Projects Coupe to truck to tub build thread
Discussion in 'The Hokey Ass Message Board' started by 40ply, Apr 22, 2022.
  1. 40ply
    40ply
    Ok I'm still committed to not letting this thread die and it's been a bit since I posted anything so although there's no progress on the tub, there is progress towards getting time to work on the tub. David's convertible I was working on got finished and sent back home a few weeks ago. It definitely turned out to be a way bigger project than I intended on taking on but he's happy, I sleep good at night knowing I didn't just spray it and send him a disappointing job and I'm flush again. Of course just like the big kid I am I could leave that cash sitting burning a hole in my pocket so some of went to a opportunely posted ad on marketplace so I'm now the owner of a 52" shear/brake/slip roll to help with the fab of the tub. I don't expect much work on the tub until the fall as it's crop season and I'm also doing some much needed maintenance on my other cars. Here's a few pictures to color up the post.
  2. Nice work on the convertible, Ed...and that slip roller/brake/shear will help on your tub project, so that's indirect progress.
  3. wstory
    wstory
    Good job bud! Hope to see pics of the Plymouth when re***embled..
  4. 40ply
    40ply
    Thanks guys. Fortunately I don't have to do that part. Lol.
    Tim likes this.
  5. 40ply
    40ply
    Alrighty, I'm back! I had a much longer hiatus from this project than I had anticipated but I'm refusing to let this project and build thread die. It's taking me a bit to get familiar with what I was doing and so to get my feet wet I started working on the other half of the cowl (driver's side) and door. I made templates of the dash top when I made the p***enger side so it was quite easy to get both halves to match.
    I cut the top corner of the cowl out because I wanted to curve it more to blend it into the door top better because I felt like the p***enger side looked like it had really high "cheekbones" and my thought was if i fixed it on the drivers side I could redo the p***enger side with what I learnt. The shape of a '27 cowl is so curvy that anything I tried still looked off and after many attempts and trips to the s**** bin to throw out more mangled sheet metal I decided to see if a windshield post would hide the sharpness of the cowl top. The Chrysler cowl is similar to an early model A cowl and I could have maybe tried to follow what Ford did but I like the windshield stanchions on the 32's better so I decided to work on making a windshield stanchion that was reminiscent of of the 32 to see if it hid the high cheekbone appearance before having another go at the driver's side.
    First mock up was some sheet metal and round rod to see if it would make the cowl top less noticeable.
    So far from the front I'm liking it.
    The rear view wasn't so bad either maybe just needing a few tweaks to design. Now my curiosity being piqued I decided to work on the windshield stanchion.
  6. wstory
    wstory
    I am watching your pro'-gress with interest. As I am currently "stuck" on the header pro'-jek, I fantasize on what I'd like to do an the Tudor. Always felt that the chop that came with the car was pretty rough and would take a lotta work and skill to clean it up. Soooo,...I'm thinkin, why not a tub? Like you, just whacking the top off a sedan wouldn't get it. I would only attempt that if I also committed to fabricating door tops and the cowl transition such as you are executing. Gives me a goal and a reference. Good job Bud!
  7. ski
    ski
    from San Diego
    I It looks really good there.
  8. Nice job Ed! Great to see you're at it again. That's an area that most creators of "coupsters" and "tubs" don't invest the necessary time and effort to get right.
  9. Tim
    Tim
    from KCMO
    Man great thread! Thanks for the continued updates :)
  10. 40ply
    40ply
    I had another go at the tub this weekend, this time jumping back and forth between building the start of a windshield stanchion and the driver's side of the dash and cowl.
    This is the modified dash extension tacked in place. I'm not sure exactly what I'm going to do here to make up the shape but you got to start somewhere and since I had the template from the other side it seemed like a reasonable place to start.
    This is where I got distracted and decided to switch to starting to build the windshield stanchion, my thoughts being with the p***enger side made and dialed in then I'd have more reference for making what is needed to fill the missing parts of the driver's cowl.
