Termites and Bowties- Early Chevy Group
Discussion in 'The Hokey Ass Message Board' started by 29bowtie, Jan 7, 2009.
  1. Jay Altemus
    Jay Altemus
    Inspiring film.
    31chevymike likes this.
  2. Jay Altemus
    Jay Altemus
    I may have found a suitable width rear axle. It’s a 1970 Camaro “corporate” with a 58” WMS width. I hope it has a gear I can use.
    Wayne67vert and 31chevymike like this.
  3. Thanks @snoop74/@tb33anda3rd & @Jay, that '31 needed a dropped axle, doubtful on availability. One day I happened to scan eBay for early Chevy parts and that coupe showed up for sale - sadly. Wondering if she had sold...
    Jay Altemus likes this.
  4. rumblegutz
    rumblegutz
    I truly enjoyed this video, thanks
    31chevymike and Jay Altemus like this.
  5. You're welcome Mr. Rumblegutz! Great looking Deuce 3W!
  6. Jay Altemus
    Jay Altemus
    Everyone sit down for this story. You will not believe it.
    Today I went to meet a man about a 1970 Camaro rear axle that was supposed to be the correct width for my Chevy coupe. Internet research and his measurements suggested that it was 58 inches wheel mounting surface to the opposite WMS.
    I drove to his house after work. He’s in Columbia, SC where I live but opposite side of town.
    I arrived and we measured the axle and it was too wide. More like 61”. Rats!
    He said to me "What are you going to put it in?"
    I answered, “It's going in a 1934 Chevy two-door business man's coupe.”
    He said “I sold a 1936 Chevy coupe a few years ago. It had a Corvette IRS rear axle.”
    I said, "SO DID MINE."
    Within one minute, we realized he was the man who sold the Chevy coupe to the man I bought it from. We confirmed this with pictures and details about the car.
    This is one of the most unusual coincidences I've ever encountered because there was NO OTHER REASON for me to talk to him except that I MIGHT want to buy his Camaro rear end.
    Columbia, SC is NOT a tiny community like Hooterville from Green Acres. What are the odds that I’d ever meet the man AND figure out he was a prior owner?
    Oh, and the other freaky coincidences are:
    1. My first car was a 1970 Camaro. (Pictured below in 1978.)
    2. He lives on Montgomery Avenue and I grew up and lived my entire life on Montgomery Avenue (in PA not Columbia, SC) until I moved out and got my own apartment after college.
    TFoch, Okie Pete, Shitbox and 4 others like this.
  7. Jay Altemus
    Jay Altemus
    This picture was taken by him in his driveway over 2 years ago. I was standing 40 feet from that exact location when we both realized he was a prior owner.
  8. Jay Altemus
    Jay Altemus
    Technical question. I’m test fitting my fibergl*** tail pan (probably not the right name for it). Should the tail pan mount flush with the horns on the frame, or does some sort of spacer go between the frame horn and the tail pan? This picture shows the tail pan mounted flush with the horns. The rear body to frame brackets line up well with the holes in the frame.
    TFoch and 31chevymike like this.
  9. Wayne67vert
    Wayne67vert
  10. Jay Altemus
    Jay Altemus
    Wayne,
    Yes, my good friend gave me a copy of the 1934 Chevrolet Repair Manual about 2 weeks ago. Unfortunately, it does not show any points about ***embly of the body panels. It has a small section about gl*** installation at the very back of the book.
    The other reference is the same link I have been referencing regarding the wood skeleton and body pieces. Unfortunately it doesn’t seem to have any info on bumper installation. I’m 99% sure it bolts on without any spacer between the tail pan and the frame horn.
  11. Wayne67vert
    Wayne67vert
    Have you checked with the AACA? They will take points off if you do wrong!!!:)
  12. Jay Altemus
    Jay Altemus
    I’ll get points off for nearly everything I have done so far. Haha!
    Okie Pete and 31chevymike like this.
  13. snoop74
    snoop74
    I would think it goes flush, are you running a fuel tank in the rear? Maybe mock that up under it and move some stuff around until it looks “correct”
    Jay Altemus and 31chevymike like this.
  14. snoop74
    snoop74
    My car had one of those cheese treat panels for a recessed license plate but I just filled it in. Even mine doesn’t match up well IMG_8547.jpeg C6790336-8926-409A-BCB7-C0566828BFA6.jpeg
  15. tb33anda3rd
    tb33anda3rd
    I used a small gasket material behind panel, then opened the hole up in the panel to accept a washer/tube spacer to sit flat against the frame so when the bumper brace went on it mounted solid to the frame . before mounting the bumper I put a rubber washer around the spacer to fill the space between the bumper brace and rear panel. I did this with an original panel, your tube spacer will be thicker to clear the thickness of the fibergl***.
