Technical 1941 Chevy PU windshield outer gasket
Discussion in 'The Hokey Ass Message Board' started by TwistedMetal, Jun 12, 2025.
  1. TwistedMetal
    TwistedMetal
    from Wisconsin
    Over the past almost 20 years on the HAMB; I’ve always found my solution using the search function. Well, I’m struggling this time.
    I would like to install this one-piece gasket for a trial fit before I install gl***…..the gl*** I don’t have yet. Leaky or not I would like to utilize the flip out mechanism. What is the best way to install this gasket? Slide it into the channel or push it in with something? Rubber gasket tool? Lube maybe? Has anyone ever successfully removed this gasket? It seems like it will easily damage.
    If the fit with the flip out does not line up properly any ideas on how to permanently mount the frame/gasket to the cab? Thanks
    Toms Dogs and Tow Truck Tom like this.
  2. Joe H
    Joe H
    I would bet the frame will distort some with out the gl***, so your trial fit will not show much. My '37's frame was pretty flimsy till I had the whole ***embly put together. Also beings it's a one piece, you won't just slide in, you have to start the front side and push in the back side or vise versa. If thats a SteelRubber gasket, it will work just fine. I went through two other venders till I bought the Steel piece. The others were to stiff, the windshield wouldn't close or seal. With the SteelRubber seal, the gl*** closes all the way and seals up pretty good. I added a second seal just on the inside lip of the windshield frame around the cab, it's a very soft universal bulb type so the windshield frame lays against it as secondary seal. With what the seals cost, I would not want to try and remove one after all the work to install it.
    Tow Truck Tom and TwistedMetal like this.
  3. TwistedMetal
    TwistedMetal
    from Wisconsin
    Joe that makes sense, the gl*** will stiffen the frame. I think I bought the gasket from Jim Carter Chevy. I've read the SteelRubber products are much better. Next step is I'll get gl*** cut and look into the Steel products. thanks.
  4. Soap it up
    Dish washing liquid
    We used generic plastic wedges like these
  5. cshades
    cshades
    from wi
    i have done a few of these. is that a new frame or an original? the first thing i do is set the frame in the hole in the truck and check for how far out the center sits away from the truck. new frame center vee join bars always seem to be bent a bit to far out. if you adjust the bar be careful because the screw holes make them weak. as far as putting the gasket in the channel i have never got them to slide they fit to tight. i start on the bottom center, lube and use a plastic flat pry bar to push i9t down in the channel. it will be a pita for the first few inches then you will get the hang of it. they arent bad to do but the issue is the gaskets for these **** no matter who you bought it from. i carry a towel in my truck to wipe the dash off when its raining
  6. cshades
    cshades
    from wi
    dishwashing soap works ok but a better product is tire mounting lube. you usually can buy it at a parts store. its not expensive and is made for rubber on steel
  7. cshades
    cshades
    from wi
    where are you in wisconsin?
    Tow Truck Tom likes this.
  8. TwistedMetal
    TwistedMetal
    from Wisconsin
    I live just outside of Eau Claire. The frame is original. I had to cut part of the back of the frame apart just to get the v-bars out. I made new V-bars but decided to buy new ones thinking the angle would be closer. The center gasket is junk, I will need to buy a new one. I could not get the screws out of the top mounts, but I think I can fix that as well. So I have some fab work ahead of me. Other than that the frame is in ok shape I think. Again if I'm not happy with the flip out I will just mount it solid. If that is the case I'm ***uming I can still use the same gasket and use a better sealer behind it? From previous windshield installs, this frame seems smaller. The frame does not have a lip, it relies on the outer gasket. This is why I wanted to trial fit the frame before I install the gl***.
  9. cshades
    cshades
    from wi
    i am amazed it is good enough to use they usually are not. the problem with solid mount is you cant get to the screws on the top edge of the dash if you need/want to remove it for what ever reason. the problem with the center bar is the outside gasket is part of the center bar it is molded to it so it isnt replaceable in the true sense of the word. my avatar truck has the original center bar on a replacement frame i used sealer to get it mounted. getting the top screws out can be a challenge you really need time and patience. i do have some original frames around if you need some pieces. i normally jut use new frames nowadays. i am in portage so we are not that far apart.
    TwistedMetal likes this.
  10. Toms Dogs
    Toms Dogs
    from NJ
  11. TwistedMetal
    TwistedMetal
    from Wisconsin
    Thanks a lot for the help cshades, appreciate it. And yes I would need to remove the dash so I was thinking of ways around the dash mount in case I solid mounted the frame. Have a flip out and the cowl vent working just makes a person smile. :)
    You can see from my photo that my frame is pretty decent. But the top inside cap where the windshield hinges are mounted is all rusted through. Had to fabricate a panel to repair.
