Technical What are you working on?
Discussion in 'The Hokey Ass Message Board' started by Lloyd's paint & glass, Jul 18, 2022.
  1. 0531251954.jpg And the "Fupp" (Ford/Hupmobile) pre war jalopy is slowly marching on.
    I pulled every part off the A engine that had a gasket and replaced the gaskets and seals then I do greased everything and decided to paint it the stock Ford color... When it is all said and done the goal is to make it look like a guy put a hupmobile body on a Model A ch***is in 1940 or 1941...
    Next is to fully re***emble the engine and transmission now that both are resealed.
    I probably should make a build thread for this little project I just got to take more pictures and I'm really bad at doing it. I got a lot of performance parts for it but I want to install it stock just to see how much faster all the bits make it. The last picture is the car really roughly mocked up I want it lower quite a bit lower actually. 0607252006a.jpg 0607252006.jpg
    hfh, swade41, mad mikey and 7 others like this.
  2. squirrel
    Drove the corvette to the hardware store to get plumbing supplies for the house. Started to leave, the stereo quit, and then I noticed the ammeter was pegged full charge, 30+ amps. I keep some stuff in the car for fixing things, including the old voltage regulator that had been seeming to not charge quite enough. And a volt meter. Volt meter confirmed 18v at the cigarette lighter socket. So I swapped out the regulator, and it was happy again.
    When I got home, I opened it up. I think the date code means 2017, I got it as old stock on ebay.
    looks like the problem is some contact material transfer, causing it to "lock" in the full field position?
    maybe I'll give up and put a 10SI on it.
  3. dana barlow
    dana barlow
    from Miami Fla.
    From brakes update #5308,,,
    It drove,but did not stop well> to get too stop well #2 pump. Bleed many more times/also jacked up,all four tire off ground,an adjusted shoes,tell I could not move;then backed off just enough so I could move tire=feels better*,but not enough better*< for hard fast stop,still need#2 pump;;;So I'm thinking { old master had 10lb Residual Pressure Valves { I have 4wheel drums n needs them.}and new master{even though by looking at it=is very same in every way as old master<but can't see in side/no don't want to pull apart = So I call Speedway an ask about it"" We sent you a match,but it dose not have any #10 Residual Pressure Valves,you have to buy those!> OK I did now and should have by weekend. I was told,they did have inside years back, same master with built in Residual Pressure Valves,but no longer can get them that way!
    Ya,the old master was new way back some were around 20years ago<so I guess I understand. Yes ,I should of asked about this when new order; Hu'mm,not really SWM falt,but my own for not asking. Come next week,all should be good{ Ya,I said that alot of times..
    Old cars are fun Fun,right ! At 84 years old me ,the fun comes shower :D:p:cool:
  4. squirrel
    heh...yeah, these days you have to ask, every time you order a part, "what did they screw up on it now, compared to my old one?"
  5. saltflats
    saltflats
    from Missouri
    After the third or forth time of doing this on my ba*****t shop I made a swing out panel with a man door because the door was manly open to foot traffic. Yes the springs need to match the the door weight not that hard to do if one has some common knowledge about how things work. Tools is the keys.
  6. snoc653
    snoc653
    from Iowa
    Yep we expect it to be the way it was supposed to be and not have trouble shoot to figure out what they changed. Even when it’s not parts missing the instructions only get you close and you have to figure out what they changed. The front end kit I’m working on puts the centerline 1/2 inch back from the measured centerline before I started. If it would just work right the first time, life would be so much more enjoyable.
    Okie Pete, Sharpone and dana barlow like this.
  7. jeepster
    jeepster
    from wisconsin
    Put on some racing shoes.
  8. Oneball
    Oneball
    Can you not adjust the original regulator?
    porkshop and Sharpone like this.
  9. squirrel
    I'll give it a try...and cleaning the contacts might help, too.
  10. mad mikey
    mad mikey
    Have a blast enloe.:) Wish I was going to be there.:(
  11. saltflats
    saltflats
    from Missouri
    Today was water heater repair :(
    porkshop, Sharpone and osage orange like this.
  12. jeepster
    jeepster
    from wisconsin
    Sometimes you got to take care of the homestead!
  13. RockyMtnWay
    RockyMtnWay
    Still collecting parts for the 53 F100.
    rod1, porkshop, deathrowdave and 7 others like this.
  14. wilkinson
    wilkinson
    Beauty! I can imagine how much work, patience, and attention a cl***ic car like that demands—keeping it in good shape is no small feat. When I was working on mine, we actually ran into a whole energy issue from the tools and equipment we used. Ended up having to call the Dominion Energy phone number to sort it all out. Just shows how even a fun personal project can lead to unexpected tasks! Totally worth it though for the joy of driving something with real character.
