Technical Timing? help, possibly worse?
Discussion in 'The Hokey Ass Message Board' started by OZCAST, Jun 9, 2025.
  1. OZCAST
    OZCAST
    I have a ‘58 283
    Ran perfectly for a long time. Couple years. Out of the blue the distributor came loose, timing out of wack. Reset timing, tightened down, now the darn thing works itself loose every day.
    Get a new hold down, no help. Timing seems to be all out of wack consistency now. today I was test driving, running good. After a mile on the freeway I took the exit and at the stop light it dies and won’t re start. I had to advance the timing a ton to get it going, now runs like garbage at the 10 degrees it historically loved.
    New plugs (same plugs it ran great with)
    Wires all seem good
    MSD box the has blue spark and zapped the hell out of me while I was check king all the connections into the cap
    could The timing chain have too much slack? Possibly bad distributor? Just all happened at once. I’m at a loss. Checked everything I know how to. Wondering if I should do a leak down test to see if I bend a push rod?
    Any next step advice would be a huge help
    Thanks
    VANDENPLAS and Tow Truck Tom like this.
  2. squirrel
    I wonder if a bushing went out in the distributor, and it's seizing?
    Johnny Gee, BJR, studebaker46 and 4 others like this.
  3. OZCAST
    OZCAST
    My only next clue is to pull it. Not sure who can test MSD distributors. Pretty spendy to replace without knowing though
  4. squirrel
    The distributor works, doesn't it, since the engine runs. So you need to see how it turns, is it grabbing, or rough? Is the shaft loose side to side?
  5. OZCAST
    OZCAST
    Ok. I’ll pull it and see what I can find out. Thx
  6. inthweedz
    inthweedz
    At some stage it hasn't had one of them plastic cam timing gears fitted, and now jumped a tooth??
  7. OZCAST
    OZCAST
    Un Sure. I have been thinking through this whole mess, it may be worth a gear drive to nip any slippage in the bud. At some point I’m afraid I’m gunna have to dig deeper than surface stuff. For what it’s worth, the timing marks are dead smooth in the light. No jumping around at all
    Tow Truck Tom likes this.
  8. pprather
    pprather
    Is the distributor off a tooth or two from when it was loose?
    In other words, is rotor still pointing at number one plug wire on distributor cap when piston #1 is at top dead center?
  9. 1934coupe
    1934coupe
    Slow down and take a deep breath, Is the car running now? is it popping back through the carb or muffler? If it has a fiber or plastic cam sprocket it could have broke, but a gear drive is over kill just get a steel timing set. With the timing light on the motor does the timing mark move up (advance) when you Raise the RPM's ? Does it have a wire style hold down or a flat steel fist. hold down, I find the solid steel work better. Do this by the numbers before you sink stupid money on it. 283's are great engines no matter what the Jags and Summit hot rodders say.
    Pat
  10. saltflats
    saltflats
    from Missouri
    Is the distributor physically moving that you have to move it back to where it was?
  11. 2OLD2FAST
    2OLD2FAST
    from illinois
    You'll hate a gear drive , extremely noisy & less accurate than a chain ..like 1934coupe says , slow down & do some diagnosis before you test it down . Start with pulling the plugs , take off the dist cap & check if your on no.1 , then rotate the crank forward then backward to see how much slop is in the chain/ gears .
    pprather, Hollywood-East and OZCAST like this.
  12. OZCAST
    OZCAST
    Yes, physical mobility. For some reason I get it real tight so I can’t move it with my hand, 30 minutes driving it loose and timing is out, with all the drivability issues to follow. I’ve been carrying a timing light with me. I’ll try a new hold down, go test and have issues.
  13. OZCAST
    OZCAST
    Car will start and drive, at least up until tonight, not sure about now, but I was able to re time it and drive well. It will pop slightly out the pipes coming down off high rpm (5000 ish). Never have backfired
    I’m getting some black smoke now, which I was never getting before. Have always been solid steel hold down. On my 3rd one. Had 2 after market and one factory. All same issue. It never moved at all for over a year, or all the sudden. Real weird. I really like this little motor. Plenty of power for this little roadster. Good looking too.
  14. OZCAST
    OZCAST
    Thanks. I tend to react fairly abruptly. I’ll check play in the rotor 1st thing. Distributor only has 1200 miles on it, but that doesn’t mean much these days I guess
  15. Kerrynzl
    Kerrynzl
    Has the intake been cut? [for milled heads /block]
    If so install a spacer between the distributor and intake
    I had this same issue with a BBC [with a HEI]
    2OLD2FAST and Oneball like this.
