Projects The Flathead Flathead
Discussion in 'Traditional Hot Rods' started by Jeff34, Aug 30, 2021.
  1. Jeff34
    Jeff34
    It’s home! Apparently Mike hid the bell housing somewhere and we couldn't find it, but that's fine since I've got some travel scheduled next week and won't be able to spend much time on it. Can't wait to get it in the ch***is and keep going on this damn thing... FH.jpg
  2. Jeff34
    Jeff34
    IMG_4864.jpeg IMG_4866.jpeg IMG_4867.jpeg Got the incorrect pilot bushing removed (bread trick worked great) and the new bearing installed. Put the clutch and rebuilt pressure plate on. Then the bell housing with a new throw out bearing and carrier. And finally put the transmission back on. Just have to add the starter and I can put it back in the frame this weekend
  3. roseville carl
    roseville carl
  4. Jeff34
    Jeff34
    IMG_4876.jpeg Got the engine back in the frame and some of the other stuff connected. Next is a drive shaft
  5. Tim
    Tim
    from KCMO
  6. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Wow super nice. Can't wait to see it back on all four wheels!
  7. looking for kato kings? info. on electric to manual speedo install on wc t-5 ******
  8. just wow!!!
    Outback likes this.
  9. Jeff34
    Jeff34
    Yesterday, I did something that I didn't plan to, and didn't really want to, do.
    I had planned to measure for the driveshaft last week, but when I went to put the yoke in the transmission, it got hung up in the tail housing. It went through the seal, but then got tight in the bushing. I knew it was snug, but not that tight. So, in reluctant denial, I pulled the engine and transmission back out of the car.
    The task? Remove the tail housing from the BW OD transmission and figure out what's wrong. I've never worked on one of these before, so I read everything that I could to see where this could go south. I also worked very slow and took pictures so I had the best chance of getting it back together.
    I thought there were 2-3 possibilities. One: the output shaft spline is twisted, preventing the yoke from sliding on any more. Two: The spline is damaged. 3) The bushing is undersize.
    I removed the reverse lockout lever pin and pulled the lockout lever, and unbolted the tail housing. When I removed the tail housing, several cylindrical bearings fell to the floor. I quickly located all of them and put them in a safe place. Next, I removed the tailshaft from the housing and inspected that. The yoke slipped on the output spline very smoothly. No binding or catching. Great! Next, I put the yoke through the seal and into the bushing. Stuck. Went in about 1/4 - 1/2" and got tight.
    I decided to hone the bushing slowly until the yoke just fit. Once that was done, I thought I would put it back together, but I don't have the gasket. Dang.
    Turns out that's O.K. I need a 12VDC solenoid for the OD anyway, so I'll call VanPelts tomorrow and order the gasket, and 12V goodies I need for the conversion. Hopefully it goes back together as easily as it came apart...
  10. Jeff34
    Jeff34
    I got the rear seal replaced on the R10 today. Mac said it would be tough, and it was. Not an easy seal to remove. Once I had it out, I dressed the ID with a stone, and the OD with a file to clean up any dings. Then I installed the new seal. I also got my headers today. Took a while, and they still need a bit of finish work (IMO), but I won't be installing them for a week or two anyway.
    IMG_4920.jpg IMG_4921.jpg IMG_4922.jpg IMG_4923.jpg IMG_4924.jpg IMG_4926.jpg
  11. CSPIDY
    CSPIDY
    Those roller bearings are for the sun gear
    I did one when I was 13 yo, old guy told me to pack them in grease and rap a rubber band around them
    Reinstall the housing and letter rip. The oil will dissolve the rubber bands
    It worked for me
    Wow I just realized I’m the old guy now
  12. Jeff34
    Jeff34
    :p
    I saw a pic using the rubber band. I just put a little grease on them and slid the tail shaft on before they fell out...worked fine.
    Algoma56 and Tim like this.
  13. Tim
    Tim
    from KCMO
    Omph! That one came out the hard way
    Stogy and Algoma56 like this.
