Hot Rods Engine turned chrome???
Discussion in 'The Hokey Ass Message Board' started by jcrapola, Jun 14, 2025.
  1. jcrapola
    jcrapola
    Ok fellas, I have been driving my 30 model A Ford coupe, and I ran across a little issue. My car does not have a roof insert, and the sun reflecting off of the 4 spoke steering wheel is blinding. Not always, but once or twice is enough to make me wanna do something about it.
    So, here is my appeal to the HAMB community: Has anyone ever engine turned chrome? The instrument panel I made for it is engine turned, and I’m thinking that engine turning the steering wheel would both look right, and fix my issue. IMG_1031.jpeg IMG_1030.jpeg IMG_1031.jpeg IMG_1030.jpeg IMG_1030.jpeg IMG_1030.jpeg
  2. TCTND
    TCTND
    I'm doubtful, but have not tried it. The chrome is a very very thin layer over nickle and copper. You could try it on a s**** bumper or something like that; who knows? An alternative might be to spray it with a matte clear coat.
  3. caprockfabshop
    caprockfabshop
    lothiandon1940 likes this.
  4. KevKo
    KevKo
    from Motown
    What about doing it with silver leaf the way the sign people do? Might not be durable enough. Model car builders use some stuff called Bare Metal Foil, real thin aluminum foil with adhesive back. Agin, not sure if it would stand up.
    Almostdone likes this.
  5. miker98038
    miker98038
  6. inthweedz
    inthweedz
    You wont know until you try.
    Get a smallish item that is chromed (for a test piece).
    A piece of round 1/2'' dowel, 2'' long (or whittle down a bit of wood) and tighten it in your bench drill.
    Smear some medium valve grinding paste on the end of the dowel, and start the drill..
    Hold the test chrome and work the wooden dowel down onto the chrome for a few seconds, raise slightly and move the chrome piece slightly to do the next swirl.
    I've done this on shiny stainless steel with great results.
    oldsmobum likes this.
  7. BJR
    BJR
    Or you could put an insert in the roof. Or a piece of tinted plexigl***.
    Kiwi 4d, das858, swade41 and 4 others like this.
  8. RICH B
    RICH B
    '33 Ford dash insert was engine turned chrome; read on the Ford Barn about someone restoring one doing the same process.
    Budget36 likes this.
  9. Tim
    Tim
    from KCMO
    Feel like that’s how you get a rusty steering wheel.
    I would look into that clear protective film they put on the front of cars to keep it from getting chips. Shouldn’t change the look much and should kill the glare .
    05snopro440 and 427 sleeper like this.
  10. ClayMart
    ClayMart
    I'd get a thin sheet of aluminum big enough to cover the hub and spokes of the steering wheel. Trim it generously to leave extra material beyond the edges of the hub and spokes. Drill any necessary mounting holes in the hub and then do your engine turning to the entire face.
    Mount the piece to the steering wheel and use it as a pattern to do the final t******* to match the hub and spokes. Bend and shape the aluminum to fit as flat as possible to the wheel. Dress up any rough edges and use double face tape to attach the new trim to the face of the existing spokes.
  11. akoutlaw
    akoutlaw
    IMO: I would fill the roof.
  12. Tow Truck Tom
    Tow Truck Tom
    from Clayton DE
    Well if that's how ya feel..... duct tape:p
    mad mikey and lothiandon1940 like this.
  13. Petejoe
    Petejoe
    from Zoar, Ohio
    Try something like these 1” discs.
  14. '34 Terraplane
    '34 Terraplane
    from Western PA
    Ever think of using a "wrap" material like that used on all types of car exteriors and race cars? The company below has a turned aluminum wrap. If you get tired of it or want it removed, most wraps are removeable. Larger communities usually have businesses that do wrapping or hopefully can get you a material you like.
    https://www.fpmmetals.com/store/Aluminum-Engine-Turned-DGL-75-p471514639
    clem likes this.
  15. lothiandon1940
    lothiandon1940
    I get the same issue sometimes with my wheel and I don't have the option of 'filling' the top.:(..Everyone is making some suggestions, some good, some not so much. I personally don't think the engine turning will help since it just offers many more areas for reflection. Love what you did with the insert. Nice work there. I don't have a good answer short of changing the wheel or painting the spokes a matte color or just live with it. Sungl***es help.:) thumbnail (25).jpg FB_IMG_1525008048923 (1).jpg
    BigRRR, mad mikey, pprather and 5 others like this.
  16. swade41
    swade41
    from Buffalo,NY
    I think if you did the steering wheel it would overpower the look of the interior.
    With that being said I put this engine turned vinyl, in my top less t-bucket, on this gauge panel 20 yrs ago and it's still holding up great.
    Robdski, Budget36 and mad mikey like this.
