Technical hot rod truck frame plans
Discussion in 'Traditional Hot Rods' started by 62Fleetside, Jun 11, 2025.
  1. 62Fleetside
    62Fleetside
    Hi, I have been looking at a lot of frames lately for 40s Chev pickups to swap on my 42 but every lead is a dead end and locally they don't grow on trees in Canada and anything east of the rockies is roulette for rust. I have seen a lot of well executed open wheel hot rod pickups (pre 47) and I know there are a lot of these style trucks that can be built cheap and I swear half are on custom built frames out of square tubing, the body doesn't have any mods to the floor to make it fit, what I am wondering is what plans do everyone use for these and if the biggest expense is buying the square tubing and having it cut? I think the option of putting it on a t bucket frame without extensive modifications look silly, the square tube ch***is is an option I am considering, so what has everyone used for a frame on a fenderless "bobber truck" and if there are any plans for the design of one with dimensions and everything? I have seen lots of people build these styles for less than the cost of a brand new crate motor and look really good, attached are a few trucks of a similar vintage to mine that I like the look of
    Sharpone likes this.
  2. gene-koning
    gene-koning
    I do not know your experience, skill level, or what equipment you have, but based on the idea that you are looking for "plans" tells me you probably don't have much experience in building a frame.
    My I suggest that an internet search should provide several shops that build truck frames. Unless you are one of those "have to do it yourself" guys, buying a complete (or nearly complete) frame may be a good direction to go. Starting with a welded together, well designed, frame puts you much closer to having a derivable truck.
    Sharpone, vtx1800, alanp561 and 5 others like this.
  3. 62Fleetside
    62Fleetside
    I have a lot of experience in starting to get really sick of posting this, I want plans to know exactly what would fit this body style
  4. Well
    Ya set the cab on blocks how like it
    Set a rear end where ya like it
    Figure out where the front axle looks good
    then ya start measuring
    google bobber truck frames
  5. You just put pieces where you think they look good
    Then start measuring and building
    I gotta get back on this one day
  6. alchemy
    alchemy
    osage orange and seb fontana like this.
  7. Tools needed:
    Kinda level floor
    A level
    Squares
    A plumb bob cones in handy
    Jack stands
    Various blocks of wood
    Chalk, pencils, markers
    Angle finder is nice to have
    A welder
    A way to cut steel. Chop saw is nice
    Tape measure
    Straight edge rulers are cool to have
    Clamps
    Goofy imagination
  8. Budget36
    Budget36
    alanp561 likes this.
  9. fastcar1953
    fastcar1953
    Something like this. 465814353_9079718318719040_7671453574240345461_n.jpg 466359509_9079717948719077_5130445868032124393_n.jpg 468251552_9182337651790439_9155308214855976613_n.jpg 466968762_9109581919066013_4750567017835964924_n.jpg 466994107_9109580959066109_1810864923720854315_n (1).jpg 467439967_9140276349329903_9130265152697682180_n.jpg 468295972_9187969434560594_5508663570755125366_n.jpg 468304890_9187969047893966_8128394349726999078_n.jpg 473253901_9450359608321574_8119271695677792207_n.jpg 473327787_9450359114988290_9000406087235326527_n.jpg 473416118_9450360084988193_7061207841893908136_n.jpg 473831055_9482732278417640_5954636530524856755_n.jpg 471349372_9350047015019501_6202015666681763524_n.jpg 471598009_9350047355019467_3857360593182127897_n.jpg 471688109_9371424116215124_6525548568132754000_n.jpg 471744276_9371665486190987_3400591377366429343_n.jpg 471751928_9371665479524321_391505667846488965_n.jpg
  10. fastcar1953
    fastcar1953
  11. K13
    K13
    You keep getting asked because you keep asking questions that someone with experience building hot rods wouldn't ask. Plans don't exist for building frames for bobber trucks. Guys just build them.
  12. Paulz
    Paulz
    IMG_20200917_185306220_HDR.jpg This is what's under mine. No plans other than an idea of how I wanted it to look, and then doing exactly what Anthony posted above.
    fatassbuick, swade41, RICH B and 4 others like this.
    just read the tech sheets for paint and torque specs for mechanical stuff :)
  14. twenty8
    twenty8
    Oooooooo........ Very nice.
    RICH B and seb fontana like this.
  15. gene-koning
    gene-koning
    And there you have it! 3 guys that have shown you their plan! We expect to see a full build report with the plan all set up for the next guy.
    If you want all the measurements, angles, and a step by step process, you will be frustrated forever. They just don't exist. You do the same thing everyone else does, a plan by trial and error, until you have done a four or five of the same thing. Then, after 4 or 5 builds, you don't hand out a step by step pictorial because you probably didn't do***ent the process.
    There isn't one of these guys that didn't have an "OH! ****! How do I do THIS!" moment.