    I started by carving a piece of 1/2" aluminum plate into a shape I liked and then t******* a hole in the cowl to fit it. I wanted to have some thickness to the base and be able to shape it to the cowl so that's why a thicker piece of aluminum instead of a thinner piece bent to the shape of the cowl.
    I made a little bucket to hold the aluminum base and weld into the cowl that way the stanchion base is flat and I can shape the top of the aluminum stanchion base to the shape of the cowl.
    Here it is fitted and ready to be tacked in place. then the next step is to cut it down and weld it in and smooth the welds.
    That done I rough shaped the aluminum base.
    That's all for now.
  11. tb33anda3rd
    tb33anda3rd
  12. dutchrod
    dutchrod
    Cool project !
  13. wstory
    wstory
    Nice solution to the stanchion mounting. I have a Roadster and the stock mounting is just bolted thru the cowl sheet metal. The mounting pocket yuv created will certainly yield a more robust mounting. Good job!
  14. 40ply
    40ply
    Here's this weekend's shenanigans. I copies the p***enger side stanchion pocket and transferred it to the other side. PXL_20250309_201535444.MP (1).jpg
    This step was a little difficult because I had to make sure to get the pocket placed and angled the same as the p***enger side, so after taking some careful measurements...I eyeballed it! :D
    Here it is welded in. This allowed me to finally finish patching the rest of the top of the cowl.
    In this picture you can see my 1st attempt at mocking up the post was wrong and had to be cut off.
    This is a picture of the windshield post fabrication. Unfortunately I got caught up in the building and forgot to photograph a lot of it. I'm using 1/8" aluminum sheet cut to strips to form a 4 sided post.
    You can get the idea from the picture.
    Tim, brEad, Ragged Edge and 3 others like this.
  15. Ed...good progress...I know what you mean about being tough to measure side to side and angles for and aft. I too have, at times depended on my calibrated eyeball. Sometimes it worked well, other times it required shims, and yet others do-overs ;):oops:.
    brEad, patsurf and 40ply like this.
  16. wstory
    wstory
    Ditto to anothercarguy's experience. Isn't it amazing, the minute detail that the human eye can decipher. However, that's when comparing differences side by side. The challenge is getting it right when comparing mirror images of an amoebic shape separated by four feet :eek: GOOD LUCK ;)
    brEad and anothercarguy like this.
  17. 40ply
    40ply
    Time for a little update. I tacked a bar across the cowl level and angled to make it easier to get symmetry between the two posts.
    The stanchion base was drilled and taped for 3, 5/16 NF studs to attach it to the cowl, hopefully that'll be sturdy enough.:rolleyes:
    The tape is simulating windshield height, 8" in the center and laid back to approximately 45 degrees. I'm not sure if this will be where it finally ends up but it seems like a good place to start.
    Not sure if I like the shape of the posts from this side profile. To me it looks kind of boxy and utilitarian so that part might change after I study a few close ups of OEM windshield posts.
    brEad, RMR&C, tb33anda3rd and 3 others like this.
  18. Nice progress Ed. From the photos, I like the windshield rake, but agree that the posts appear a bit boxy at the moment.
  19. AmishMike
    AmishMike
    Check your province regulations so build legal/acceptable windshield. I know we have height requirements here
  20. It is looking awesome, keep the updates coming.
    RAK likes this.
  21. 40ply
    40ply
    New episode. I got bored with the windshield posts and I decided that at the upcoming Northwest Deuce Days show there would be plenty of roadster windshield posts to examine up close. Since I'm happy that the high "cheek bones" of the cowl can be hidden by the windshield posts I decided to move on to something else. Specifically mounting the engine and transmission so that I can finish the tub floor before removing the body from the ch***is and getting serious with the suspension and drivetrain. The original thought for this build was to use a DC motor and make it electric (which obviously wouldn't be shown here) but I moved from that to using parts I have laying around and I have a lot of Mopar flat six parts. The best part about these motors (in Canada at least) is the blocks are mostly the same with bore and stroke the only thing changing the displacement for the various models. Having already built a flat six for my 40 Plymouth Tudor I was able to take the displacement from 217 cid to 265 cid with a rebore and 4 1/2" crank swap, so that'll be the goal for the tub as well. I'm also hoping to do something cool and unique for the intake and exhaust.
