Hot Rods DeCode a SBC for me
Discussion in 'The Hokey Ass Message Board' started by mr.chevrolet, Jun 16, 2025.
  1. mr.chevrolet
    mr.chevrolet
  2. gimpyshotrods
    gimpyshotrods
  3. Fordors
    Fordors
    I’m reading through the rust, but if I’m correct it’s T0911HC. That engine was ***embled in Tonawanda, NY on Sept. 11th. If it was built in ‘65 through ‘68 it’s a 327, ‘69 it’s a 350. Check the casting numbers on the block as seen above the bell housing flange to ID the year.
    ‘65 would be a 250 horse engine, ‘66 -‘68 was 275 horse and if a ‘69 250 horse.
    05snopro440 and squirrel like this.
  4. mr.chevrolet
    mr.chevrolet
    thanks, i got that far too but what's the II?
  5. Fordors
    Fordors
    The I characters represent the 11th day of the month.
    Take a pic of the casting numbers on the left rear of the block
    05snopro440, Deuces and squirrel like this.
  7. squirrel
    you guys are good.
    The only sort of missing info is that it was used in full size cars 65-68.
  8. DDDenny
    Any photos of the heads.
    anthony myrick likes this.
  9. We have a great teacher
    bobss396, winduptoy, 51504bat and 4 others like this.
  10. patsurf
    patsurf
    :):):):):):D:D
  11. DDDenny
    Those charts can be less than fully accurate, such as the first one, (1965) calls out full size/Camaro.:confused:
    19Eddy30 and anthony myrick like this.
  12. LWB one :)
    spudshaft likes this.
  13. squirrel
    The chart is accurate for the years it shows, the HC suffix was used in Full Size in 65-68, then in A (chevelle) F(camaro) and X(nova) in 1969.
    Deuces, patsurf and gimpyshotrods like this.
  14. Black Panther
    Black Panther
    from SoCal
    I'll say it's pre '68...1965 to 1967 because there isn't a partial vin on the pad. ***uming of course that it isn't an over the counter engine which would be very unusual.
    squirrel likes this.
  15. Fordors
    Fordors
    The chart I referenced shows the 327’s as all 4 barrel carbs, Power Glide, fitted to PA, p***enger cars. The 350 was a 2 barrel, manual transmission and the applications were as follows CA, CH, EC, NO, Camaro, Chevelle, El Camino, Nova.
  16. Mr48chev
  17. warhorseracing
    warhorseracing
    from cameron wv
    I see traces of orange paint. Telltale corvette and a big price increase.:D
  18. squirrel
    HC isn't a corvette code, and all the car engines were orange in the 60s
    Deuces likes this.
  19. All SBCs are vette engines
    my uncles cement mixer had one
  20. mr.chevrolet
    mr.chevrolet
    i couldn't get pics of the rear, and as you can see it's got a 2 barrel carb and hooked to a 3 spd OD. thanks to all for responding. burt53.jpg 58parts1.jpg
  21. squirrel
    could be a mish-mash of parts...probably the original 58 intake and carb put on the later engine. looks like 327 heads under there, which would not have been used with a 2bbl originally.
  22. HEATHEN
    HEATHEN
    from SIDNEY, NY
    Right. A guy gave me a 283 a few years ago just to get it out of his way, and it ended up being a '61 block with a pair of '59 power pack heads and a '64 2 bbl. intake. It also had a '57-'61 style factory dual point distributor stuck in it.
    winduptoy likes this.