  17. jcrapola
    jcrapola
    Thanks for all the replies fellas! I’m gonna try to engine turn the underside. If it doesn’t work, I will figure something else out, paint maybe?
    I think I will use a small tool. I used 1” diameter on the dash panel. I will try a 5/8” dia tool because the spokes are so damn narrow. I would like to have at least 3 or 4 swirls in the across direction.
  18. jcrapola
    jcrapola
    Well damn. Your car is a LOT nicer than mine! Mine is brush painted and more than little rough around the edges. Yours is lovely, just lovely.
  19. lothiandon1940
    lothiandon1940
    ...Thanks. You're too kind.
  20. Bandit Billy
    Bandit Billy
    I have. It will require the course Cratex like you would use on stainless steel. It won't bite in like aluminum but the pattern will be quite vibrant still. This is a cleaver that I "hot rod restored" (new rosewood scales, welded on a new handle with hooked end, re-profiled the blade) for a friend. It is hardened steel, not an easy surface to cut into. The pattern is still deep though. I used course Cratex and left it on the surface for at least 2 seconds where I typically would be down around 1 second on softer metal. I like masking the edges of odd items like spokes and this cleaver with duct tape around the edges to give it a border rather than run the pattern off the piece. I think that would look nice on your spokes.
  21. 1biggun
    1biggun
    I wear sungl***es when driving a cool car.
    49ratfink, Bentrodder, das858 and 5 others like this.
  22. dana barlow
    dana barlow
    from Miami Fla.
    Finish the roof,> Ya,that's the first thing comes out at me. Love look of rest,sorry I just don't get not finish of things= I love shiny stuff,we'er not all the very same= thats a good thing..:D:cool:
    das858 and lothiandon1940 like this.
  23. lothiandon1940
    lothiandon1940
    A repro Crestliner wheel would look good and solve your issue, but the cost!!!:eek:
    Kiwi 4d and MMM1693 like this.
  24. jcrapola
    jcrapola
    Thank you,Sir! That is super helpful (Cleaver turned out pretty sweet too BTW).
    When you use the duct tape, do you use a masking tape layer first? Or just go straight to duct tape and deal with the adhesive residue?
    Bandit Billy and lothiandon1940 like this.
  25. jcrapola
    jcrapola
    I like the unfilled roof. It is a bit like having a roadster. The roof insert does nothing for me except trap heat. Well, I guess it keeps the sun off my bald head, but I don’t mind that too awful much. I only drive it when it is nice out anyway… hell I don’t even have door gl*** in it, and I have never missed it.
    dana barlow and lothiandon1940 like this.
  26. loveoftiki
    loveoftiki
    from Livonia,Mi
    Engine turned vinyl…worked pretty good
    lothiandon1940 and patsurf like this.
  27. Bandit Billy
    Bandit Billy
    I have used masking tape alone but the Cratex cuts right through. Here is a picture of a trophy I built earlier this year for upcoming Lloydfest III.
    I apply the duct tape directly but your idea of lining it first with masking tape is clever. The only issue I see is the thickness of the tape will affect the pattern on the edge.
    I remove the tape, clean with whatever solvent is at hand and then I run the edge on the buffer lightly to polish it. You will have to be creative working on those spokes and leave out the polish step. I think it is much cooler leaving a border than running the pattern off the sides. This the is the panel turned and cleaned up.
    And a close up of that tricky bit at the bottom. As you can see, I like to round off the sharp edge of the panel to create a "softer" feel. I like that about polished metal, the way it feels in your fingers. You can't do that with a chromed surface as it will peel.
    This panel was done entirely using 3M masking tape to protect the edge and give me a place to work my pattern. You can see a very slight difference in thickness of the border from side to side. You can also see the "looseness" of my pattern on the right compared to the left, I was stretching the pattern to fill the panel and slightly overdid it. You can measure all you want but engine turning comes down to touch and feel. It is art not just maths. Imperfection is part of the beauty IMO. In the examples above of the vinyl, they are perfect and very nice.
    You can see I used a full circle around the boarder, rather than filling the pattern with a half circle which I would have preferred If I was to be picky. For that, the duct tape is the only thing I have experimented with that allows me to set the Cratex down "on the tape" and not tear it up and not be so thick as to prevent the Cratex from hitting the surface. This is just aluminum so a soft Cratex was used.
  28. 05snopro440
    05snopro440
    Wrap it in electrical tape, that's the traditional option. :p
    49ratfink and lothiandon1940 like this.
  29. RMONTY
    RMONTY
    Sell that wheel and buy one with the profits that isnt chrome maybe?:confused:
  30. 05snopro440
    05snopro440
    I've never seen a 4-spoke sprint style that isn't chrome or stainless... Do they exist?
