Technical Cragar magnesium 348/409 blower intake?
Discussion in 'The Hokey Ass Message Board' started by 123, Apr 7, 2021.
  1. 123
    123
    from Seattle
    Trying to ID this intake I ended up with in a trade. I'm just looking for confirmation that it is a 348/409 intake and what would a ballpark value be on it in its current condition.
    I'm more familiar with mopar engines so I'm just matching the runners and bolt holes with pictures of gaskets and 348/409 is the closest I have found.
    Last picture is a drop of vinegar to see if it was aluminum or magnesium.
    VANDENPLAS and Deuces like this.
  2. Deuces
    Deuces
    Very cool.:cool: and very rare.....;)
    mad mikey likes this.
  3. Bob Lowry
    Bob Lowry
    Bolt pattern is that of a 348/409". with the lower performance, smaller valve heads. The difference
    between this intake and the high performance heads is that on the high performance heads and intake
    the intake runners are a complete rectangle. Lower performance heads and intake have the intake bolt in the center
    of the two intake p***ages. Still a cool intake and does have value. Might check and see what current
    new items are listed for to give you an idea. Nice score!
    Deuces likes this.
  4. Moriarity
    Moriarity
    SUPER MODERATOR
    too bad someone hacked that road draft tube through the cragar logo... looks like the ports have been ground on? you are going to have to get gaskets and lay them on there to see what it is. the upper bolts are spaced higher on the HP 409.
    here is a 348 gasket
    here is a 409 gasket
    mad mikey, VANDENPLAS and Deuces like this.
  5. Deuces
    Deuces
    I learn something new every day on here.... Thanks!... :)
  6. Mike VV
    Mike VV
    from SoCal
    Agreed, while the bolt pattern appears correct for the 348 or low/standard performance 409 heads, the port opening seems awful wide, like they've been opened up quite a bit.
    See the opening sizes in the gaskets shown above.
    Mike
    Bob Lowry and Moriarity like this.
  7. 427 sleeper
    427 sleeper
    Look's like a regular 'ol Big Block Chevy with a soup can stuck to the bottom. The ends of the manifold don't look like a W-Motor.
    Moriarity and 1933_willys_77 like this.
  8. ROADSTER1927
    ROADSTER1927
    This is a bottom of a 409 low perf intake. Gary thumbnail (46).jpg thumbnail (46).jpg thumbnail (46).jpg thumbnail (47).jpg thumbnail (49).jpg
    Deuces, 123 and 427 sleeper like this.
  9. SS327
    SS327
    That’s what I thought too. But I’m on a dumb phone.
  10. greybeard360
    greybeard360
    You can tell by the end gaskets it isn't 348/409.
    Rectangular port BBC.
    123 likes this.
  11. 123
    123
    from Seattle
    I thought regular big block myself at first but the port design and bolt holes led me to 348/409.
    Coolant p***ages have been epoxied at some point and that funky road draft tube installed. Ports are all hogged out and uneven but all pretty much the same size. I'm sure this thing has some stories to tell.
    Here are some more pictures...
    Deuces likes this.
  12. Moriarity
    Moriarity
    SUPER MODERATOR
    yup, how silly of me, sure its a BBC, still too bad someone stuck that breather in it....
    SS327 and 123 like this.
  13. 123
    123
    from Seattle
    I've been debating if it is even worth removing the tube and welding up the hole but seeing as how it is right in the middle of the Cragar logo and who knows what quality of magnesium they used so it might make it worse.
  14. Jtaylorok327348
    Jtaylorok327348
    What did you do with this mani ?
  15. 123
    123
    from Seattle
    I sold it at a swapmeet a few years ago.
