History scalloped paint jobs rule of thumb?
Discussion in 'The Hokey Ass Message Board' started by damagedduck, Jul 7, 2013.
  1. damagedduck
    damagedduck
    from Greeley Co
    I have read a bunch of custom car/truck threads about this-N-that... so what are the rules of scalloped paint jobs, I've seen rounded ones & squared off ones, I figured the rounded one go on rounded bodies & square go squared shaped bodies,and when did they come into play?
    I've seen then on everything from A-Z, I want to put them on my 53 F100 & was wondering what is the 'right' way of laying them out.......
    such as this one..
    http://www.jalopyjournal.com/forum/showthread.php?t=189013&highlight=scalloped+paint+jobs
    I've read just about everything from Gene Winfield to Larry Watson and just about every other painter,
  2. big duece
    big duece
    from kansas
    Square ones remind me of 90's street rod graphics, barf.
  3. Leviman
    Leviman
    Whatever the hell looks the best, do that. It's just a paint job who needs rules?
  4. big duece
    big duece
    from kansas
  5. damagedduck
    damagedduck
    from Greeley Co
  6. jmpowie
    jmpowie
    The only rule is, try to get both sides to look the same. I tried to paint a simple 3 scallope on the side. After laying tape about 100 times I ended with a cactus.
  7. 40StudeDude
    40StudeDude
    There is no hard and fast 'rule'...the only thing you need to adhere to is do the scallops make the car, and its' body lines, look better...choice of color is also an option...
    Personally, I prefer the rounded corner scallops, just seem to 'flow' better than sharp corners, especially on a sort-of 'round' body like a '53 F-100...
    R-
  8. indyjps
    indyjps
    My scallop rules, they rarely make anything look better than solid color. I'm sure I'll catch hell for this, but there it is. The exception being curvy customs where the scallops follow the lines of the car,even then the color needs to complimentary to the base and preferably a pearl. Example a medium dark green base with a medium green/lime pearl scallop, thin and long that doesn't break up the bodyline but compliments it.
    The SoCal car and some of the Bonneville type coupes got it right.
    For your truck, find a layout you like or get some photoshop help, It a blocky design so a front 1/3 2 tone with a medium length thin scallop down top of the door, a large radius to a shoter middle scallop then another large radius to a medium length thin scallop along the bottom of the door would work. you could also do long to short or short to long. Look at it long and hard to incorporate the fender, lay it out in tape
  9. 2 Deuce
    2 Deuce
    from pa
    Rounded always look the best in my opinion.... be sure to lay your lines with the bodylines and PLEASE be sure to use a quality fine line tape to lay your pattern.... then trace you pattern on some 36" paper and transfer to the other side of the car .. the pattern will be reversed so you will have to either punch holes in the paper and use powdered chalk to transfer to the body.... or trim the paper and use it as a template to set up and use as a guide.... Keep in mind.... tape is always cheaper than repainting... Hope this helps
    LeoH likes this.
  10. Fenders
    Fenders
    Fixed it for ya ... no one sees both sides at the same time. :D
  11. philly the greek
    philly the greek
    from so . cal.
    Never knew there were rules to painting scallops, but here's some pics and a few things to think about . Not all scallops have to look like someone painted a pitchfork on the side of your car . Sometimes less is better than more . Think long and sleek , not short and stubby . A little fading of colors goes a long way . They always look better with a pinstripe outline .
  12. Stevie Nash
    Stevie Nash
    Saw some backwards scallops today. Please don't do that, my eyes still hurt...
  13. damagedduck
    damagedduck
    from Greeley Co
    No damn chance of that!:cool:
    here's a couple that I kinda like,
    I'm thinking this wayyyy too busy,
    juan motime likes this.
  14. Ole don
    Ole don
  15. GassersGarage
    GassersGarage
    One of my favorite scalloped cars. This was done in the original owners garage.
  16. bbr
    bbr
    from Missouri
    my buddy kenneth's 54 desoto he scalloped. i am not much on the color combo but scallops look pretty good.
  17. 48buickkid
    48buickkid
    Follow as many body lines as you can while not treading into looking like a the beginnings of a Panel paint job. Try and keep them all flowing the same direction also. My 2 cents.
  18. coppertone
    coppertone
    jimmy faris pics.JPG Try to take in ALL the body lines as you lay it out. Really helps if you can see it from a distance as you work. When you have it how you want it, leave it for a day and look again. Mine are pretty simple but took 1 1/2 days to lay out and a lot of tape in the trash.
    LeoH likes this.
  19. Gearhead Graphics
    Gearhead Graphics
    from Denver Co
    Come visit me, bring a few rolls of tape. We can scallop that ***** out bigtime
  20. damagedduck
    damagedduck
    from Greeley Co
    I have finish the motor mounts & build a drive shaft first,but like I stated I've been reading a bunch of threads & there really was no clear way of laying them out,some have no rhyme or reason:eek: kinda like they closed their eyes & started taping.
  21. Gearhead Graphics
    Gearhead Graphics
    from Denver Co
    Close eyes, lay tape, open, repeat until desired look is achieved.
  22. gtokid70
    gtokid70
  23. Irishjr
    Irishjr
    I am customizing my '53 Studebaker (53 COOP):
    https://www.jalopyjournal.com/forum/threads/53-coop-studebaker-gets-a-major-makeover.1208116/
    I have a set of '54 stainless full wheel disc repros on which I do not want to make any permanent irreversible changes. So I am thinking of painting candy blue scallops on them and having a striper add his/her bling. By not doing any sanding or other prep, I will have the option of using a paint remover to get back to stock.
    Do any of you have photos of such wheel discs from that period?
    By the way, here is a friend's '53 F-100 from a few years back that I laid out the scallops on:
  24. In_The_Pink
    In_The_Pink
    K.I.S.S. when it comes to scallops..."less is more", like this:
  25. Grandadeo
    Grandadeo
    I saved this pic in case I want to put scallops on my F1 some day. My one pet peeve if you will is that side scallops should be level with the body line and not have a downward slope, if that makes sense.
    Lee
    treb11 and lurker mick like this.
  26. xix32
    xix32
    Nardi's  chopped `51 Merc.jpeg Scallops should enhance the features that are already there, not distract from them
  27. JimSibley
    JimSibley
    Scallops are incredibly easy to do, and even easier to screw up. A good scallop job makes the car, and a bad one will ruin it. Here is my last one, I like it, but you be the judge. IMG_2337.jpeg
    Blues4U likes this.
  28. Blues4U
    Blues4U
    from So Cal
    Thanks for posting this one. I've been collecting photos of scallop paint jobs, as inspiration for what I want to do on my pickup, and this really hits the mark for me. Means I'd have to install a hood though......
