Hot Rods Posies “In-Da-Dirt” Kit insight
Discussion in 'The Hokey Ass Message Board' started by Kelly Burns, Jun 13, 2025.
  1. Before I order a Posies In-Da-Dirt front end and rear SuperSlide, reverse eye, transverse spring, to lower my ’47 I thought I would see what everyone’s take is on these. Did you use the spring packs as they came or did you take any leaves out? I think my car sits a little high, even for a stocker, but if get the advertised 5” drop in front, that should barely tuck the sidewall tread of my 6.0x16 Firestones into the fender, a little. SO I was thinking about pulling a spring out of each pack.
    I am also going to order their dropped steering arms and rear spring shackles as well. Also, I can see dropping down the front tires a size or two soon.
    If I get time tonight, I will try and photoshop a picture to the "advertised" amount.
    Any advice is appreciated!
  2. flamedabone
    flamedabone
    I can't help you on the super slide, but I can say that is a damn fine looking shiny black old Ford.
    -Abone.
  3. flamedabone
    flamedabone
    One thing though...those 46-48 ch***is have a pretty deep drop in the crossmember spring mount. Any chance you could raise it up a bit for some free lowness? Definitely something you would want to do with the front clip off...
    -Abone
  4. flamedabone
    flamedabone
  5. mad mikey
    mad mikey
    Well , I have known Dutch, as he is called AKA Posie- Ken Fenical since I was a small kid. I grew up with his kids. His stuff is nice. His daughter I think still runs the spring shop. I run a chrome super slid spring on my coupe, for over ten years now. Plenty of street and drag race abuse, no problems.
  6. alchemy
    alchemy
    If you get 5” of drop in the front, a 600 tire will probably rub the fender. A 5.50 or maybe even 500 would be better.
    And, why would you need dropped steering arms if you aren’t dropping the axle too?
    Kelly Burns likes this.
  7. swade41
    swade41
    from Buffalo,NY
    I have super sliders in my 57 pickup, it moves pretty freely thanks to the slider ****ons but I'm sure the springs aren't as stiff as stock springs either. I would recommend installing the springs as is first then if you still feel you need to remove a spring do it later after everything has settled.
    You might find yourself hitting the bump stops by removing springs first.
  8. Thank you! I appreciate that!
    lothiandon1940 likes this.
  9. Not on this particular one, but that is one of the best ways to do it.
  10. I have no doubt about the quality of their parts, I was wondering about the install and what to expect. As in, is it really 5" or does it settle to 6" kinda stuff.
    05snopro440 likes this.
  11. I think you very well may be correct.
    The Posies kit comes with a 4" dropped axle, I believe its a Super Bell.
  12. I would agree.
  13. Using a 6' ruler, in the rain, the best I could tell this is about 5" lower in front and about 2-1/2" in the rear. It's nothing scientific or anything to base decisions on, but a little fun on a rainy Friday night with a margarita. It does make me want to do a more accurate one!
    My 47 Behind STB Lowered 5&2-1:2 062501.jpg
  14. Jimmy Paycheck
    Jimmy Paycheck
    from NE Ohio
    Did you ever get the In Da Dirt kit on your 47?
    Kelly Burns and alanp561 like this.
  15. Not yet, I'm waiting on my bonus next week, then all I need to do is find a place to do it!
    53olds, pprather and Jim Bouchard like this.
