Technical Paint viscosity question
Discussion in 'Traditional Customs' started by birdman1, Jun 2, 2025.
  1. birdman1
    birdman1
    Do any of you use a viscosity flow device when thinner paint? I'm using summit urethane paint and the thinner i mix it the better it flows. Besides the risk of runs, is it okay to thin it more than the instructions say,? Thanks
    seb fontana likes this.
  2. I’ve never used one.
    I just follow the instructions
    Occasionally I’ll sneak in more reducer.
  3. K13
    K13
    Over reduction can lead to issues like dieback down the road.
  4. jumbogem29
    jumbogem29
    from Alabama
    Same as Anthony said .
  5. Rich796
    Rich796
    Are you looking for better flow, out of the gun. Or, flowout on the panel ?
    anthony myrick likes this.
  6. Zookeeper
    Zookeeper
    If you're looking to maintain the viscosity you like, Zahn cups are not that expensive and if you ever need to touch up a metallic paint they make it much easier to match the panel you painted a couple years ago by keeping viscosity the same. Also, digital scales are handy for the same reason, add reducer by weight, not eyeballing the marks on the mixing bucket and hoping it's close.
  7. slowmotion
    slowmotion
    In the olden days, if you were a regular customer, the supply house would give a viscosity cup, along with a flow chart.
  8. Bandit Billy
    Bandit Billy
    Temp, al***ude and humidity can play a factor but 99% of the time I follow directions. It's one of those "trust the science" things.
  9. Over reduction can be as little as an extra cap full these days.
    overspray likes this.
  10. SinisterSleds
    SinisterSleds
    from MA
    Mix per instructions. As said previously a little extra might be OK. Watch for shrinking, and die back.
    Generally air pressure and flow help with layout. If the paint is going on wet and you feel there is too much orange peal raise your pressure. To dry open the flow.
    Tip selection is important as well. Most high build primers available are being shot from a 1.8 or 2.0 tip.
    All guns are not made the same either. My 1.3 tip on the accuspray is OK for a door or smaller single panel, tough to run even wide open. But the 1.3 tip on my Sata will dump plenty of paint and if your not careful you will be cutting the car off the floor.
    overspray and lostone like this.
  11. tomcat11
    tomcat11
    Yeah there's Zahn cups. I can't remember where it learned from but if you let the paint run off your stir stick it's supposed stream off and then form drops about an inch from the end of the stick. Maybe it's BS but I have done it and it did seem to work and pretty much fit the instructions.
    joel likes this.
  12. seb fontana
    seb fontana
    from ct
    When in doubt I thin it out some, my aura causes the the paint to go on too dry if per instructions:rolleyes:
  13. patterg2003
    patterg2003
    We painted an off topic vehicle. A kitchen scale was used to determine the exact proportions using weight. Tare the container then add a volume of paint. For example if the ratio of paint to thinner is 2:1. Paint being 2 then thinner is 50%. We used grams as it is decimal units that are easier to calculate. (ie) If the paint is 500 grams then the weight of thinner would be 250 grams. It helps to have a calculator. Hardener is calculated the same as well. Have a container for each liquid and tare it or zero it each time with the container on the scale. Pour until the desired weight is reached. We tried using the viscosity cup but it was a pain.
  14. 1971BB427
    1971BB427
    from Oregon
    I'm not a painter, so I always follow mixing directions as close as possible. I don't want to do anything to mess up a paint job by experimenting.
  15. SinisterSleds
    SinisterSleds
    from MA
    Order cups. I pay about $60 per 100.
    overspray, seb fontana and joel like this.
  16. The best advice I got for using an HVLP gun was this.
    Open the fluid knob up all the way.
    Find the happy spot on the fan adjustment.
    Move as fast as ya can
    Overlap more
    bobss396, Rich796 and klleetrucking like this.
  17. Rich796
    Rich796
    I would add to this, get closer ! Most people that haven't done this professionally. Are spaying way too far away from the surface with a hvlp gun. A closer distance to the surface. Translates to faster apply speeds and a finer surface finish.
    When I was taking my PPG certification cl***. If you were more than 4" away from the surface. They were on you to get closer ! and move faster ! They were adamant about it.
  18. joel
    joel
    Good to know. Thanks
  19. Gahrajmahal
    Gahrajmahal
    I just sprayed my Avitar Chrysler 300 overall this past fall. Amazingly I was able to rent a local body shops paint booth. It was warm in there, maybe 80 deg. But unlike spraying in the driveway where the sun heats up the metal too, it was uniform. The airflow across the car was fast and it ****ed in dust from the through cracks in the walls and opening doors. I used large 3M style PPS cups with a HTE high transfer efficiency gun. If I was to do it over again I would use the largest cup size I could find. Painting cars in the 70’s with a Binks or Sharp gun, the cup size was always large enough to make it all the way around a big car with one fill up. With the PPS system, I was constantly running out of paint in the middle of a panel making it very challenging, and exhausting, to refill the cup and continue spraying. Because of this I had a few runs whereas when I am spraying something smaller I never get runs even though I lay on the paint to make it gl***y smooth. Post up your progress, good luck!
  20. overspray
    overspray
    I paint less frequently than I used to so I'm still using conventional sprayguns . I have noticed for quite a while that most of the new single stage urethanes and clearcoats are formulated for use in paint booths with a bake capability. These products are thicker (higher solids) and made to be applied (per tech sheet) with a small amount of texture/orange peel and the heat from the bake cycle "reflows" the material smoother and flatter. The bake also cures the product faster. When I spray new single stage urethanes and clearcoats, in a NON bake spray booth, I usually over reduce slightly or moderately, depending on the viscosity of the product. I also increase the spraying pressure (conventional spray gun) to atomize (watch your spray tip size) the product to a smaller droplet size and adjust my p*** speed accordingly to minimize orange peel/texture. I will spray some test panels to check my wet out and see how the paint flows out smooth. I watch the temperature, humidity and airflow to see how it affects the "flash off" time between coats with each product I use. I also frequently use a small amount of urethane accelerator to speed the through cure of these new products when spraying without a bake cycle. If I over reduce a product I will usually add 1 more coat of product to the job (clear or single stage), to make sure I end up with recommended film thickness.
    It takes practice and experience to get the reducing of the product, the settings of the spray gun, the speed of your gun p***, and all the other factors "dialed in" to get the results you want. Early on I would make a checklist so I would be thorough when painting and remember all the variables and products I would need before starting to spray.
    I have 50 years of auto paint spraying experience with all types of paint, plus many hours of training from major paint manufacturers--and I'm still learning. Over the years I have seen many very talented painters, much better than I, but only a few with excellent technical product knowledge. I still find and read the TDS/tech info on all the products I use and others, for reference. I also have some very knowledgeable friends and colleagues I can call for support and expert advice--and of course, the HAMB is always a valuable resource.
    If you don't paint very often, be aware that with HVLP you need to have your lines, fittings and air supply/compressor all compatible for the high VOLUME of air in order for the HVLP spraygun to work properly. Sometimes it is NOT the best idea to just go the Harbor Freight and buy a HVLP gun. Here's some good information on purchasing a HVLP spray gun.
