Technical HELP wheels won’t fit Chevy rear end.
Discussion in 'The Hokey Ass Message Board' started by Travis latour, Jun 8, 2025.
  1. Travis latour
    Travis latour
    from Putnam CT
    So like the ***le says I’ve been banging my head against the wall. So the car has a GM rear end casting number 3707306gm7. But the Bolt pattern does not measure 5x 4.75. It’s more like 5x 4 11/16. My buddy’s Chevy steel wheel didn’t fit, both early ford and new ford steelies didn’t fit. Is there another bolt pattern that I am unaware of??? Thanks in advance
  2. squirrel
    maybe you could move the camera back a ways, so we could see the whole rearend? from a few different angles. and also what you're measuring from.
    I bet it's really a Chevy rear end, and there's something funky with the wheels you're trying? but more pictures would sure help us help you figure it out.
    (the casting number is the 55-64 style drop out center Chevy rear)
  3. fastcar1953
    fastcar1953
    Late model with metric studs? Seeing how you measure stud would help. BoltPattern3.jpg
  4. Johnny Gee
    Johnny Gee
    from Downey, Ca
    What Chevy steel wheels did your buddy lend you? GM went to a smaller metic 5 lug pattern around the turn of the Centry.
  5. Travis latour
    Travis latour
    from Putnam CT
    Yeah I tried to upload a picture of how I was measuring it but the picture was too big. I knew those comments were coming…… I’m measuring it correctly. Like fastcar1953’s picture shows. I’ll try and upload some more pictures but I guess my camera is too good lol
  6. Travis latour
    Travis latour
    from Putnam CT
  7. fastcar1953
    fastcar1953
  8. ronzmtrwrx
    ronzmtrwrx
    There's sure not much of the center sticking through the drum either. Looks a little odd. Maybe it's just the angle I'm looking at it.
    lemondana likes this.
  9. fastcar1953
    fastcar1953
    Looks like chevy 5 x 4 3/4. Tape measure looks a little off.
    Do the wheels fit but just the wrong pattern?
    Most metric rear ends would have disc brakes.
    Lug nuts std or metric? That would help.
    jazz1 likes this.
  10. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Being a wood worker my whole life I have to ask, is the tip of your tape measure bent do to frequent droppings?
    05snopro440 likes this.
  11. Johnny Gee
    Johnny Gee
    from Downey, Ca
    It’s normal, that’s how early 8.2’s with drop outs are.
    1oldtimer and squirrel like this.
  12. squirrel
    Find another wheel that you can verify fits an original 49-70 Chevy car, and see if it fits. It has to.
  13. brading
    brading
    What I would do is to put a wheel nut on the two studs, using a vernier gauge measure the distance between the two nut flats, call this measurement "A". Measure the width of the nut, call this measurement "B". Take half the measure "B" from measurement "A" and you have an accurate measurement.
    '28phonebooth likes this.
  14. Torkwrench
    Torkwrench
    The drum looks like a 55 - 64 Chevy p***enger car. As does the end of the axle shaft.
    Does the axle housing have a drain plug? If it does not, it's a 55 - 56 Chevy. If it does have a drain plug, it's a 57 - 64 Chevy.
    SS327 likes this.
  15. Joe H
    Joe H
    Bent stud will keep the wheel from fitting, will the drum come off?
  16. Fordors
    Fordors
    I was at the s**** yard when my housing was torched from a ‘64 Bel Air station wagon, no drain plug, never had one.
    2OLD2FAST likes this.
  17. Mr48chev
    If the lug bolt pattern on your buddy's "Chevy car" wheels is a tad too large he probably has 5 lug wheels off an Impala or Caprice that were five on five. I know from 77 and up into the mid 80's they could come either way, the small brake cars had 5 on 4-3/4 with 11 inch rotors and the big brake cars had 5 on 5 with 12 inch rotors. My wife had a 79 ex cop car Impala 4 door that had 5 on 5 .
    squirrel and lothiandon1940 like this.
  18. squirrel
    5 on 5 started in 1971 on full size Chevys. That's why I suggested you find a wheel that fits an original 49-70 chevy car to check the bolt pattern, to confirm that it is indeed 4.75"
    1oldtimer likes this.