    From what I've seen, new frames are crazy expensive. At least the flat gl*** is cheap.
    I'll keep you posted on progress and if I need anything. I'm sure I'll have other questions moving forward as well.
  12. rusty rocket
    rusty rocket
    You can order brand new gl*** from cl***ic parts for really reasonable. Just ordered every piece for a 46 I’m building for a friend of mines.
  13. cshades
    cshades
    from wi
    auto city cl***ic out of minnesota has all of the gl*** cut and ready to go. i usually get it within a day or two after ordering it. yes new frames used to be about $500 now they are closer to a 1000
  14. cshades
    cshades
    from wi
    most of the time the cap is rusted out because the header panel makes a perfect place for the rodents to live.
    swade41 and TwistedMetal like this.
  15. TwistedMetal
    TwistedMetal
    from Wisconsin
    For my 34 windshield I had a gl*** place up the road from me cut and install the gl*** in my frame for $180, which I thought was reasonable. For $120 for both panels for my 41 I think I will go that route. Do you use an inner gasket for the gl***, or the gl*** setting tape or windshield adhesive? Thanks.
  16. cshades
    cshades
    from wi
    the last one i did i used the rubber setting tape. my first one i glued in but i am always afraid that some day i will get a rock chip and have to buy a new frame because you will never get the gl*** back out if it is glued. $120 is reasonable
  17. Heat will release the urethane
    Toms Dogs likes this.
  18. cshades
    cshades
    from wi
    how much heat?
  19. BJR
    BJR
    The frames are flimsy without the gl*** in them. When I did the crank out for a 47 International I used urethane to set the gl***. Installed the frame into the cab and cranked the windshield closed tight before the urethane got hard. If you don't do this step the frame may not fit the opening in the cab, as they twist easily until the urethane hardens. Then you can remove the frame and put the gasket around the frame on.
    TwistedMetal and anthony myrick like this.
  20. A good quality heat gun should work.
    Induction heat is used on new cars now. It releases the glue in places a knife won’t cut
  21. tb33anda3rd
    tb33anda3rd
    another trick for using the urethane is to use a few short pieces of setting tape to locate the gl***, trim them, then run a small [no smaller] bead of urethane around the frame inside and out. then if/when it needs to be removed it can be done by running a razor blade around to release the gl***. works with side gl*** too.
  22. TwistedMetal
    TwistedMetal
    from Wisconsin
    Very good information here, thanks. I do need to fix the upper mount threaded holes (two of them are sloppy) Think I should Tig in a rivet nut 10-32 or 10-24? Or cut out the section completely and weld in a thinker flat bar and re-thread. Or machine a piece to weld in. Thinking the rivet nut as long as it does not hit the channel would be easiest.
  23. TwistedMetal
    TwistedMetal
    from Wisconsin
    Got the outer gasket in, what a PITA. My frame doesn't seem to fit the greatest on the drivers side bottom, mainly. Think I need to bend the V-bar on the bottom slightly? Of course this would require removing the outer gasket. The seal doesn't fit into the Cab opening perfect either. Some adjustment is needed there as well., thanks.
    swade41 and tb33anda3rd like this.
  24. patsurf
    patsurf
    are you able to feather the a-pillar out some?
  25. TwistedMetal
    TwistedMetal
    from Wisconsin
    Well the p***enger side fits better than the drivers side. I can push the lower corner in some. Maybe I'll just try to tweak it with the gl*** installed.
  26. patsurf
    patsurf
    :eek:
  27. cshades
    cshades
    from wi
    is the windshield regulator actually pulling it in all of the way? i have had a few of these that the regulator slips when it it is pulling it down. you can try bending the frame in the truck but i think you will probably have to pull the v bar out and bend it
  28. TwistedMetal
    TwistedMetal
    from Wisconsin
    @cshades The original regulator works very well. But the outer seal hits at the bottom, I can manually tuck that in. That is one issue. 2nd issue is I'll try bending the V-bar to fit the bottom curve better. Have you had any luck re-using the outer gasket after its been removed? Have you as well reshaped V-bars with good luck on fitment? Thank you.
  29. cshades
    cshades
    from wi
    i usually use a new frame and gaskets when i build one. even the new frames dont fit right. i usually bend the center bar in the vise. carefully. it doesnt take much bending to change the angle a lot so be careful. also be aware the center vee is fragile because of the drilled and tapped holes it is easy to break one at the holes. the gaskets are just a pain in the rear because they are not the same as an original gasket
