Projects 1950 plymouth special deluxe (motor swap)
Discussion in 'The Hokey Ass Message Board' started by Bluebell7727, Jun 4, 2025.
  1. Bluebell7727
    Bluebell7727
    Let's stir the pot of purist. I'm looking for pics and tech on doing a v8 swap in a 50 plymouth. Please post pics and tech of sbf/sbc.... and chrysler v8s . Now I know this is gonna get some flax from the purists but I'm looking for all options
    Tow Truck Tom and 51 mercules like this.
  2. Bluebell, what's this purist bit? This IS a hot rod site!
    Ben
    Moriarity, 6inarow, oldsmobum and 4 others like this.
  3. proartguy
    proartguy
    from Sparks, NV
  4. Bandit Billy
    Bandit Billy
    There is a lot of cool MOPAR power out there but put a SBC in it and keep the hood closed. No one needs to know.
    oldsmobum, rod1 and Budget36 like this.
  5. We don’t care about original
    bschwoeble and Budget36 like this.
  6. choptop40
    choptop40
    Only real issues for a Chevy V8 are the exhaust manifold driver side clearance and the distributor clearance if you keep suspension and steering stock..fender well headers resolve exhaust , a torch and big hammer the firewall....
  7. gene-koning
    gene-koning
    This could go off topic really fast.
    There isn't a huge deal swapping a V8 motor into a 50 Plymouth. Pull the inner fenders, they will need to be modified any way.
    Then the biggest issue is having exhaust clearance on the steering shaft. Shift what ever motor you choose towards the p***enger side about 1.5" often solves the exhaust clearance issue. The only other issue may be the right side (p***enger side) cylinder head clearing the firewall. A few correctly placed swats with a BFH will often solve that clearance issue. Then you can put what ever V8 your little heart desires in the hole. Some motor/transmission combos require more effort then others, but with a welder and a torch, and some know how, putting any motor in the 50 Plymouth, probably isn't impossible.
    Old or modern Hemi, big block Mopar, small block Mopar.
    Big block Chevy, LS Chevy, small block Chevy.
    FE Ford, 428 Ford, 429 Ford, Windsor Ford, 5.0 Ford.
    Oldsmobile.
    Buick.
    Caddy.
    Pontiac.
    You get the idea.
  8. Bluebell7727
    Bluebell7727
    Point taken, I was meaning the keep it in the family . Ford in a ford or chrysler in a chrysler ect
  9. bobss396
    bobss396
    I have seen some very sanitary 318/360 swaps done with Volare and Cordoba front clips in '46 to '53 Mopars.
    caprockfabshop and das858 like this.
  10. Matt Dudley
    Matt Dudley
    from New York
    Slant 6s and 318s are pretty common swaps. It’s covered a ton in various forums if you search. The 23” flathead is a very compact engine. The smallest V8 is going to fit the best.
    I’ve hemmed and hawed about putting a Mercruiser/ Chevy 153 in my ‘51. It runs and drives but the engine is a little tired. I have a 230 that needs gone through, but I have a couple running boat engines and the manifold to put one in a car.
  11. Put what ever fits
    could care less about the family
    Tow Truck Tom likes this.
  12. rustydusty
    rustydusty
    A few years ago I had a ‘50 Dodge that a previous owner had installed a 318/727 combo into it. The engine was shifted an inch or two towards the p***enger side, block hugger headers cleared the steering box, and I had to modify the p***enger side fender well just to be able to change the spark plugs. (Don’t know how the P.O. did it, or maybe he never did). The combo worked great, and I wish I could have kept it… 5A2928D7-DAB7-4E61-888B-67FA24635C41.jpeg B07DEDA1-DF0C-4601-820B-8965480D3630.jpeg
    Tow Truck Tom, rod1, bobss396 and 3 others like this.
  13. Paladin1962
    Paladin1962
    Get two Olds Toronados...
    oldsmobum likes this.
