Technical Little tips and tricks for garage hobbyists.
Discussion in 'The Hokey Ass Message Board' started by Ron Brown, Jul 30, 2019.
  1. snoc653
    snoc653
    from Iowa
    IF I’m ever crazy enough to do it again, I’ll lock it in 4X4 and the between the parking brake and the trans locking both ends, it should hold. But it would take something pretty serious to get me to try doing anything on the hill again.
    Tow Truck Tom and Sharpone like this.
  2. Sharpone
    Sharpone
    How steep is the hill?
    Dan
  3. snoc653
    snoc653
    from Iowa
    I’ll have to put the angle finder on it. If I had to guess I’d say between 10 and 15 degrees. It takes 4wd in the winter if we’re lucky but it’s only 300 ft. from the road to the garage Otherwise I clear a spot near the bottom and we can walk the fence up to the house where it levels off. The shop is about 1/3 of the way up if we can get there to park
    Sharpone and Tow Truck Tom like this.
  4. deathrowdave
    deathrowdave
    from NKy
    Locking in 4x4 is your friend . The tongue weight changes and raises the rear axle of towing truck off the ground . I have seen it happen many times , loading and unloading equipment on the pipeline rigs . Scary stuff , the operator on the equipment on the trailer can do nothing but ride the **** storm out . Always tried to get to most level spot as possible . Most of the drags we used had feet to support the ramps which made it some what better . Air brake trucks helped .
    snoc653, Sharpone and Six Ball like this.
  5. Boneyard51
    Boneyard51
    When we bought this D-9 dozer the owner loaded it on the back of a four axle trailer….on an incline! As he climbed onto the trailer , the trailer and truck started heading down hill at a rapid pace, starting to Jack knife! I was observing this at a distance, thinking this is not end well for the guy we hired to haul this monster! The owner , cool as a cu***ber, just shifted the D-9 into reverse and backed it off the moving trailer , when the cleats reached the ground, everything stopped, short of any damage! Coolest thing I have seen in years!
    dana barlow, SS327, alanp561 and 8 others like this.
  6. snoc653
    snoc653
    from Iowa
    When we loaded him there was a slight slope and his tires could barely get him up on the trailer. The truck didn’t show any signs of moving at all. But had he backed up on the trailer when it was slipping, it probably would’ve stopped everything as the weight returned to the rear axle of the truck.
    Tow Truck Tom and Boneyard51 like this.
  7. Fabber McGee
    Fabber McGee
    Sometimes logic is a bit slow to show up during a crisis. Much easier to get it right the next time.
  8. patsurf
    patsurf
    i'm not sure that is a 9.....
    Boneyard51 and arse_sidewards like this.
  9. atch
    atch
    That's OK. I bet 99% of us don't know the difference between a D-9 Caterpillar and a rocking chair.
  10. patsurf
    patsurf
    Sharpone likes this.
  11. atch
    atch
    Here's one I discovered this afternoon when I was replacing some disk brake pads. I've always pulled both bolts out and removed the caliper completely (except for the rubber brake line) when replacing pads. I was having a hard time with the 2nd bolt on the first side that I did and accidently found that I could just pivot the caliper up and out of the way on the other bolt. Well, that saved some time and aggravation. By leaving one bolt in there was no need to fiddle around lining up the bolts again.
    First pic shows one bolt removed and the piston/housing moved slightly. Second pic shows piston/housing swung completely out of the way allowing the pads to just about fall out.
    Replace the pads; push the piston back in; swing the housing back down; reinstall one bolt; and boom; you're done.
    NOTE: this may or may not work on other vehicles, but it worked this time on this one.
    Boneyard51, fauj, alanp561 and 4 others like this.
  12. arse_sidewards
    arse_sidewards
    from Central MA
    1990s and 2000s Subarus come with one pin and one bolt with the ***umption being you'd undo the bolt and swing it on the pin.
    b-body-bob likes this.
  13. Boneyard51
    Boneyard51
    I’m sure it is, because I said it is and I bought!
    Bones
  14. snoc653
    snoc653
    from Iowa
    That dozer is still a brute. The heavy duty winch is an awesome addition. It may not have all the bells and whistles of a modern D9, but I bet it can get the job done. The sun shade/cab cover showers that thing was meant to be worked. In the words of some on the site, I’d drive it.
  15. Boneyard51
    Boneyard51
    Thank you! We bought this monster some years ago, like thirty! We acquired a new pice of land on the West side of the ranch, that was bottom land with huge trees. We used it to clear that piece fir gr***! It was a blast to operate. We would put it in low gear, drop the 14 foot wide blade and raise it 1 inch and just drive through the smaller trees. Funny thing about the engine. Idle was 900 rpm, wide open was something like 1400! lol
    Bones
  16. patsurf
    patsurf
    Boneyard51 likes this.
  17. Boneyard51
    Boneyard51
    Yep! We don’t use it any more. All the big stuff is done! I have a s****er that will fit it! I was planning on building a lake on the East side of the ranch, but got too old!
    If we need anything done we use my D-6 or one of our wheel tractors, with front end loaders!
    Bones
  18. Sharpone
    Sharpone
    One day with that brute and I could be done with all the dirt work I’ve been doing for the past 20+ years
  19. Harv
    Harv
    from Sydney
    You can break a rocking chair... :D
    Cheers,
    Harv
    Just Gary, seb fontana, enloe and 8 others like this.
  20. Fabber McGee
    Fabber McGee
    So many pop ups I can't see what they're selling, so helwithem.
  21. I don’t even know why a person would have linseed oil. The only time a can remember using it was on a steam turbine rebuild at a power plant 35 years ago. Iirc it was triple boiled if that makes a difference. Seriously what do you guys use it for?
    ekimneirbo, deathrowdave and Sharpone like this.
  22. BJR
    BJR
    linseed oil used to be used in paint. Some people use it for a wood finish.
    phat rat, scotty t and Sharpone like this.
  23. blue 49
    blue 49
    from Iowa
    My Dad was a carpenter. He treated his wooden ladders with it for weather protection.
    Gary
  24. 50 years ago I used it to freshen up some window sills that had long been neglected. Sticky stuff. I'd hate to think someone would pour it into a crankcase. Talk about the anti-Marvel Mystery Oil.
  25. so not really car related then, thanks
    JimmyNeutron likes this.
  26. deathrowdave
    deathrowdave
    from NKy
    BLO only thing I finish wood rifle stocks with . Once a day for week , once a week for a month , once a month for a year , it will be beautiful and tough with this formula .
    GuyW, LWEL9226, Six Ball and 3 others like this.
  27. Harv
    Harv
    from Sydney
    Linseed oil was used to finish the surface of cricket bats, before we colonials used them to win cricket matches against the English. :D
    Cheers,
    Harv
    jet996, deadbeat, Just Gary and 2 others like this.
  28. alanp561
    alanp561
    @Bones, do you have a front shot of your D-9? Is the blade hydraulic or is it a cable rig?
  29. GuyW
    GuyW
    I think some guys use boiled linseed oil to protect bare sheetmetal or patinaed paint jobs.
  30. RodStRace
    RodStRace
    @ekimneirbo I didn't get pop ups, but the site is 'busy'.
    There are so many variations on the original zip tie that a whole thread could cover tips and tricks on them alone!
    I tried to find a single source for variations, but even that seems to be tough. This one shows quite a few.
    https://www.nylon-cabletie.com/nylon-cable-tie
    It seems to be AI written or a quick translation, but at least it has a collection of pictures of various styles.
    While many consider them to be a cheap ugly solution, they are widely used and can be a lightweight, best use tool for many things.
    seb fontana and ekimneirbo like this.
