Hot Rods 5/8" wide pulley for Sanden 508 style compressor
Discussion in 'The Hokey Ass Message Board' started by flying53gmc, Jun 15, 2025.
  1. flying53gmc
    flying53gmc
    from M-boro, TN
    adding ac to an old truck with a gmc 302 in it. I need the 5/8" pulley to put on the Sanden style compressor same as what the flatheads use I think. I see where you can get the entire compressor with the wide pulley, but I already have a new compressor. Where can I get just the pulley?
  2. tb33anda3rd
    tb33anda3rd
    do you have a second pulley for the crank? if not I would add a 1/2" pulley to the crank pulley and run a 1/2" belt for just the compressor.
  3. flying53gmc
    flying53gmc
    from M-boro, TN
    I'm replacing an existing air unit. The crank has 3 grooves all the big size. This truck is running a compressor, power steering pump, and alt. All custom brackets. Compressor runs on the center one and I'd like to just leave it the setup and size it is.
  4. gimpyshotrods
    gimpyshotrods
    Replacement parts for these are sold. I see most of the clutches.
    I have not yet found the wide belt one. I will keep digging.
  5. gimpyshotrods
    gimpyshotrods
    It does not appear to be in the catalog.
  6. gimpyshotrods
    gimpyshotrods
    I would call Vintage Air and ask them: 1-800-862-6658
    They sell the 508 (SD5H14) with that pulley, maybe they know.
  7. squirrel
    sanden 600-9840
    they use them on tractors...so go find a tractor supply place... :)
    deathrowdave likes this.
  8. gimpyshotrods
    gimpyshotrods
    About $145-170 for the whole clutch.
    Also appears under an OEM part number: SFD013761
  9. gimpyshotrods
    gimpyshotrods
  10. flying53gmc
    flying53gmc
    from M-boro, TN
  11. gimpyshotrods
    gimpyshotrods
    We have got to take care of each other!
    BJR, 51504bat, Jim Bouchard and 3 others like this.
  12. flying53gmc
    flying53gmc
    from M-boro, TN
    After all that searching I decided to try something tonight. The clutch kit was gonna be almost $200 after tax and shipping. I’ve got a lathe but have only used it once. I decided to try my luck.
    tb33anda3rd and BJR like this.
  13. squirrel
    I like my lathe, it saves me a lot of money, too!
  14. gimpyshotrods
    gimpyshotrods
    Looks good!
