Projects Building a 57 Chevy Shop Truck
Discussion in 'The Hokey Ass Message Board' started by swade41, Nov 1, 2017.
  1. swade41
    swade41
    from Buffalo,NY
    I started permanently bolting it all together using a stainless bolt kit
    Real happy with the fitment of all these mismatched body panels
    Indexed all the bolt heads, just because
    I had to heat, pry and hammer the one remaining metal tailgate hinge out so I could clean that up and install new hinges, now I have a working tailgate.
    LAROKE, porkshop, Torkwrench and 3 others like this.
  2. swade41
    swade41
    from Buffalo,NY
    I was having no luck finding any used 31x10.5's to try out but I did run into a friend at a cruise night that was changing rims on his ride.
    He happened to have the same exact rims I had just bought (of course) with 275/60/15's. He shot me a decent price so I bought the rears, fronts were 15x7.5 and I had no use for those.
    I wanted just a little taller tire to tuck the top of the tire behind the fender lip but these actually worked out pretty good.
    20250601_165219.jpg 20250601_165001.jpg 20250601_165036.jpg 20250601_171236.jpg
    Mr.Norton, LAROKE, 4 pedals and 14 others like this.
  3. swade41
    swade41
    from Buffalo,NY
    Short video walk around
    LAROKE, chevy57dude, porkshop and 6 others like this.
  4. swade41
    swade41
    from Buffalo,NY
    Finally decided on a stain color for the bed wood and ordered it, some brushes and urethane.
    I was reading up on the acceptable humidity levels to stain and coat, it was 68% today so I didn't even set up the bed wood like I planned, hopefully it goes down by the time it all comes in.
    I'm not a carpenter so I'm only going by the internet recommendations, don't want any curling boards.
    porkshop and impala4speed like this.
  5. Johnny Gee
    Johnny Gee
    from Downey, Ca
    You are applying finish to both sides right?
    porkshop likes this.
  6. swade41
    swade41
    from Buffalo,NY
    Yes and the stain too, want to totally encapsulate the wood.
    I must have watched a hundred videos with a few different techniques to get the general idea of what to do. I'll be brushing the stain on, it seams like doing the swirly with a rag leaves blotchy sections, so the brush is for me.
    I seen one video where the guy was pouring the urethane right on the board then using a bondo spreader to level it out, lots of different ways to skin a cat.
    porkshop and guthriesmith like this.
  7. swade41
    swade41
    from Buffalo,NY
    Sanded all the boards with 220
    I started on the bottom of the boards to practice and to test how long to leave the stain on before wiping it off.
    20 minutes far left board, around 12 on far right.
    Next 4 boards I let the stain sit for 10 minutes, looking better
    Practice is over, time to do the tops, I let the stain sit for 5 minutes and like it.
    Some weird little shiny spots showed up in certain angles of light, they would disappear once wiped over with the stain rag but would return a few minutes later.
    Tomorrow I'm starting the urethane regardless of those weirdos.
    Screenshot_20250608_182150_Gallery.jpg Screenshot_20250608_182129_Gallery.jpg
    LAROKE, porkshop, Dooley and 5 others like this.
  8. swade41
    swade41
    from Buffalo,NY
    Well, the stupid spar urethane totally changed the color of my stain, I really liked that gray too and it took me awhile to decide on a color, all for nothing.
    20250610_161735.jpg Screenshot_20250610_125620_Gallery.jpg Screenshot_20250610_125431_Gallery.jpg
    Tomorrow I'll do the tops and learn to live with it, I think I'll call it baby **** brown.
  9. 427 sleeper
    427 sleeper
    How about "Dark as Dog ****"?:p
    porkshop and swade41 like this.
  10. Johnny Gee
    Johnny Gee
    from Downey, Ca
    You’ll grow to like it.
    porkshop, swade41 and 427 sleeper like this.
  11. swade41
    swade41
    from Buffalo,NY
    But the gray would've been so much better, by the end of the week I hope to have it at least laying in the truck to see how it is. I figure I'll give it a few days drying time before bolting it down, I forget what the can says about how long it takes.
    porkshop, Moriarity and guthriesmith like this.
  12. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Is your finish oil based?
  13. swade41
    swade41
    from Buffalo,NY
    Yes, this is what I used
  14. swade41
    swade41
    from Buffalo,NY
    Is it true that in California you can only get water based products ?
  15. guthriesmith
    guthriesmith
    Man, it did change the color a lot. I think it will still look good though.
    swade41, 427 sleeper and Moriarity like this.
  16. Johnny Gee
    Johnny Gee
    from Downey, Ca
    I was going to suggest tinting the poly with gray oil base stain then spray it on. I’ve done this with brown tones of stain. But this morning after sleeping on it, I’m afraid that a gray toner would make the finish look milky.
    Yes, there’s still oil poly available. However oil paints and real paint thinner isn’t.
  17. Bandit Billy
    Bandit Billy
    Well what's done is done. I like using high solids, automotive clear for this reason. Goes on clear and stays that way. A lot of topcoats for wood are yellowish out of the can.
