Projects 1946 GMC Bonneville build
Discussion in 'The Hokey Ass Message Board' started by Marcia, Aug 26, 2020.
  1. Marcia
    Marcia
    On our way to Loring, I drove it onto the scales. PXL_20250605_124619424.jpg PXL_20250605_135749934.MP.jpg
    Stogy, Sharpone, jnaki and 18 others like this.
  2. Dave G in Gansevoort
    from Upstate NY
    Great looking truck! Here’s to a successful weekend with it.
    Stogy, Sharpone, 41 GMC K-18 and 2 others like this.
  3. Marcia
    Marcia
    We start racing on Monday. I'll post timing slips, good or bad.
  4. Marcia
    Marcia
    Thanks!
  5. 05snopro440
    05snopro440
    Wow, surprisingly it's a few pounds (230) lighter than my street driven 46 GMC (weighed full of fuel).
  6. Six Ball
    Six Ball
    from Nevada
    Looking forward to results. Good luck and be safe!
  7. 41 GMC K-18
    41 GMC K-18
  8. For those about to rock, we salute you.
    Stogy, Sharpone, Just Gary and 3 others like this.
  9. Marcia
    Marcia
    Our first p*** at Loring, taking it easy. I wanted to see if it drove okay, shifted okay . I set 3 new records.
    The second p***, I went for it. I had 3 perfect shifts and then the tac started going the wrong way. We lost a lot of oil and we're done for this event.
    Stogy, Chucky, tractorguy and 12 others like this.
  10. 51504bat
    51504bat
    Hate it when the Tach does that. Sounds like things went OK before that. Hope you get it sorted before Bonneville.
  11. Marcia
    Marcia
    We'll bring it back here in July.
    Stogy, Sharpone, Just Gary and 6 others like this.
  12. riv63
    riv63
    from Texas
    Congratulations/ condolences.
    Sure is a nice looking little pickup.
  13. Marcia
    Marcia
    Thanks!
  14. Marcia
    Marcia
    The pistons just arrived. Do we have enough time to build a motor and get to Bonneville? We're getting too old for thrasher 18 hours a day!
    Stogy, Sharpone, bobss396 and 9 others like this.
  15. Marcia
    Marcia
    FB_IMG_1753455411442.jpg On a brighter note, we picked up the 3 record certificates while we were at Loring Timing ***ociation.
    Stogy, jnaki, Sharpone and 21 others like this.
  16. 41 GMC K-18
    41 GMC K-18
    Bravo ! Most impressive indeed!
  17. lothiandon1940
    lothiandon1940
  18. Marcia
    Marcia
    Thanks!
  19. Marcia
    Marcia
    Thank you!
  20. Okie Pete
    Okie Pete
  21. Six Ball
    Six Ball
    from Nevada
    Sure you can get it done! It's just pistons, you don't even have to pull the engine. :D
  22. riv63
    riv63
    from Texas
    Sweet deal on the records. Absolute bummer on hurting the motor. Good luck getting it back together.
  23. Marcia
    Marcia
    We made a couple of p***es at Loring but we ran on the middle runway and it wasn't compatible with my suspension setup. We took air out of the tires but it wasn't enough. We'll do some more work when we get home and then head to World Finals at Bonneville.
    We set three more records but we need to go a lot faster. FB_IMG_1757337504411.jpg PXL_20250905_182704588.jpg
    SS327, Stogy, LCGarage and 26 others like this.
  24. Six Ball
    Six Ball
    from Nevada
    Beautiful record setting truck! You are just beginning to the fun part. Good luck at Bonneville.
  25. Marcia
    Marcia
    Thank you!
  26. Dave Gray
    Dave Gray
    Marcia and Frank. Congratulations on your records. More to come I am sure. Dave
    Stogy, lothiandon1940, Marcia and 2 others like this.
  27. ronnieroadster
    ronnieroadster
    Considering the last minute change required for the runway you certainly did great. Heck when we flat tow our car back on that runway its so rough I could never run our car on that surface. It would be a very bad idea. See you both at Hershey.
    Ronnieroadster
  28. Marcia
    Marcia
    Thanks Dave!
    Stogy, chryslerfan55 and 41 GMC K-18 like this.
  29. A pickup I would be proud to use as a Daily Driver. You "done" good.
    Ben
    SS327, Stogy, chryslerfan55 and 2 others like this.