  14. F-ONE
    F-ONE
    from Alabama
    Awwww
    Leave the purists alone. They are an easy target. It's kind of like winning a track meet or worse, the boxing match at the local nursing home. Sure, you may get a trophy, and maybe some sugar from Miss Congeniality 1952, but have you really accomplished anything?
    The low priced Mopars were tip top in the 1930s but by the early 50s they were long in the tooth.
    You are going to have the issues with steering clearance.
    You will have to change transmissions.
    You will have to change the rear axle.
    You will have to address the front brakes.
    These issues above are why the flat 6 hung around so long in these cars.
    Stan Back likes this.
  15. gene-koning
    gene-koning
    This is coming from a Ford guy...
    Wouldn't be much different then if you wanted to remove the flathead V8 and install a real motor in your shoe box. :p :D
    You would probably change the motor, the transmission, and the rear end (because the old stuff couldn't take the higher HP), upgrade the brakes (because you really may want to be able to stop), and modify what ever needs to be modified, so your preferred motor fits and functions as desired.
    You either get with the program, or stay in the garage pouting because its "too much work," but the old motor is wore out.
  16. proartguy
    proartguy
    from Sparks, NV
    There would probably be many the same issues in Fords and Chevys of the era when swapping drive train.
    Stock steering and column shift retained in my 318/904 swapped ‘51.
    Part of the reason a lot of old MoPars still have the 6 cyl flathead is they are well engineered and drive good. My ‘46 had a hopped up 6cyl with an overdrive and was a very nice performer.
    Paladin1962 likes this.
  17. 51 mercules
    51 mercules
    Needs a hemi!
  18. choptop40
    choptop40
    some inspiration.....I did sit it back a bunch... Screenshot 2025-06-04 10.39.42 PM.png
  19. Paladin1962
    Paladin1962
    Wisconsin V4's in tandem
  20. rustydusty
    rustydusty
    How about some pictures?
  21. KenC
    KenC
    Like others have said, any compact V8 will work best. But there have been hemis and big blocks stuffed in there.
    Now, if a driver with good performance is the goal, not race quality, just keep up with traffic quality, maybe think of a modern V6. A RWD Dakota would be easy. Pick an early version with the hydraulicly controlled version of the OD auto and it would provide adequate power, as compact as possible and light weight. The power shouldn't overwhelm the original rear end and the OD would work well with the original ratio. Should be a 3.73 or so, but some may be 4.10 or 3.54s. I think that depended on whether equipped with OD and maybe the state originally sold, mountains vs flatland.
    The same advice is needed regarding location though. Shift to the p***enger side 1-1.5" to clear the steering.
    Lots of factory Mopars are located like that from the factory.
  22. Bluebell7727
    Bluebell7727
    Thank you for all the replies. Still kicking around the swap ideas.
  23. Stan Back
    Stan Back
    . . . and then you have to figure out a parking brake if you keep the original rear end, right?
    51 mercules likes this.
  24. southerncad
    southerncad
    How about milling the head a little, dual carbs, headders, and twice pipes with some gl*** packs and your done, and if you really want to cruise on the highway, add an O/D ******.
  25. Use a motorhome auto and ya get a parking brake with the trans :)
  26. Paladin1962
    Paladin1962
    Mama MoPar was looking out for future rodders all along
    anthony myrick likes this.
  27. KenC
    KenC
    A pinion mounted disk is one option. I have most of the parts, but I'll probably just not use one at first, if I ever get motivated to finish the project.
  28. Bluebell7727
    Bluebell7727
    So quick up date, picked up a 400sbc out of a 78 gmc camper van. Also got a 8 1/4 rearend out of 71 dodge charger. So it'll be getting a sbc400 with probably a powerglide or th350 will post some pics soon!
    bobss396 and Tow Truck Tom like this.
  29. scrap metal 48
    scrap metal 48
    SBC in a 53 Plymouth... **clic pics** 100_4394.JPG 100_4395.JPG 100_4386.JPG