  18. Bandit Billy
    Bandit Billy
    BTW, still looks nice IMO
  19. swade41
    swade41
    from Buffalo,NY
    I started out bright and early to avoid the late night final coat but had to spend a couple hours cleaning up my drips.
    I ran the brush on the underside after every coat but still got got them, I guess it just keeps moving longer than I thought.
    I was able to use a plastic putty knife and s****e them down.
    Then I used a mineral spirits soaked rag to clean it up further
    Hopefully wrap this up around 11 p.m. tonight, there's so much cottonwood fuzz flying around that I can't even open the garage door to sneak out to a cruise night in the meantime. Some yards look like they're snow covered.
  20. swade41
    swade41
    from Buffalo,NY
    Laid some of the boards in the bed to see how it goes with the paint or lack of and it just looks green/yellow/brown, if the truck was olive drab then it might look OK.
    I thought maybe the l.e.d. lights might be effecting the color so I took a board outside, looks more brown and less green.
    rod1, guthriesmith and Johnny Gee like this.
  21. swade41
    swade41
    from Buffalo,NY
    Then I decided to try some of the gray stain on the underside of the board to see if it did anything. At first I didn't see much of a difference, took it and another board outside for a side by side comparison, again I didn't see a drastic change.
    Took it back inside and laid it over a couple of the other boards and it looked a little better.
    So the next thing ya know I'm staining the tops of the boards
    Still no where what I wanted but it's better
    And a little side by side comparo of before and after
  22. swade41
    swade41
    from Buffalo,NY
    Mocked up the wood and stainless, the cross braces under the wood line up with the wood and the holes in the frame but DON'T line up with the stainless strips.
    They're off enough that the bolt has to go in at an angle and of course the carriage head won't sit flush. I'm going to see if I can draw them in, if not I'm going to have to open the holes up and hopefully the nut doesn't jam up against the side.
    LAROKE, LOST ANGEL and guthriesmith like this.
  23. patsurf
    patsurf
    turn them end for end;):confused:
  24. swade41
    swade41
    from Buffalo,NY
    You can't, the front takes 2 bolts
    And the rear only takes one
  25. 57tailgater
    57tailgater
    from Georgia
    A lot of bolts for the strips, bed angles, cross sills and bed front panel to line up for sure! You're making good progress. Too bad about the stain color struggles. Keep up the good progress!
    427 sleeper and swade41 like this.
  26. swade41
    swade41
    from Buffalo,NY
    Well 82 bolts and my first case of VERTIGO later the bed wood is fully bolted in.
    That vertigo is some crazy stuff, first noticed it just rolling over in bed on Tuesday morning, thought maybe it was blood pressure related because of my heart condition. A couple more spinaroonies during the day made me realize what was going on, did the Eply maneuver a few times and it wasn't as bad.
    Wednesday I thought I had it licked so I went to work back under the bed, about 45 minutes in I dropped a washer while laying under the truck, looked to my left and BAM it hit again. I called it quits and back into the house, more of those evasive maneuvers, next day I didn't feel so bad so I sit behind the truck and did the 14 bolts I could reach, no way was I laying on my back again lol.
    Eventually I worked my way through it by keeping my head propped up while laying under and making sure I didn't drop anything again.. lol
    If you remember this carnival ride, that's what vertigo feels like
    chevy57dude, Budget36, rod1 and 7 others like this.
  27. Johnny Gee
    Johnny Gee
    from Downey, Ca
    I hate that feeling. Had it Friday doing front alignment on the red 56.
    chevy57dude and swade41 like this.
  28. swade41
    swade41
    from Buffalo,NY
    I couldn't believe how off balance it makes you feel, mentally you know you're laying flat on your back, but physically you're trying to hold onto something to keep from falling.
    Stupid moving ear crystals, as far as I'm concerned it can come back in another 59 years and visit me then.
    porkshop, chevy57dude, rod1 and 2 others like this.
  29. swade41
    swade41
    from Buffalo,NY
    Getting close to seeing if the crooked 307 will run or not
    I flushed the block and it was surprisingly very clean inside, I wonder what was done to this thing in the past
    I hooked up a temp and oil gauge that I had on hand, also dug through the stash and found pulleys, low mount alternator mount and an alternator, even a fan belt that fit.
    I grabbed the old radiator I had used in the 41, found radiator hoses that fit, left over antifreeze that I had drained out of that radiator, some decent looking sparkplugs, then got bamboozled by the distributor I was going to use. Turns out the hei that came in one of my past motors was set up to to be used with an MSD box, but I did go ahead and find TDC and stabbed the distributor in for now.
    Not bad for just digging through my junk in the garage
  30. swade41
    swade41
    from Buffalo,NY
    Got a different distributor ........
    And we have a runner, didn't even adjust the distributor or the carb, tomorrow I'll make up some fuel lines, time it and let it run longer.
    I did bottle feed it longer after the video and it ran pretty good for a mystery motor.
