Projects Building My First Roadster in San Francisco
Discussion in 'Traditional Hot Rods' started by J.Ukrop, Sep 7, 2020.
Tags:
  1. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    You'll note in that last image that the fan is too far from the radiator. That bugged me, so I spent some time trying to get everything within spec. I have yet to torque down the front motor mount bolts, and I understand the biscuits will settle too. I'd like to think that will get everything where it needs to be. If it doesn't, I'll modify the radiator brackets.
  2. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    The blocked off grille gives it a competition look, don't you think?
    A little bit-o-little pages.
  3. RodStRace
    RodStRace
    I'd be very tempted to drill the wing nuts for safety wire.
  4. Tim
    Tim
    from KCMO
    Man what a score!
    I love reading anything you write but these weekend updates are always such a great snap shot.
    I’m curious if there isn’t enough meat in those wing nuts to try putting a standard tap through one of the spares to see if it works. I don’t think anyone’s gonna walk around the car with a micrometer checking bolt head sizes or anything but ya already got the cool slotted screws holding the rest together.
    Just thinking out loud.
    drdave, winduptoy, Six Ball and 2 others like this.
  5. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Last, and maybe least, I finally painted the grille shell to match the body. Authentic Loyola Terrace dirt was used.
    Now, with the old headlights. The shell will get bolted on this week.
    Alright, now that brings us up to date!
  6. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    So, the question some be asking is "What's next?" First off, I'll be bolting the grille shell into position and attaching the battery box to the frame. Then, I'm installing the steering box and headers and doing a whole lot of torque wrench work.
    I'm going to be super busy with work and life for the next two weeks. Then, it's full steam ahead. I'm saying it right here right now: the body will be on by the end of the month. In July, it's getting plumbed, wired and, if all goes to plan: fired.
    Speaking of wiring: does anyone have a favorite simple diagram for a 12V negative ground, flathead V8 with a PowerGen? I'll be reusing all lights/horn wiring from Version 1.5, but I'd like to start fresh for the rest. Any insight is greatly appreciated!
  7. Tim
    Tim
    from KCMO
    Man I bet after a couple months of driving that grill looks totally different and even better matching!
    no favorite diagram but I have a felling Difalco has one nailed up on his wall that’s just right.
    J.Ukrop, Outback, Kelly Burns and 3 others like this.
  8. Mikko_
    Mikko_
    from Sweden
    If it was tough painting over the old paint on the shell you could just think of it like
    adding another layer of history to it.
    J.Ukrop and Six Ball like this.
  9. 41 GMC K-18
    41 GMC K-18
    Hey @J.Ukrop
    Hey Joey, as ever you are making superior progress at a rapid rate. It appears that you deserve to get some links to some music that is made for the final roadworthy 2.0, or what ever rig you are tooling around in.
    So trust this 72 year olds choices, on what is kick**** jazz and funk wise, that will make you want to drive fast and take chances, and most definitely want to dance. I am sure your Girlfriend will agree with these choices once she hears all of them. Enjoy from Dennis.
    pineknot4, J.Ukrop and trevorsworth like this.
  10. Beanscoot
    Beanscoot
    I want to see pictures of the Pacific Heights Hardware cat!
    If the wing nuts are 10mm and your bolts are 3/8 NC, they'll thread on sloppy but good enough for as tight as you can get with fingers.
    J.Ukrop, winduptoy, cactus1 and 4 others like this.
  11. Dick Stevens
    Dick Stevens
    Best choice would be to use metric bolts that match the wing nuts, or buy SAE wing nuts and SAE bolts! Grind the markings off the head of the bolts and the only one that will know that you are using metric fasteners is you and whoever you tell that you did it.
  12. Six Ball
    Six Ball
    from Nevada
    Don't go down the rabbit hole of making stuff look like something it is not. That brings dishonesty to a great build just to appear to be period correct. If someone "in the day" had come across those (while serving during WWII in Europe?) he would have used them without a though. That is traditional! If you are really concerned go to the next size up and rethread the wing nuts. That too is traditional and period correct. 2fer1 :eek:
  13. warbird1
    warbird1
    And the wing screws on all those old hose clamps...
    41 GMC K-18 likes this.
  14. kustomkat1950
    kustomkat1950
    from Coastal GA
    Joey, this thread rocks.