    I'm using a truck bell housing and front engine mount. The benefits of using the truck bell housing is it makes pedal attachment easy and includes ears for mounting to the frame. I'm trying to use stock parts and make it look like the drivetrain grew there.
    Here's the first problem. The six is quite a bit longer than the original 4 banger so to get it to sit it to fit behind the radiator without adding length to the hood it has to sit further back than I originally designed the floor braces for. But the best part of working with metal is you can chop it out and weld it back in differently.
    :D
    Front motor mounts were a pretty simple fabrication.
    Next plan is for the rear motor mounts then start patching the floor supports. Thank for looking. Stay tuned.
    Ragged Edge, RMR&C, RAK and 2 others like this.
  22. patsurf
    patsurf
    you and gimpy have to compare notes on tying the windshield stanchions into body/cowl line...
  23. Cool update Ed...good to see you're still plugging away. You certainly won't need to worry about showing up at a carshow, and battling the other 1/2 dozen cars just like yours for attention!
    40ply likes this.
  24. 40ply
    40ply
    That's the whole idea.;)
  25. AmishMike
    AmishMike
    Love unique engine. Do not know Mopar flathead must ask stupid question. What is object on center p***enger side of engine just above oil pan? Oil pump?
  26. patsurf
    patsurf
    yes
    AmishMike likes this.
  27. wstory
    wstory
    Good job bud! Love seein the old and new metal coming together and the courage to "chop" stuff out that's not working as you wish.
    40ply likes this.
  28. 40ply
    40ply
    This build is still not dead. :D Just was having way too much fun this summer cruisin and hanging out with the guys so not a lot has gotten done on the phaeton. this year was a Northwest Deuce Days year and my Curmudgeon buddies gathered in Victoria from their respective homes to enjoy a week (or more) of BS and car fun. As usual they allowed me to host a BBQ for them at the farm after which we headed out for a week of cruisin the province. If you want to check that out the link is here, https://www.jalopyjournal.com/forum/threads/can-am-curmudgeons-are-road-trippin-again.1338625/ This time I decided to leave the Plymouth sedan behind (had a few bugs I hadn't gotten straightened out yet) and took my truck on it's first ever multiday run since putting it on the road over 30 years ago. The Chevy handled the trip like a champ and it renewed a love I have for this truck that I have abused as a shop truck workhorse for the last 10 years, so I decided when I got back to freshen it up a bit. So the truck has been the focus since July rather than the tub. However in the resealing of the engine and transmission I got the idea while the T5 was out to use it to modify the bellhousing on the phaeton to accept a T5 when the time comes. I'm using a dodge truck bellhousing which has the pedal swings attached and also is the rear engine mount, also the transmission mounting face is large enough to accept the T5 bolt pattern without the need for an adapter plate. PXL_20251005_141700108.MP.jpg
    The opening for the bearing retainer in the bellhousing was bigger than the bearing retainer on the T5 so I made an aluminum spacer to bolt to the transmission in place of the original retainer with the correct size for the bellhousing to center the transmission for marking and drilling the attachment bolt holes.
    Here it is mocked up on the bench for marking the holes with a transfer punch. I really should invest in a set one day as I had to make one on the lathe for this job. :rolleyes:
    Set up in the drill press and drilled.
    Drilled, Tapped and the holes chamfered, just like it came factory.:)
    For anyone interested, one of the projects for the Chevy was making a tail pan because there were a few comments about being able to, "see up the skirt" of my truck while following it. :eek: Here's a few pictures of that process.
    ....and yes I know the right tailpipe is crooked. ;)
  29. It's good to see you're still moving the project(s) forward. Nice solution on the T5 for the tub!
  30. wstory
    wstory
    Thanks for sharing the latest in your world. I'm thinkin most of us have more than one project and I, for one, enjoy seeing the other stuff that my friends are r***ling with. The little side trips from the core subject lend texture and context. Good job!