  16. OZCAST
    OZCAST
    It sure possible. It’s an early aluminum. Front oil fill like the factory cast one. It easily could have been milled over the years by someone. I can try a spacer for sure. Just strange that it just now getting loose after a year and a half of no issues.
  17. Oneball
    Oneball
    I’m wondering if for something odd has happened with the drive shaft from the oil pump and you’re now clamping the distributor down on to that rather than the manifold or if the manifold/heads have been skimmed as Kerry said.
  18. Oneball
    Oneball
    PS is the distributor itself moving or is it the timing alone that is changing? Have you marked the distributor body against the intake to check?
  19. oldsmobum
    oldsmobum
    from SoCal
    Is the distributor clamp held down with a long stud and a nut? If so, make sure that the stud is not physically pulling the threads out of the intake. That would have the sensation of being tight and randomly coming loose, until the threads leave the party altogether.
  20. OZCAST
    OZCAST
    I haven’t made a mark, but that’s a really good idea. My hunch is that it’s physically moving since it keeps coming loose, but definitely a box to check. Good idea
    Oneball likes this.
  21. OZCAST
    OZCAST
    No, it’s a bolt. I was going to try a stud to see if it helped
  22. OZCAST
    OZCAST
    I think at some point soon I’m going to have to pull the distributor. I’ll make sure to look. Oil pressure is normal luckily
  23. 19Eddy30
    19Eddy30
    from VA
    @OZCAST
    First thing I would do is check play in chain , cap off , watch rotor ****on , back & forth on crank, or
    If stick transmission , 1st gear rock roaster back & forth .
    If play looks Marginal,
    "" Is the Collar on Distributor adjustable ??? """"
    If No or Yes still do whats below ,
    Then I would pull distributor out ,
    Take gasket off , drop back in & see how much of a gap between base & intake .
    Should set on Intake with No Gap with Out a Gasket . If there is a gap , it's
    More likely pushing on Oil Pump .....
    Or Very close unless gasket in use is
    .065 to .100 thou Thick !
    If that checks out Ok,
    Then I would start looking @ distributor
    Pin , Not sheard & that gear not spinning / slipping on shaft ,
    Then Shaft &
    To pick up wheel Not slipping / spinning ,
    Then the weight plate where Cap bolts / screws to
    To make sure its not slipping / spinning.
    If shaft , pick up or weight plate Is slipping / spinning it will change timing in distributor relation to poles for each cylinder Before spark plug wires to plugs to piston & so on ...
    Report back what you see /find
    Also Mark distributor base & on intake to see if distributor housing is turning
    When clamped down after your Drive ..
    Doublepumper and jaracer like this.
  24. 2OLD2FAST
    2OLD2FAST
    from illinois
    Hurry up & **** up .... Are the hold down threads in the manifold still good ? Try some blue loc***e on the bolt ..
    OZCAST, leon bee and pprather like this.
  25. jimmy six
    jimmy six
    Is there a gasket under the distributor? I’ve found sometimes I needed 2 as the unit was going to far on to the oil pump drive. Good luck
    OZCAST likes this.
  26. porkshop
    porkshop
    from Clovis Ca
    AScreenshot 2025-06-10 112500.png some MSD distributors have an adjustable lock collar around the stem. If that is loose it could be the cause....
    tb33anda3rd, swade41 and pprather like this.
  27. BJR
    BJR
    I go with Squirrel's suggestion, the shaft in the distributor may be seazing to the distributor body due to lack of lube and turning the distributor.
    OZCAST likes this.
  28. MAD MIKE
    MAD MIKE
    from 94577
    If the distributor has been undisturbed and functional I would suggest that there may be varnish buildup on the shaft causing drag.
    Clean up the shaft and install a new distributor gasket.
    Verify the dist gear is not too close to the housing, binding.
    Verify the distributor clamp is also installed correctly. It can be flipped upside down which may look as though it is clamping the distributor, but it is not.
    Verify the bolt is not too long or missing a washer.
    Some later model clamps and aftermarket pieces work only when installed 'upside down'.
    To check timing chain slop;
    Rotate engine to TDC.
    Remove distributor cap.
    Manually rotate crank backwards while watching rotor.
    When rotor begins to move STOP.
    Look at timing tab mark.
    <5° You're OK.
    >5° Start gathering parts for timing chain replacement .
    >10° Timing chain should have been replaced last year.
    OZCAST likes this.
  29. GordonC
    GordonC
    What kind of distributor is it? Pick up a new one for about $60 and stab it in and see what happens. Or borrow one if you don't want to buy one.
    Kerrynzl and leon bee like this.
  30. OZCAST
    OZCAST
    Good call! I’ll check that right away. Thanks!
    porkshop likes this.