  14. Jeff34
    Jeff34
    IMG_4943.jpeg IMG_4944.jpeg IMG_4945.jpeg IMG_4934.jpeg I got more done this weekend. Trans was put back together. The snap ring was a bit of a challenge but I got it figured out. New solenoid installed. Engine and transmission back in the car and bolted down. Measured for the driveshaft. Installed a vent on the open drive conversion rather than the banjo. I was worried about metal chips in the rear end. This seemed like a good solution. Also installed the headers and mocked up the exhaust location. Moving forward.
    also a quick Timelapse of the install
    https://youtube.com/shorts/HhKYhR73SA4?si=-1YLUw7OTpLxehvG
  15. Tim
    Tim
    from KCMO
  16. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Now that's a productive weekend! Great work, per usual. And of course, I like the little curl on the vent line.
    Algoma56 likes this.
  17. Jeff34
    Jeff34
    Thanks, Tim
    Thanks, Joey. Yeah, once I got the parts for the transmission, I knew I needed to get this done. It was pretty warm this weekend, and warmer in the garage, but worth the sweat.
    I thought you might like the curl...I need to remake that part. Not happy with it, but it's no big deal to make another one.
    Algoma56, Tim and J.Ukrop like this.
  18. Jeff34
    Jeff34
    IMG_4979.jpeg I had Greg at Santa Rosa Drive Line Service build me a driveshaft. He did an awesome job. It’s 3” diameter tube. Should be strong enough for a flathead
    Algoma56, ZerroHalfcup and Tim like this.
  19. Jeff34
    Jeff34
    Installed. Perfect fit. Now to make a hoop. I’m going to add a second torque arm on the other side to attach the hoop to. I will also use that as a place to route the E brake cable. IMG_4980.jpeg
  20. Tim
    Tim
    from KCMO
    Looks great!
    I’m curious you know if the different r-10 yokes are interchangeable? I’ve got one behind a Stude and the yoke is bolted to the over drive and the factory driveshaft had a slip joint in the shaft. Been curious about swapping to a slip yoke and a normal driveshaft.
    keep up the good work!
  21. Jeff34
    Jeff34
    not sure I’m following. When I got my r10, it didn’t come with a yoke. Another member here sent me one but it was too big, so I honed the bushing to match. I talked with Mac VP about it. Most of them are 1.5” diameter. Mine was exactly that but was still tight
  22. Jeff34
    Jeff34
    I read your q again and think I get it. I’m not sure if you can switch from one of the bolted on yokes to a slip yoke. If you can take the yoke off you might know more. Mine is 1.5” OD.
    Tim likes this.
  23. Tim
    Tim
    from KCMO
    Thanks man, if I figure it out I will let you know. I figured maybe you had come across the info when you were getting ready to tear yours down. :)
  24. Jeff34
    Jeff34
    I got most of the exhaust welded up and fitted this week. Still need to add one more bend to get them to the pipes, but it’s close. Plan to fire it up in the ch***is next weekend! IMG_5027.jpeg IMG_5028.jpeg IMG_5031.jpeg
  25. Jeff34
    Jeff34
    I’ll have to dumb down my other pics to post. They’re too big
  26. Jeff34
    Jeff34
    Stogy, dwollam, LCGarage and 8 others like this.
  27. continentaljohn
    continentaljohn
    Awesome build
    Jeff34 likes this.
  28. Craig Owens
    Craig Owens
    Nice looking work, Jeff! I recently tried to post pictures and found my pictures are too big now that I'm using my cell phone camera. I'll have to figure out how to dumb 'em down,
    Jeff34 and Outback like this.
  29. There should be an edit feature in the gallery on your phone. Resize, and crop will do that.
    I've been re-sizing digital camera photos with a free software on my computers, to make photos easier to send or post. Phones have similar function, built right in.
    Jeff34 likes this.
  30. Greenblade
    Greenblade
    On my phone I take a screenshot of the photo then crop the black borders.
