Eatom M112 I need information
Discussion in 'Off Topic Hot Rods & Customs' started by Masot, Jun 12, 2025.
  1. Masot
    Masot
    from Spain
    Hi guys.
    I need to know if this 2001-2008 Eaton M112 Jaguar is a good match for my 49 Flathead.
    I only need it for street driving; I don't want to boost much.
    I have Navarro cylinder heads, 88 camshafts, and Ross pistons.
    I want to modify it with two Stromberg 97 carburetors as pictured.
    thanks
    69fury likes this.
  2. Relic Stew
    Relic Stew
    from Wisconsin
    The M112 has a displacement of 112 ci, max rpm of 12,000.
    You didn't state engine displacement or max rpm, so I'll make generic ***umptions.
    If you run a 2:1 pulley the blower will push 224 ci per engine revolution. A 255 will consume 127.5 ci per revolution. A 1.75 ratio. ***uming the carbs can keep up 14.7 psi x 1.75 = 25.8 psi, subtract atmosphere 14.7 gives 11 psi gauge boost. Looks about right on paper.
    The Eaton blowers have the intake at the back, so the carbs won't sit centered on top like on a Roots.
  3. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    This may be the biggest hinderance to using it on a traditional flattie with carbs, and the most probable reason this thread may get deleted by the moderators.
    Masot likes this.
  4. mkubacak
    mkubacak
    Looking at the picture of the one with the carbs on top, they look almost identical other than the modifications done to move the inlet to the top and the plate on the back to eliminate the original intake port. I think I recall seeing a thread from years ago of the modifications done to get there.
    Masot likes this.
  5. 31Apickup
    31Apickup
    I’ve seen people convert those Eaton blowers to carbs, how well do they hold up as they are designed for dry flow (no fuel) thru the blower. In the original application the injectors are at the intake ports.
  6. gimpyshotrods
    gimpyshotrods
    I find 4-71's all of the time for cheap, and sometimes free.
    Algoma56 likes this.
  7. Where?
  8. Masot
    Masot
    from Spain
    I want to modify the carburetors from above, replace the closed rear bearings for gasoline, and close the rear intake. I want a city blower of approximately 5 psi. Is this a good combination? Thanks.
  9. Bought a 3:71 on marketplace for $40 once
    gimpyshotrods likes this.
  10. Clydesdale
    Clydesdale
    I'm not sure its really worth the effort, once you have done all the necessary modifications to make it work you might as well have just bought a 4/71.
    Plus it will still look like a modern piece and really detract from what sounds like a nice period looking flathead.
    Still, its your car and your money.
  11. gimpyshotrods
    gimpyshotrods
    Swap meets.
    Metal recyclers.
    Craigslist.
    Facebook Marketplace.
  12. Clydesdale
    Clydesdale
    Its important to note the original poster is showing as in Spain, so those sources likely wont be any good to him.
    Masot likes this.
  13. Doing this conversion atm, I liked the challenge ;)
    I'm using an NOS Eaton M90 blower off a T bird and using a custom 2x2 adaptor to mount 2 Stromberg WW carbs. Getting closer to finishing it as the pics are older. I''ve made a coupler to allow a gilmer drive rather than a ribbed pulley they come std with.
    You can run these blowers with fuel through them by using 2 sealed rear needle bearings that will prevent fuel from washing the bearing lube out of the bearings..
    The conversion isnt difficult with a little machining and the available carb adaptor that can be sourced from https://www.oldtimespeed.com.au/
    I'll bet money the M90 will be much more efficient and **** less HP than my 4-71 ;)
    Oneball, rod1, SS327 and 4 others like this.
  14. gimpyshotrods
    gimpyshotrods
    GM - Detroit Diesel powered vehicles and power equipment were sold in phenomenally large numbers, globally, since the inception of the brand in 1938. The 71 series platform was produced from 1938-1995.
    More importantly, it should be noted that the question about my sources was asked by someone in the same US state I reside in, and not the original poster.
    Local sources would only be known to those in their respective locality.
    Masot likes this.
  15. Masot
    Masot
    from Spain
    Thanks for the info, guys.
    I live in Spain (Europe), and it's difficult here, or there's a lot of money and taxes.
    Thanks
  16. Masot
    Masot
    from Spain
    ¿Cuál es un mejor candidato para un flathead, M90 o M112?
    Mi motor de cabeza plana es 8BA 239ci
    Con cabeza de Navarro
    Isky 88
    Pistones Ross Racing
    Dos Stromberg 97
    Pertronix
    Solo para uso en la calle....
    Gracias
  17. Masot
    Masot
    from Spain
    ¿El sonido del 4-71 y del M112 es diferente?
  18. mustangsix
    mustangsix
    Rat, what's the PN on those sealed bearings?
