1981, BW ST-10 Trans
Discussion in 'Off Topic Hot Rods & Customs' started by bjinx, Jun 6, 2025.
  1. Trying to find what vehicle this BW ST-10 trans came in. All date codes shows to be 1981, 6 rings on input shaft indicates wide ratio. But I can't find a model with the electrical plug @ the reverse shaft, see pic.
    A friend has the trans and he wants to sell it, but he would like to know what it came out of.
    Thanks
  2. 31Apickup
    31Apickup
    By 1981 it would have been GM a-body or f-body.
    slowmotion likes this.
  3. buds56
    buds56
  4. squirrel
    Partial Vin stamped on it should tell you the car assembly plant, which will narrow it down.
  5. What was the electric plug on the reverse gear shaft? An idiot light to show you were in reverse.
  6. SS327
    SS327
    Back up lights.
    427 sleeper likes this.
  7. slowmotion
    slowmotion
    By '81, my WAG maybe a Z28 or T/A?
  8. We got it figured out.
    Thanks for all the help.
    42merc likes this.
  9. I've had three ST-10 transmissions. One from an '80 Z28, one from an '80 Corvette and one from an '81 Trans Am. The Z28 and Corvette had cast iron cases and were wide ratio, the Trans Am had an aluminum case and was a close ratio. I don't know if my experience with them means anything but I find it interesting that yours is an aluminum case yet wide ratio ...
  10. mustangsix
    mustangsix
    Didn't the Monza, Skyhawk, Sunfire also come with a T10?
  11. squirrel
    more likely a saginaw.
  12. 31Apickup
    31Apickup
    Monza’s and the like were indeed Saginaw 4 speeds.
  13. And the answer is ?????
  14. VIN# on Trans 1CL744888
    Chevy, 1982, Van Nuys CA.
    Camero
    squirrel likes this.
  15. squirrel
    But it could also be from a Camaro....
    Desoto291Hemi and SS327 like this.
  16. I must of had a senior moment
    Yes it could
