9s for $9k
Discussion in 'Off Topic Hot Rods & Customs' started by squirrel, Mar 18, 2025.
  1. oldiron 440
    oldiron 440
    Those guys are little more than no prep/street racers, he put the bars in for the drag and drive activities where they actually tech the cars.
    squirrel and 427 sleeper like this.
  2. squirrel
    I got some new boots for the back, and wheels too. 15x8 wheels with 3.5 back spacing, and 255/60R15 drag radials. The wheels are cheezy cast "modular" with the fake rivets around the outer center, so they were cheep.
    Just Gary, Thor1, porkshop and 10 others like this.
  3. 41 GMC K-18
    41 GMC K-18
    Just curious, with the new wheels and tires, is the speedometer still accurate or close to accurate!
    Inquiring minds want to know!
    porkshop, Sharpone and 427 sleeper like this.
  4. squirrel
    oh, it'll be off a bit with them. But I don't plan on putting a lot of street miles on them, they wear out fast and cost a lot!
  5. RMcCulley
    RMcCulley
    Nice license plate!
  6. squirrel
    I took the line lock out of the Vette, and put it in Cheep.
    And had to do a little test burnout to make sure it was working.
    Then of course, get it warmed up and see how the new tires grip on the street. Pretty well, actually.
    I might have got some gopro video, I'll post that too if it works. Still working on it.
  7. squirrel
    a rather half-hearted merge, but it was fun. If it was turning 5000 rpm at the end in high gear with 3.73 gears and 26" tall tires, I might have been going fast? or the converter slips a lot? it dropped down to 3800 pretty quick after I let off. That's not nearly as fast. Or I was on the brakes?
  8. fastcar1953
    fastcar1953
    Do you need bigger injectors? Fuel pressure is 52. I thought it might be higher around 60.
    4 lbs boost , is that what your looking for? I figured it would be around 8 to 10.
    I'm still learning all this myself.
    porkshop, 41 GMC K-18 and squirrel like this.
  9. squirrel
    The numbers shown on the left are not the actual data from the part of the log that you are looking at, that's at idle, note the RPM is 928, and boost is -4.0, which is vacuum. When it's under boost, fuel pressure goes up to around 60. If I were to move the cursor to where the action is, you can see what's going on with those numbers. The cursor is the white crosshair.
    also note that I'm only at about 75% throttle...
  10. squirrel
    Oh...injector duty cycle, tells you if you need more injector. They're way too big, actually. The duty cycle shows in this one, they're only open a third of the time!
    BigJoeArt, Thor1, Deutscher and 4 others like this.
  11. fastcar1953
    fastcar1953
    I missed the rpm at the top and didn't see the -4 on boost.
    Thanks for clearing that up. Carry on.
    porkshop likes this.
  12. snoc653
    snoc653
    from Iowa
    255/60r15s are 27 inch tires. Same size as the 80-83 Corvette.
    41 GMC K-18, squirrel and porkshop like this.
  13. squirrel
    Creature comforts...I installed the "screen" that plays android auto, so I can do navigation/music from my phone, without breaking all those new laws.
    And the cup holder, with the slot for the phone to sit in.
    There's a late night race in Tucson tonight, it's the younger crowd money race, but they say they'll allow TnT runs between rounds or something. So I'll see what happens. Might be there till 3, who knows. But again, I'm chickening out and hauling it up on the stretcher.
  14. RodStRace
    RodStRace
    Jim, do you have a way to log computer seen conditions (temp, baro)?
    I realize you don't have to do jet and timing changes, but it might help set dial-ins for future trips.
    41 GMC K-18 and porkshop like this.
  15. squirrel
    I should but I don't. Although the computer does log baro and mat, so I can use that to get close.
    Anyways, fighting the rev limiter again. Talked to the guy in the next pit, he told me what I was doing wrong. I wanted High limit only. Will try again.
    Right lane
    Thor1, 41 GMC K-18, porkshop and 10 others like this.
  16. Zuffen
    Zuffen
    from Sydney
    You gotta be happy with that.
    A bit more playing and 9's are well and truly on the cards.
  17. Sharpone
    Sharpone
    One and a half seconds to nines.
    That could be a song or a Tee shirt
    Dan
  18. squirrel
    The next thing I need to work on is 60 ft times. That means getting it to build boost while staging. So I get to learn about the two step rev limiter .
  19. Sharpone
    Sharpone
    Which time is yours?
    Dan
  20. squirrel
  21. Sharpone
    Sharpone
    That’s what I thought - Impressive
  22. squirrel
    I did a little more research, seems that NHRA allows +/- 10% tolerance on wall thickness on the tubing. And still have not found any mention of required thickness after bending. So it seems to me that you probably won't get the answer you want to hear.
    Thor1, porkshop, slowmotion and 2 others like this.
  23. RmK57
    RmK57
    One thing I’ve found after installing a basic 5-point bar is welding the rear bars to the main hoop. If you’ve tried to get a nice tight fit hugging the roof line there’s no way to get a complete 360 weld. They do check for that I’ve found and may ask you to weld in triangular plates the same thickness as the roll tubing to strengthen the whole structure.
  24. squirrel
    the steeper the angle of the rear bars, the easier that weld is.
    porkshop, SS327 and 427 sleeper like this.
  25. DDDenny
    To fully weld the top, a common practice is to drop the main hoop through holes cut in the floor, this does require some creative juggling and getting the rear bars fitted and premarked with location lines.
    Thor1, Sharpone, Tickety Boo and 2 others like this.
  26. RmK57
    RmK57
    I explored that idea but the way my frame and floor pan is constructed plus the rear bars p***ing through the parcel shelf opening it would have been easier to cut the roof off. I think the NHRA rules state they want 75% of cir***ference of the tube to be welded. I’m pretty close.
    Sharpone and porkshop like this.
  27. squirrel
    That's something that I had heard for years too, but reading the rules, they don't mention it...
    As you probably know, tech inspections at local tracks of cars that are relatively slow, never seem to include more than a glance at the roll bar/cage. I think it also has to do with the car looking in general like it was built to meet the rules. Some cars look like **** in that regard, I try to always make sure the stuff that I know needs to be done, is done. Solid battery hold down, throttle return spring, lug nuts/studs, that kind of stuff, if they see it, they don't seem to worry too much about the rest.
    I really do appreciate your concern.
  28. RmK57
    RmK57
    One thing tech checks for 100% of the time at both tracks I race at are expire dates on belts and helmet.
  29. gene-koning
    gene-koning
    Going out on a limb here, but I suspect the tech inspectors at the drag strip see more injuries from failed out dated seat belts or improperly installed roll cages, then they see from actual properly built roll cage failures.
    A roll cage with the main points welded directly to the sheet metal floor pan without the 6" square 1/8" plate between the cage tubing and the floor pan would be a big red flag. Tubing with joints that are only 60% welded and have gaping holes the rest of the way around are another big red flag.
    Most of us have seen the video of the 55 (or 56) Chevy doing the roll over past the guardrail where the driver is flipped out of the still rolling car. No one really wants to see that happen in real life, so the rules are written to prevent that from happening again, not many come out of those type of crashes as well as that lucky guy did.
    The reality is, most racers are more concerned about going faster then they are about being safe. Most of the comments on this post are concerning what is required by the rules to go "this fast" and keep the tech guy happy, not about what needs to be done to keep the driver safe at that speed.
    Just Gary, Sharpone and porkshop like this.
  30. 19Eddy30
    19Eddy30
    from VA
    The Days !!!
    First Drag strip on East
