Technical Banger carb linkage help
Discussion in 'Traditional Hot Rods' started by Ottvw, Jun 11, 2025.
  1. Ottvw
    Ottvw
    I’ve got a 31 coupe with the stockish banger in it with a downdraft carburetor. I have the original model A linkage and need to figure out a way to make it work. I’d order a burns one but doesn’t look like they’ll be made. So what are you guys running for linkage?
  2. Zottel
    Zottel
    Just build it, using the torch and bending stuff
    oldsmobum likes this.
  3. Lättähattu
    Lättähattu
    from Finland
    I do not know if this helps any, but this is how i made mine for two downdraft carbs. I connected original A linkage to a rod pivoted in the middle and connected that to the carbs. So linkage connected to the carbs move opposite way. Not pretty, but works with Strombergs anyway.
    winduptoy and Deutscher like this.
  4. Kevin Pharis
    Kevin Pharis
    from Califunny
    Most banger downdraft intake manifolds have a boss to mount a bellcrank to elevate the linkage, and reverse direction for 81/94/97 carb. Have seen drawing of this bellcrank on other threads
    winduptoy likes this.
  5. Maybe something like this? (not my car)
    Charlie Stephens
  6. winduptoy
    winduptoy
    cabby engine latest resized 1MB.jpg yes, you need a bell crank mounted to the manifold..someone was making these and listed them in the cl***ified section...but that has been years ago...but you get the idea and one can be made with a piece of flat iron
    I also have
  7. wuga
    wuga
    Here is a do***ent from Charlie Yapp detailing making your own bell crank. When I got my Equalizer intake, it didn't have one so I made this. It works great with my dual 97s. I make my own link rods by threading some rod the proper length and installing the spring ends.
    Warren
  8. 51 mercules
    51 mercules
  9. Ottvw
    Ottvw
    That’s perfect! Thank you I’ll give it a whirl. I can fab stuff up just wanted to see different options.
  10. 4BangerDean
    4BangerDean
    FYI… Burns Racing Equipment will be available through Millworks Hot Rod. The company was sold.
    I had purchased a complete dual carb setup from the owner of Burns last year sometime and the company was for sale. I believe he was having health issues.
    jet996 likes this.