    If you want a frame the body will bolts onto, buy one from somebody the jig builds the frames, or man up and do the plan by trial and error your self.
  16. RMR&C
    RMR&C
    from NW Montana
    I've seen guys build complete mock up frames from wood 2x4's. (cheap)
    After tweaking it to how they want it, copy it in steel. Gives you a visual and allows you to easily make changes as you go
  17. hotrodjack33
    hotrodjack33
    The OP seems to lack the one tool all hot rod builders need...patience.:eek:
  18. twenty8
    twenty8
    If you don't have these moments, you are not doing it right.
  19. 62Fleetside
    62Fleetside
  20. 62Fleetside
    62Fleetside
    If you all are only going to post negative comments and be rude find someone else to be rude with
  21. 05snopro440
    05snopro440
    If you edit your profile to include your location or tell us your location, you might luck into something. I have the ch***is from my 46 GMC 3/4 ton I'd happily rehome, but I have no idea where in Canada you are.
    swade41 likes this.
  22. fastcar1953
    fastcar1953
    I started with a model a frame back to firewall. Copy that in 2x3 square tubing ,left it long. Built the back to fit the bed. I also mocked up bed length and fuel cell. Ended up with 116 inch wheelbase. That is what the stock wheelbase was.
    First thing is get body and wheels close to what you want. Figure out what suspension you want .
    Ride height engine placement. I didn't channel my cab. My floor is still flat.
    Yes I did have to make changes a long the way. Move shock mounts , front crossmember, etc.
    If you have the cab and body plus a engine and transmission if will come together pretty quick.
    Mockup is the fun part.
    Okie Pete, X-cpe and lostone like this.
  23. fastcar1953
    fastcar1953
    Gas tank. 25 gallon. 493878805_23878382998425995_4207612585204988979_n.jpg 494100184_23878377968426498_1247220610214837551_n.jpg 494201487_23878383261759302_8492738383767538745_n.jpg 494281361_23878382401759388_1702799380898325101_n.jpg
    Okie Pete, Deutscher and lostone like this.
  24. fastcar1953
    fastcar1953
    th400 with gear vendor. Floor is flush up to toe board. I cut out floor just for mockup. It will all come out and get new floor put back. 474013286_9489028577788010_3458395365278883544_n.jpg 474210553_9489028904454644_712885756321661977_n.jpg 474274474_9489029081121293_5211812670103525668_n.jpg
    alanp561, Okie Pete and Deutscher like this.
  25. fastcar1953
    fastcar1953
    swade41, osage orange and Okie Pete like this.
  26. X-cpe
    X-cpe
    Maybe imagination too.
    05snopro440, hrm2k, Okie Pete and 3 others like this.
  27. seb fontana
    seb fontana
    from ct
    Having the at***ude you have I am surprised you got all all the response, especially https://www.google.com/search? q=1942+chevy+pickup+frame+dimensions&client=safari&sca_esv=3689d8f87b454a04&channel=iphone_bm&ei=pCJKaMadKKan0PEPn5uTkQg&oq=1942+Chevy+Pickup+frame%C2%A0&gs_lp=EhNtb2JpbGUtZ3dzLXdpei1zZXJwIhkxOTQyIENoZXZ5IFBpY2t1cCBmcmFtZcKgKgIIAjIFECEYoAEyBRAhGKABMgUQIRigATIGEAAYFhgeMgYQABgWGB4yCxAAGIAEGIYDGIoFMgsQABiABBiGAxiKBTILEAAYgAQYhgMYigVIiXFQjhhYyVpwAngBkAEAmAHLAqABnRuqAQgzLjIzLjAuMbgBAcgBAPgBAZgCGaAC0xfCAgoQABiwAxjWBBhHwgICECnCAgUQABjvBcICCBAAGKIEGIkFwgIFECEYqwLCAgUQIRifBcICCRAAGBYYyQMYHsICBRAAGIAEwgILEAAYgAQYkQIYigXCAggQABiABBjJA8ICDhAAGIAEGJECGMkDGIoFwgIIEAAYgAQYogSYAwDiAwUSATEgQIgGAZAGBZIHBDMuMjKgB7mZAbIHBDEuMjK4B78XwgcIMC41LjE3LjPIB38&sclient=mobile-gws-wiz-serp#vhid=RC2lcXMbdoXlwM&vssid=_tiJKaKzdBbm90PEPwPTKsAU_50
    swade41, 05snopro440 and hotrodjack33 like this.
  28. 49ratfink
    49ratfink
    do you have the whole truck? is there something wrong with the original frame?
    Just Gary likes this.
  29. Toms Dogs
    Toms Dogs
    from NJ
  30. Okie Pete
    Okie Pete
    A late friend/ mentor shared with me more than once words of wisdom his Grandpa had told him . A man built it , your a man and you can figure out how to fix , build and repair it .
