local cars and coffee. This will be my first attempt at welding a rear suspension. Im leaning towards a 2 link I design myself ( with the hamb help).
  3. Practice welding. A lot. If there’s a cl*** for it close by, sign up. Explain to the instructor what your plans are. Skip the stick, straight to mig
    but an air over head is simple. But don’t expect it to act like full bags or hydraulics.
    My old boss had an air over leaf set up. Changed height a few inches. Mostly for overload when people set in the back seat.
    Okie Pete and RodStRace like this.
  4. Grumpy ole A
    Grumpy ole A
    Just saw this tube dropped axle on another thread. I thought it might help getting you a dropped axle.[/QUOTE]
    gas man likes this.
  5. gas man
    gas man
    from socal
    Got the motor in from the 59 pickup and sticking with the trend I took it apart. Cylinders look decent. The pickup bellhousing didn't work so I got a 39 bellhousing off ebay. The pressure plate hits so im gonna need the correct one. I also need to find a transmission, that may slow me down. 20250524_181649.jpg
  6. tr_rodder and Okie Pete like this.
  7. gas man
    gas man
    from socal
    Thanks for the help so far Anthony. Much appreciated. I dont really have any " hot rod" friends so im relying heavily on the help here.
  8. RodStRace
    RodStRace
    Those are good engines, but they are torque biased, not RPM. A step up from the stock 3 speed is going to make it much more modern road friendly. They also had the e brake on the back of the stock one.
    You may end up swapping rear axle, too. More modern self energizing brakes, one piece axles, the e brake function, plus more gear ratio selection and easier to find parts.
    I grabbed an 8.75 from a 68 Coronet, which are not as easy to find now, but didn't need to be shortened, just spring pads welded on. Those rear springs will work, but are narrower than later stuff.
    lemondana, Okie Pete and gas man like this.
  9. RodStRace
    RodStRace
    As for the trans, stock was what would be called a mid mount, with the trans hanging off the back. I swapped to a V8 auto and had to fab a mount. It's pretty simple, the cross member that was from the trans, cut to fit between the X member with a plate welded to each side. Those bolt to the member.
    This is a 40, so it does vary some.
    Deutscher, Okie Pete and gas man like this.
  10. Grumpy ole A
    Grumpy ole A
    Nice setup for the little 6
  11. gas man
    gas man
    from socal
    The local metal supply didnt have the size I wanted for my crossmember, so I made my own. Arc welded it with a root p*** first. 20250603_111454.jpg 20250603_114952.jpg 20250603_121122.jpg 20250603_135048.jpg
    Tried mig welding for the first time on my trailing arms
  12. gas man
    gas man
    from socal
    Anyone see anything wrong with this notch design? It will be made from 3 inch wide 3/16 flat stock. It will give me about a half of an inch clearance between the axle and notch if the frame was on the floor. The axle is 3 inches wide and the notch is 4 at the top. 110 degree angle.
    Deutscher and Okie Pete like this.
  13. gas man
    gas man
    from socal
    Wire wheeled the frame. Going to paint it semi gloss black with rustoleum
  14. If you add some radiuses you can save some welds
    the rear of the frame will try to sag or pull when the inside plate is welded
    Be careful how ya weld it
    Save some welding for the top maybe for the last bit of welding
  15. RodStRace
    RodStRace
    What are you using for axle locating, stock leafs? Arms tend to have an arc in the travel, so lowering will shorten the length. Make sure it's where you want it in the fender at ride height. It will be more obvious with the wheel/tire tucked up.
    This pic from the first page looks good. just make sure you check this.
    Okie Pete likes this.
  16. gas man
    gas man
    from socal
    I took measurements at the stock height from the transmission crossmember to the drive shaft flange on the rear axle . Im keeping the same distance at my new lowered planned ride height. You think thats good enough?
  17. RodStRace
    RodStRace
    Should be, but it's one of those things where if it's off, it will bug you.
    You have solid before numbers so that's helpful.
    EDIT: Went back and read through again. You are doing a great job and gettin' it done! Good to see. When painting the frame, there are some box sections that could use the wand style sealer or paint to coat inside. It's lasted this long, but a little extra effort will make it rust proof.
    This is just an example. I'd look for other cheaper solutions.
    https://www.tptools.com/TP-Tools-Rustproofing-Gun-with-Wands,8288.html
    tr_rodder and gas man like this.
  18. gas man
    gas man
    from socal
    20250622_174323.jpg Primed and painted the frame. Upol brand.
    Now comes the fun part of putting it back together.
    Deutscher, mvee33, Okie Pete and 3 others like this.
  19. Grumpy ole A
    Grumpy ole A
    Looking good, can hardly wait to see it coming together.
  20. gas man
    gas man
    from socal
    Should I put the body on the frame to do the c-notch ? Im thinking it will hold the frame in place and I will see exactly where to cut floor . Or am I worrying to much ?
  21. Heat moves metal. It’s just fact.
    We had ch***is clamped to very heavy benches.
    Still moved.
    Won’t make a difference.
    How you weld it does
    Welding the inner c-notch last yields the most movement in my experience. Welding long continuous welds seems to move more.
    The more experience ch***is guys can chime in
    I’ve had the best luck doing like 1 inch welds and moving around
    Deutscher, Okie Pete and tr_rodder like this.
  22. gsnort
    gsnort
    Have had a '35 Plymouth coupe for 26 years. I dropped a SBF in it. Runs like a scalded dog.
  23. gimpyshotrods
    gimpyshotrods
    I built this at a shop where I worked about 14-years-ago.
    It lives in Germany now.
  24. gas man
    gas man
    from socal
    Got anymore info on that front end ?
  25. gimpyshotrods
    gimpyshotrods
    Forbidden here.
    PM me for details.
  26. gene-koning
    gene-koning
    The painted frame looks great.
    If you knew you were going to modify the frame, why did you paint it before you did the modifying?
    Now you will need to grind off the new paint before you can weld to it, and then you will need to paint part of it again.
    May I suggest that maybe you hold off repainting the frame until you are completely done with the modifications? That would include the modification for the front suspension, any motor mounts, a possible transmission mount or crossmember installation, possible brake & master cylinder mounting stuff, and the "C" notch.
  27. gas man
    gas man
    from socal