    TFoch, Okie Pete, Jay Altemus and 2 others like this.
  16. tb33anda3rd
    tb33anda3rd
  17. tb33anda3rd
    tb33anda3rd
    the panel is only pinched by the rubber gasket/washer seen behind the bumper brace. the bumper is mounted solid to the frame via the washer/tube through the panel
  18. primed34
    primed34
    I mounted mine with the side brackets. I don't use a bumper.
  19. Jay Altemus
    Jay Altemus
    I will use this method. Any impact to the bumper is transmitted directly to the frame.
    TFoch and tb33anda3rd like this.
  20. Jay Altemus
    Jay Altemus
    Today I checked the rear axle to make sure it was perpendicular to the frame centerline. I checked the frame for squareness several months ago.
    I made a temporary Crossmember at the very front of the frame and then drilled a small hole in the exact center to represent the center line. I then use electrical wire to measure to the you both plate under the leaf spring and compared one side with the other. They matched. Hooray!
    Here’s a video. LINK
    TFoch, Six Ball, Okie Pete and 3 others like this.
  21. snoop74
    snoop74
    Nice, what’s going to be the next step after that? You have all the wood replaced on the inside?
  22. I'd like to see the rear differential (which ever he decides on) mounted up for good...
  23. Jay Altemus
    Jay Altemus
    I’m replacing the wood skeleton with steel. Progress has been made but still more to go. Lots more.
    31chevymike and Okie Pete like this.
  24. snoop74
    snoop74
    Gotcha I’m used to seeing you post something so
    I just wasn’t sure if I had missed something. Las trine you were working on the door structure I thought
  25. Jay Altemus
    Jay Altemus
    Call me OCD.
    I rarely have a helper when I’m in the shop working.
    I made a metal jig because tape measures flop around too much. The jig will be used instead of a tape measure and I made it rigid so the ends stay parallel to each other. It’s perfectly flat with no flex. It takes a lot of force to get any twist.
    Lots of pictures. Too many.
    The plan is to drill my 1 + 1/8” hole and lightly tack weld the shackle tube in place. Then use the jig to position the front leaf spring bracket and bolt.
    I confirmed that my marks are exactly 43 + 7/16” apart on both sides and square to the opposite side mark on the jig. This jig should be more accurate than using a floppy tape measure.
    I’m counting on the leaf spring eyes to be parallel and without any twist. I’ll check before proceeding.
    IMG_9825.jpeg IMG_9826.jpeg IMG_9827.jpeg IMG_9822.jpeg IMG_9817.jpeg IMG_9816.jpeg IMG_9823.jpeg IMG_9824.jpeg IMG_9819.jpeg IMG_9818.jpeg IMG_9820.jpeg IMG_9614.jpeg
    TFoch, snoop74, Six Ball and 3 others like this.
  26. Jay Altemus
    Jay Altemus
    I need advice. I feel I'm able to accomplish this fabrication even though I’ve never done it before.
    I’m thinking about doing a mini tub to the rear wheel wells. This would allow me to use a more common 2WD S10 rear end. They are far more common than the 4 x 4 S10 rear ends.
    S10 2WD is 54.5” wide WMS to WMS.
    S10 4x4 is 59”.
    The sub flooring frame shown in this picture runs along the outside of the frame just like the factory wood beam. It’s my understanding the wheel well had a flange at the bottom that was nailed to the bottom of that wood beam.
    The frame is 42” wide in this area and I’ve done the math. The distance between the vertical sheet metal inside the wheel well is 47”.
    A mini tub would give me an extra 2.5” per side to work with.
    One additional advantage is that I will have better access to repair my wheel wells and rear quarter panels while the fender wells are off the car.
    I value your wisdom. I’m new at this stuff.
    TFoch, Six Ball and 31chevymike like this.
  27. tb33anda3rd
    tb33anda3rd
  28. Six Ball
    Six Ball
    from Nevada
    You are skilled and brave but I think your time and effort would be better spent looking for a 4x4(or proper width) rear end.
    TFoch and Jay Altemus like this.
  29. primed34
    primed34
    I run an S10 two wheel drive rear in my '34 Master coupe with 15x9 wheels and 235 70s. I did not use tubs. It all fits but is close. I've run this set up since 1990.
  30. Jay Altemus
    Jay Altemus
    Primed34, what sort of backspacing do your rear wheels have? Do you have fenders on the rear?
    Thanks.
    Six Ball likes this.