  15. IMG_2336 - Copy.JPG IMG_2338.JPG IMG_2339.JPG Just completed wiring the dash and overhead console on my '29 A truck cab. I put the trans and engine temperature gauges abreast of the tachometer, the ignition, light and hazard switches, left, right and hi-beam indicators and rear-view mirror all in the overhead console above the windshield. The speedometer, volt, fuel and oil pressure gauges surround the horn ****on in the middle of the stock dash.
    Next will be wiring the turn signals, brake light switch, fuel sender and lights. I think I can get that done in a few weeks, don't you? Then it's rebuilding the carburetor and hooking up the throttle linkage, ****oning down the floor, spinning the oil pump to get some lubrication to the crank and top end, cranking the engine without plugs in to get the oil pressure up, adding coolant and fuel, installing ignition wires and spark plugs, checking the firing order and timing, starting it up and running it in. Probably going to do the run in without mufflers and tackle that issue once I've got it down to idle.
    Okie Pete, porkshop, Robdski and 4 others like this.
  16. tomcat11
    tomcat11
    Nothing more exciting than rust removal. I'm marinating some good ole Ford brake parts in Wood bleach (Oxalic acid). One of the levers is worn and needs a little filler rod to make it new again.
    rod1, Okie Pete, porkshop and 7 others like this.
  17. deathrowdave
    deathrowdave
    from NKy
    I have High Requency TIG machine , ******* would not work . Opened it up contacts stuck . Burnished them , worked fine until the day I sold it . I think you’ll be fine cleaning them
  18. jazz1
    jazz1
    IMG_3651.jpeg I have to cut out floor rot that was was repaired 40 years ago,,,bet the guy said “they don’t build em like they used to”. ‘48 chev coupe and the repairs were leaded in
  19. swade41
    swade41
    from Buffalo,NY
    I dug the 41 out of the garage, sure had to move a few things and also put the rear up on dollies so I could slide it over.
    Got it outside and gave it a test drive around the long block, seemed ok other than the brake pedal arm dragging on the floor a bit and might need to lengthen the pushrod to get more pedal.
    I noticed that there wasn't much left of the 5 gallons of fuel I put in it so back home and gave it it's first bath in 7 years. The paint looks a little closer to matching with it all cleaned up, still need to clean the interior and engine, but that's for another day.
    61Cruiser, 1940Willys, rod1 and 19 others like this.
  20. swade41
    swade41
    from Buffalo,NY
    Mocked up the stainless and wood in the 57, this aftermarket stuff doesn't line up great that's for sure. My new doctored up color on the wood is blending in better.
    1940Willys, rod1, Okie Pete and 16 others like this.
  21. Robdski
    Robdski
    Exhaust system complete, tight squeeze, I hope it sounds good.
  22. swade41
    swade41
    from Buffalo,NY
  23. Robdski
    Robdski
    3” all the way back.
  24. swade41
    swade41
    from Buffalo,NY
    I thought it was bigger like 3 1/2, I run 3 on mine as well.
  25. chevy57dude
    chevy57dude
    20250530_094924.jpg 20250606_133605.jpg Quarter patch and floor in the '55. Rockers done.
    Robdski, hfh, rod1 and 13 others like this.
  26. chevy57dude
    chevy57dude
  27. atch
    atch
    Okie Pete, porkshop, enloe and 8 others like this.
  28. saltflats
    saltflats
    from Missouri
    Spent a few hours on the Biscayne this afternoon. Took care of a few loose ends.
    Today was driveshaft, starter, oil filter, park brake cable and fuel pump.
    Had to change the yoke on the driveshaft to the course spline to fit the early T10.
    Also put gear oil in the transmission and the rear end.
    20250618_162702.jpg 20250618_162702.jpg 20250618_162716.jpg 20250618_171759.jpg 20250618_171835.jpg
  29. Rootsy
    Rootsy
    from Monroe, MI
    BigRRR, swade41, rod1 and 11 others like this.
  30. Sharpone
    Sharpone
    IMG_3263.jpeg IMG_3264.jpeg Working on the Dart brakes, new MC, wheel cylinders, lines, shoes and hardware. I could purchase everything except the parking brake strut springs.
    A question for BRAKE experts , is the strut spring absolutely necessary?
    Upon dis***embly one side was missing the spring the other was broke in two. With the help of the NAPA counter man we found some springs that were close in size. I reshaped to fit, they seem to function OK - no binding.
    This rear differential is temporary, maybe a year, I’ll be installing an 8.8 down the road, but I want the brakes to work correctly.
    Next up gas tank removal , cleaning and paint.
    Thanks
    Dan