    Been thru some***** this past week (lost my father and father in law), and your build is a great distraction.
    Hug your kids, call your moms, patch up sour relationship. We only have one go around in life, make it count!
    rod1, J.Ukrop, osage orange and 6 others like this.
  15. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Justin, I'm so sorry for your loss. Thank you for all your support as I chip away at this project. I took your advice to heart and spent some time on the phone with some of my favorite people today. You're right about making it count!
    The 39 guy, rod1, Six Ball and 4 others like this.
  16. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Thank you everyone for the sound advice about both music and hardware. I have some fun solutions that I'll be sharing down the line.
    On Monday, I started torquing down the rear shackle hardware using my traditional torque wrench. IMG_9923.jpg
    Then, last night, I stayed up a little too late working on the car. I know that I need some of these extra pushes to make steady progress.
    It took me so darn long to install the grille shell. The more I messed with it, the more I realized that it was either raked too far back or there was too much clearance between the radiator and fan. After what may or may have not been two hours, I finally devised a solution where both the shell and radiator tabs had to be modified. Yet, at the end of the day, the fan is 3/4-inch from the radiator and the grille shell is looking good. As a reward, I installed my headlight bar.
    BigJoeArt, dwollam, enloe and 12 others like this.
  17. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Remember that part about the push? Right when I should have gone to bed, I torqued down the front shackles and started installing cotter pins.
    Not just any pins, either. No way. These are the NOS cotters from my friend @So Cal Brian B. Every piece of this car has a story—down to the cotter pins.
  18. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    One last note before I sign off. Last week when I was in Boston, I checked the H.A.M.B. and came across this incredible illustration by @gilty in the Friday Art Show. It made me so happy seeing our old friend, Version 1.5, in all his high-riding glory. Tyler captured every detail, from the B.F. Goodrich safety medallion from the antique store in Washington to the San Francisco waterslide decal in the corner of the windshield. Really neat stuff!
    BigJoeArt, Silva, razoo lew and 25 others like this.
  19. Tim
    Tim
    from KCMO
    Man that’s killer! The color and texture of the piece really adds to the vibe! Great updates man :)
  20. ModelAMitch
    ModelAMitch
    Keep em coming Joey, the cars coming along great!
  21. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Thanks everyone! Yesterday I dropped my rear wheels at Paul’s Tire on Geary. Early next week, he’ll be installing fresh tubes and balancing everything up. I brought an extra 16-inch steelie in case one of the original two are too far gone. I’ll be interested to see if that’s the case.
    Last week, I pulled the trigger on a set of full wheelcovers from an old 1940 Ford. They’re 16s and a little rough, but potentially a fun option. I’m still loving my beanie caps and rings. Always nice to be able to play around with this kind of thing.
  22. Tim
    Tim
    from KCMO
    Very cool! I almost never see full covers for 16’s! Good score
    Outback, Six Ball, J.Ukrop and 2 others like this.
  23. dumprat
    dumprat
    from b.c.
    I have to say I think it’s sad after all the cool stuff you have done on this car you fake patina the grill. It would be so much more legit and better looking to scrub the whole thing down and make it one colour. Even if it’s done with a brush or rattle cans.
  24. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Well, please don’t be too sad. I did the same thing to the decklid about 130 pages ago, as well as the cowl top last summer. My neighbors and I are all painting the car one color once it’s****embled and running. Everything in due time.
    dwollam, enloe, GirchyGirchy and 15 others like this.
  25. Outback
    Outback
    from NE Vic
    Great work Joey, it's really coming together
    winduptoy, osage orange and J.Ukrop like this.
  26. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Thank you! Slowly but surely, we’re making progress.
  27. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    My flight just landed at SFO and I’m about to head back to the house. I believe I have a few small pieces waiting for me, and my rear wheels will be ready for pickup tomorrow.
    I’m excited to get back out there and get wrenching.
  28. Tim
    Tim
    from KCMO
    Hot dog! Get after it man :)
  29. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    When I get my rear wheels back, I'm thinking it'll be time for a recreation of this shot out on the cul-de-sac.
  30. winduptoy
    winduptoy
    I'm wanting you to get it back on the road as I am having an itch to bang to Cali for your maiden outing
    Outback, pprather, Tim and 1 other person like this.
